Old Aug 15, 2014, 11:51 AM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Here is a link to tell you about what the FAA is planning to do to our hobby, and how you can send your comments to the FAA if you care:
http://www.modelaviationdigital.com/...&pm=2&fs=1#pg3
dbacon is offline Find More Posts by dbacon
Old Sep 28, 2014, 05:28 AM
BASTHEBEAR is offline
Find More Posts by BASTHEBEAR
Joined Mar 2014
Hey,
Im about to build the 62 version FlyGuy, I saw some motors and I still have one laying around.
I have these 2 motors, which one will suit the 62 inch Flyguy?
http://www.hobbyking.com/hobbyking/s...er_1200kv.html
http://www.hobbyking.com/hobbyking/s..._version_.html
If one of the 2 would fit the flyguy, then which size prop would I need?
Actually I'd like to make the 46 inch flyguy but I can't find any tiled plans of it (someone a link?)
(I will make it out of 6mm depron)
Thanks already!
BASTHEBEAR is offline Find More Posts by BASTHEBEAR
Old Sep 28, 2014, 11:45 AM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
Originally Posted by BASTHEBEAR View Post
Hey,
Thanks already!
Of the two, the second motor will work but you will have to go 6s with an 8x4 prop. Really recommend you consider an Eflite power 10 motor, 3s. Can't help with the 46 tiled plans, just what's on the build thread.
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Sep 28, 2014, 02:38 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Use Acrobat X or higher and it will print the pages as if initially tiled.
Or get PDFill PDF tools ( free)
Bob
Hoosier Cutout Service
birdofplay is offline Find More Posts by birdofplay
Old Nov 04, 2014, 10:52 AM
Joined Aug 2011
New Flyguy Video of Superman over SD
Thought I'd add this new video taken during a shoot with the Discovery Channel.
RC Superman over San Diego by Otto Dieffenbach (0 min 35 sec)
Old Nov 04, 2014, 02:35 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Very cool, Otto. Thanks for the great video.
Old Nov 17, 2014, 01:52 PM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
Iron Man survives Maiden Flight
Fantastic test flights yesterday! adding mask to see what effect it has. Also motor ran hot even though amps were @59 static so will try 2 blade 10x6 instead of 10x7x3.
Motor Turnigy 3536 1400kv 60a esc. 630 watts.
Also made custom pull-pull horns. Videos soon.
picard10th is offline Find More Posts by picard10th
Old Nov 17, 2014, 03:58 PM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Looks kinda scary with the mask on.
Pull-pull cables are the best, I use them on everything I can.
Did it fly well with the mask?
Old Nov 17, 2014, 10:21 PM
picard10th's Avatar
Joined Jan 2007
Test flight video
The Iron Maiden Lol.
Flew very stable only a couple of clicks of trim. 36oz because of additional structural reinforcements for larger motor. Next some touch ups, reprop and add mask.
Iron Man Maiden (7 min 30 sec)
Old Nov 17, 2014, 11:09 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
Can you give us a hint as to where you set the CG on this and and did putting the mask on change anything? I still have yet to get my Flygirl in the air. She's got a full manikin head but I think my motors are mounted in the wrong place. I need to remove them and re-install them a bit lower in the chest.
xviper is online now Find More Posts by xviper
Old Nov 18, 2014, 01:09 AM
Joined Aug 2011
Maybe a little pitch-up with the mask. Great flyer.
Old Nov 18, 2014, 02:12 AM
picard10th's Avatar
Joined Jan 2007
Weather turned bad so haven't flown with mask yet. CG exactly where Otto said 1/2" in front of top notch. I inserted a piece of fishing line tied and glued around a small piece of CF, easy to check cg and lateral.
Old Dec 11, 2014, 11:45 PM
Canada
Joined Jul 2009
Here is the video of my first successful (sort of) flight of my Flygirl. It's got dual motors/ESCs and runs on 3s, 3300mah battery. I ran out of juice on the landing run and it hit the ground somewhat abruptly and broke her boobs. When I give her a new boob job, I'll replace the motors and props with a more powerful setup. It's somewhat under powered and it's quite nose heavy. The battery will be moved back a fair bit on the rebuild. She flies OK but needs high rates for decent response. I think the manikin head and wig disrupts the aerodynamics.
This vid was made with a wingcam clipped to my ballcap. The sun was in a poor position at the time, in a rather overcast day. Hence, the dark background some of the time.
RC Flygirl (4 min 17 sec)
Old Dec 12, 2014, 12:34 AM
Joined Aug 2011
https://www.youtube.com/watch?v=uoNl...PNr8CdPo2CeUaw
Looks like she was flying well until the abrupt ending. Good luck on the boob job and send more video.
Old Dec 12, 2014, 05:53 AM
dbacon is offline
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Very cool, great job!
Build Log Build: Birdofplay 62" Flyguy Otto Dieffenbach Foamies (Scratchbuilt) 432 Dec 23, 2015 09:03 PM
Build Log Dick's Dream version 2.0 BigIron357 Balsa Builders 89 Jan 26, 2014 09:53 AM
Sold Turnigy 9X mode 2 version 2 with module and Rx --SOLD DirtyThirty Aircraft - General - Radio Equipment (FS/W) 2 Jan 12, 2013 06:07 PM
For Sale CVS camcorder version 03.62 darmar Non R/C Items (FS/W) 3 Nov 19, 2006 06:56 PM
