Old Aug 11, 2013, 05:14 PM
lv2soar is offline
Find More Posts by lv2soar
Los Angeles, CA
Joined Mar 2004
Originally Posted by Mauronic View Post
Thanks Otto, I am going to take your advice and keep it simple to start.
Here's a shot I took of my painters last night.
Nice paint job
lv2soar is offline Find More Posts by lv2soar
Old Aug 11, 2013, 11:35 PM
Mauronic is offline
Find More Posts by Mauronic
cool, how high does it go?
Mauronic's Avatar
Joined Jun 2012
Originally Posted by Otto Dieffenbach View Post
The black with white poke a dots gets my vote.
Haha
Mauronic is offline Find More Posts by Mauronic
Old Aug 16, 2013, 03:10 PM
Mauronic is offline
Mauronic's Avatar
Joined Jun 2012
Gah! I can be dyslexic sometimes -- I glued the elevons to the wrong side of the legs so my breast plate slots are now angled the wrong direction. So I either have to move the elevons to the other side (lots of glued surfaces there) or fill in and re-bevel the slots.
This is my first airplane build and probably not a beginner one at that. Anyhow, I suppose fixing the slots is the way to go. Should I cut out small foam pieces and glue them in to restore the slots? Cover the slots completely with foam and cut them out from scratch? How would you guys do it?
Old Aug 16, 2013, 04:58 PM
Aus is offline
Aus
Find More Posts by Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Australia, ACT, Amaroo
Joined Jul 2011
Bummer - I would cut out small foam pieces and glue them in to restore the slots. You can use a light weight spackle to smooth it out and then repaint those areas. Good luck with the remainder of the build.
Aus is offline Find More Posts by Aus
Old Aug 16, 2013, 05:24 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Yep... just scrap fill the holes and start over !
Otto has some good pix to look thru here
Flyguy 62 Version 2 Build Log is at:
http://www.rcgroups.com/forums/showthread.php?t=1836963
http://www.rcgroups.com/forums/showthread.php?t=1578106
http://www.rcgroups.com/forums/showthread.php?t=1584197
Take your time and plan your moves.
Worst case ... Otto is just south of you in SD !
L8r
Bob
Hoosier Cutout Service
birdofplay is online now Find More Posts by birdofplay
Old Aug 21, 2013, 04:06 PM
Mauronic is offline
Mauronic's Avatar
Joined Jun 2012
CG balance should be 1/2" in front of the shoulder blade notch, at the arrow. Add ballast to balance. Check your lateral balance to insure it is on the centerline. Total AUW is around 30 oz.
Hey guys, this CG point makes my guy very tail heavy requiring 2 2200s worth of extra weight at the head to balance. This just doesn't seem right.
FWIW, I used 3-4 coats of spraypaint (lots of paint) and 2.5 hot glue sticks to hold my golden rods down!
Attached are pics, sharpie marks the spot where I believe the CG is supposed to be. Correct me if I am wrong.
Old Aug 21, 2013, 04:21 PM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
The CG is where you have the Sharpie. The golden rods are heavy. I'd remove them and go with the wire in the build log. Buy some lead weights and add at the tip of the head until he balances correctly. He will not fly correctly unless you do.
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Aug 21, 2013, 04:26 PM
Mauronic is offline
Mauronic's Avatar
Joined Jun 2012
Thanks Otto. His feet are upside down (long story). Since he is an alien maybe I could cut them off. You think that would do it?
Old Aug 21, 2013, 05:06 PM
Joined Aug 2011
Nope. Need the feet for stability. You could cut them off and glue them back on right side up though.
Old Aug 21, 2013, 09:41 PM
Mauronic is offline
Mauronic's Avatar
Joined Jun 2012
I don't have time to flip the feet for aesthetics but will it adversely impact flight? If I wasn't on a deadline I would drive to San Diego so you could have a look ��
Old Aug 22, 2013, 12:11 AM
Joined Aug 2011
Don't think it will effect flight.
Old Aug 22, 2013, 10:40 AM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
My advice is to build it just like Otto designed it. If something came out different, re-do it, you will save a lot of trouble in the long run.
I built one of his designs, and I downsized it by 20%, then i made the wings slightly longer. It flew completely different, and I had to experiment to get it corrected.
Otto has a lot of experience, there is little reason to deviate from his designs. If you must, build it his way first, then change it for an experiment.
dbacon is offline Find More Posts by dbacon
Old Aug 25, 2013, 07:35 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Notice:
But please be patient.
My web site and e-mail are currently both DOWN since Thursday PM !
I've never had a problem like this since 2006 either.
PM me if you are in a hurry.
Best
Bob
Old Sep 08, 2013, 08:02 PM
Joined Aug 2011
Savannah, GA
Is anybody close to the Savannah, GA area? I'll be there and intend on flying in early October.
Thanx, Otto
Old Sep 11, 2013, 07:59 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Just this quick note:
The WEB SITE and E_MAILS all seem to be Back to Normal !
Thank you all for your patience.
Bob
Build Log Build: Birdofplay 62" Flyguy Otto Dieffenbach Foamies (Scratchbuilt) 432 Dec 23, 2015 09:03 PM
Build Log Dick's Dream version 2.0 BigIron357 Balsa Builders 89 Jan 26, 2014 09:53 AM
Sold Turnigy 9X mode 2 version 2 with module and Rx --SOLD DirtyThirty Aircraft - General - Radio Equipment (FS/W) 2 Jan 12, 2013 06:07 PM
For Sale CVS camcorder version 03.62 darmar Non R/C Items (FS/W) 3 Nov 19, 2006 06:56 PM
