Old Feb 21, 2013, 05:12 AM
CUMICBOY is offline
Find More Posts by CUMICBOY
FT.MYERS FL.
Joined Mar 2009
Spar wrapping
Has anyone tried using spectra fishing line for wrapping spars? They make it in various sizes/ 30-80 # test.
CUMICBOY is offline Find More Posts by CUMICBOY
Old Feb 21, 2013, 05:33 AM
mhodgson is offline
Find More Posts by mhodgson
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
As long as it wraps nicely around the spar you can use anything. Before Kevlar thread I used ordinary cotton. I have a plan for a free flight competition glider that uses strips of covering tissue to bind the spar. What you don't want is something that is stretchy like monofilament line.
mhodgson is offline Find More Posts by mhodgson
Old Feb 21, 2013, 07:34 AM
RCJPNS is offline
Find More Posts by RCJPNS
Rcjpns
United States, FL, Pensacola
Joined May 2011
I tried Spider wire, but CA glue would not hold it. So I still use Kevlar.
RCJPNS is offline Find More Posts by RCJPNS
Old Feb 21, 2013, 05:17 PM
stewswanson is offline
Find More Posts by stewswanson
stewswanson's Avatar
United States, PA, Harrisburg
Joined May 2012
Wrapping
Vectran is anouther aramid fiber that works. Be aware that you will put a twist in the spar if you do your wrapping right.Periodically do an untwist to relieve the twist and wrap in a direction that will put washout in if not relieved.
Stew
stewswanson is offline Find More Posts by stewswanson
Old Feb 21, 2013, 05:48 PM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
Yes it works very well. Go ahead.
Wing-span is offline Find More Posts by Wing-span
Old Feb 21, 2013, 06:41 PM
LVsoaring is offline
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
Stew
I've never heard that. Not that I don't believe you, but can you explain how that happens? I'm just not understanding why that would occur.
LVsoaring is offline Find More Posts by LVsoaring
Old Feb 22, 2013, 02:37 PM
williamson is offline
Find More Posts by williamson
Joined Feb 2006
I have used Spectra line, but soon switched to Kevlar tow. If the Spectra is heated, it loses much of its strength. My concern is that heating the covering film (e.g., Monokote) will heat the Spectra too much.
I like Kevlar tow because it wraps quite flat and is easier to apply than Spectra, Kevlar thread or unwaxed dental floss (another good wrapping material).
williamson is offline Find More Posts by williamson
Old Feb 22, 2013, 03:20 PM
craigrrr is offline
Find More Posts by craigrrr
craigrrr's Avatar
San Diego area
Joined Jul 2006
For the best strength-to-weight I don't think you can beat kevlar thread. And it doesn't cost a lot.
Craig
craigrrr is offline Find More Posts by craigrrr
Old Feb 22, 2013, 03:38 PM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Spectra is polyethylene and CA doesn't stick to polyethylene very well, as far as I know.
Also, Spectra is affected by UV unless coated.
Also, I has creep - keeps on stretching over time.
I would just order some kevlar thread from the composite store or some kevlar tow from the guys in RCG or a composites store.
Fly2High is offline Find More Posts by Fly2High
Old Feb 22, 2013, 06:17 PM
Joined May 2012
Twist of spar
As you are wrapping and putting continuous tension on the wrapping material you
are putting a stress on the spar(twist). If you are securing your wraps periodically
with CA you are locking the distortion in.
Stew
Old Feb 22, 2013, 06:51 PM
LVsoaring's Avatar
Joined Jan 2006
Stew
Why wouldn't the tension on one side be cancelled out by the tension on the opposite side?
Now that I think about it, I assume any twist would (obviously) be in the direction of the wrap.
Still, I personally have never noticed this in any spars I have wrapped..... but I'll be looking closely on the next one!
Old Feb 22, 2013, 07:33 PM
mosquito303 is offline
Find More Posts by mosquito303
mosquito303
mosquito303's Avatar
Kansas
Joined Dec 2004
What are you trying to fix/achieve? The top and bottom of the the spar take the tension and compression loads. The stuff between the top and bottom become shear loads. There is a transition in direction and magnitude of both with load.
mosquito303 is offline Find More Posts by mosquito303
Old Feb 22, 2013, 07:39 PM
LVsoaring's Avatar
Joined Jan 2006
The way I understand it, and by no means am I an engineer, the wrappings are really only helping where there is a wing joiner of some kind. Under load, the joiner tries to "pry" apart the top and bottom spar caps. Wrapping the spar in the joiner area prevents this.
Seems to me that wrapping in other areas, say the middle of a wing panel (on a built up woodie) provides little, if any added benefit, especially if the spar is built well, with the parts fitting properly and tightly.
Old Feb 23, 2013, 06:36 AM
mhodgson is offline
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
Often, when a spar fails it is because the top spar has buckled. This is more likely with thin carbon flanges as opposed to thicker spruce ones. The wrapping along the spar helps prevent the spar lifting off he webbing and buckling.
Old Feb 23, 2013, 07:22 AM
dharban is offline
Find More Posts by dharban
Flying = Falling (Slowly)
dharban's Avatar
Tulsa, OK
Joined May 2004
I built a twist into an Allegro wing this way once and, for all practical purposes, it was PERMANENT. Unlike old school construction, I could not remove the twist.
I would recommend reversing the direction of the wrap for each rib bay.
Happy Landings,
Don
dharban is offline Find More Posts by dharban
Discussion kevlar thread wrap spars info jb86 Sailplane Talk 10 Feb 16, 2013 12:03 AM
Discussion Wrapping spars? woodys3b Thermal 14 Mar 31, 2006 06:01 PM
Question Best method for wrapping spars balsaaddict Thermal 3 Mar 27, 2006 07:27 PM
Discussion Spar Wrapping Materials johnsocj Thermal 15 Mar 06, 2006 08:05 PM
Wrap spar in spectra/dyneema or not fprintf The Builders Workshop 9 Mar 17, 2004 09:46 PM
