Old Feb 20, 2013, 04:32 PM
Sweetrex is offline
Find More Posts by Sweetrex
Addicted to my hobby
Sweetrex's Avatar
United States, NV, Las Vegas
Joined Sep 2009
55mm Thrust Tube Dimensions
I'm using an old GP Synapse EDF unit on a flat foam F-22 jet. I would like to know if anyone has dimensions for a thrust tube so I can make a new one for this unit. Intake tube as well would be helpful. The length should be about 50mm if at all possible. Even a formula or "rule of thumb" to get started would be appreciated.
Sweetrex is offline Find More Posts by Sweetrex
Old Feb 21, 2013, 04:38 AM
Entropy76 is offline
Find More Posts by Entropy76
The Last Question
Entropy76's Avatar
United States, UT, West Valley City
Joined Oct 2006
That's a huge fan! J/k since this the micro forum.
I usually just measure the outside diameter and then Google circle area calculater. Use diameter to get circumference. Then draw a line however long you want the thrust tube to be. Then draw another line for the circumference. So now you have what looks like a T. Then find out your FSA by measuring diameter of inner fan housing, convert to area. Then find diameter of the hub, convert to area and subtract the two. Now you have your FSA so times that by 85% and take that number and convert area to circumference. Now you have your dimensions for the end of the tube. Connect the lines. Make one side a bit larger by drawing a line parallel so you'll have a tab to tape. Also you need to arc the top and bottom lines upward a bit so when its rolled it keeps the edges parallel. The arc takes trial and error.
Or you could Google cone program.
http://www.conelayout.com/
Entropy76 is offline Find More Posts by Entropy76
Old Feb 21, 2013, 12:46 PM
Sweetrex is offline
Sweetrex's Avatar
Joined Sep 2009
I thought 55mm IS micro? Thanks for the education. I'll give it a try.
Old Feb 22, 2013, 01:46 PM
The Last Question
Entropy76's Avatar
Joined Oct 2006
No problem. I draw them out on paper and then set the clear plastic thrust tube over it and trace onto it. Local grocery store's where I picked up my last material for my thrust tube.
Discussion Twin 55mm MIG-29 w/3D Vectored Thrust xplaneguy Foamy EDFs 493 Oct 06, 2013 04:12 PM
Discussion Where can I order Mylar for thrust tubes in Canada? Pepperpete Electric Ducted Fan Jet Talk 20 Jan 22, 2013 01:45 PM
Discussion I have thrust tubes for 55mm fans metroidrc Foamy EDFs 7 Nov 10, 2008 02:29 PM
For Sale 4300kv 55mm Fans - 500g+ thrust! metroidrc Aircraft - Electric - Jets (FS/W) 2 Sep 05, 2008 12:24 PM
Discussion 55mm fan by Mega Power 2Lbs thrust carl rich Foamy EDFs 5 Apr 02, 2007 09:53 AM
