Old Mar 10, 2013, 11:24 AM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
The rec is below the motor and batteries. The ESC we are using
recommends a separate bec or battery for 4s and up.
The dowels are epoxied to the bulkheads, all the way across.
Kimber is offline Find More Posts by Kimber
Old Mar 10, 2013, 07:57 PM
Parkflyer81 is offline
Find More Posts by Parkflyer81
N00b Sloper Addict
Parkflyer81's Avatar
Australia, TAS, Brighton
Joined Dec 2005
Hey thats good, couldnt quite see that in the photo.
Parkflyer81 is offline Find More Posts by Parkflyer81
Old Mar 10, 2013, 09:32 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
I work neat!
Old Mar 13, 2013, 02:37 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
It has been a few days, but I have been busy. Got a lot of help with
the covering. Got some graphics ordered. Everything is on but the
windows and wing tips. Battery 1" back from the firewall. No added
weight. Very slightly nose heavy.. Perfect! It is nice when it comes
together right. All the measuring, checking, calculating pays off.
Old Mar 13, 2013, 02:39 PM
sirzeppu is offline
Find More Posts by sirzeppu
sirzeppu's Avatar
United States, UT, Farmington
Joined Aug 2011
That looks superb! Well done!
sirzeppu is offline Find More Posts by sirzeppu
Old Mar 13, 2013, 02:48 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Thank you!
"Houston, we have flaps"!
Old Mar 13, 2013, 02:58 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
My biggest boo-boo was the fairings on the fin. I put them on the
wrong sides. I had one on before I saw what I had done and it
was too late. It was covered, and CA'ed in place. The square end
is to the front and the tapered end is, wrong! BTW, what looks like
a mess in the cover is a reflection of the LED work light over the
table. The cover is smooooooooooooooooth there.
Brad said it would create a vortex and enhance the rudder operation. ???
AUW, 5.098lbs. Dead center of the recommended weight. 4.75-5.25lbs.
Old Mar 13, 2013, 03:46 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Finally, the most important part.
11X6 Xoar. 4s 5000mah
562w WOT!
Going to check it with the 11X5, maybe a bit more flight time.
Old Mar 13, 2013, 07:17 PM
sirzeppu is offline
sirzeppu's Avatar
Joined Aug 2011
Dear Lord! That'll HOVER!
Old Mar 13, 2013, 10:59 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Windows are in, wing tips are on. some graphics on. The rest of the
graphics should be here Monday or Tuesday. I have put it up so
Brad can work on his Air Trails Sportster. See "Building"!
All the controls are working, need a final adjustment. New radio will
be here tomorrow. There will be two versions programed for it.
A three channel version, and a four channel version. Both will
have flaps. Also the rec is in and the rec battery is mounted.
Old Mar 14, 2013, 06:24 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Very nice, Kimber. My first aircraft was an Eagle II I built around 1990. My Eagle has balsa stick pushrods. I had a .46 glow motor on it and it was very fast for a trainer. Even though there is some self-righting with the dihedral it is not near as forgiving as something like an Easy Star and can quickly get away from you. I never flew mine as a 3 channel and perhaps it might be more forgiving but you might still want to let someone else maiden it or go buddy box if you aren't cumfy with the maiden. And one thing I know for sure is that it doesn't do as well in a crash as a foamy as I built 3 wings and most of the fuse after a few lawn darts.
I have been enjoying your thread as I still have the Eagle II and have had electrifying it on the build queue for years but it just keeps getting bumped back. Nice to see the CG worked out. Even with the glow fuel tank and motor I still had to use a Harry Higley heavy brass prop nut to get the CG correct.
I got interested in the Eagle again after recently downloading a Sig Seniorita to Real Flight. I had forgotten how nice the 40 size aircraft fly.
Keep up the good work and keep us posted.
Rick
Rickochet is offline Find More Posts by Rickochet
Old Mar 15, 2013, 04:55 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Put the tail thingie dingie on today. Getting the radio programed so
it can be three or four channel at the flip of a switch. Also getting
the control surfaces all set. Graphics came today. May work on that
tonight after supper.
Old Mar 16, 2013, 01:33 AM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
The nautical term (i.e. on a boat) for the thingie dingie is a "skeg"... I can only assume it has some other name on an aeroplane.
davidterrell80 is offline Find More Posts by davidterrell80
Old Mar 16, 2013, 02:24 AM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
It is called a skid! They recommended several layers of
shipping tape on that area, but I think the skid looks better
and will look better later on for sure.
Old Mar 16, 2013, 08:29 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Originally Posted by Kimber View Post
Put the tail thingie dingie on today. Getting the radio programed so it can be three or four channel at the flip of a switch.
I like that idea. I have an Easy Star with ailerons that I had thought about doing that with. Are you going to be able to program the tx to move the rudder from left stick to the right one and disable the aileron servos? I have flown one on Real Flight with elevator on the right stick and rudder on the left and that was kind of awkard.
Yippee! Got my first "real" quad coming!! TurboRacer Multirotor Talk 18 Feb 19, 2013 09:20 AM
Build Log #46 Model building clinic >CG Eagle 2< my first kit PoniesatemyBagel Balsa Builders 15 Oct 23, 2012 04:49 PM
Discussion My first real build, MQ-9 Reaper ll Bullish ll Electric Plane Talk 4 Jul 07, 2011 08:07 PM
Discussion First real heli building question jfl14609 Beginner Training Area (Heli-Electric) 7 Dec 08, 2009 07:19 PM
First real pico flight - first real pico crash - PARTS INFO PLEASE! rojoyinc Electric Heli Talk 2 Feb 23, 2002 11:46 AM
