Old Feb 26, 2013, 12:43 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Originally Posted by BillM View Post
kimber
It is a great plane to start with. Goes together well. Does not require a great deal of sanding. And it is agreat flyer to boot.
I ought to know. I've built over 300 of them--both versions.
BM
Won't it be easier to just learn to fly??
Kimber is offline Find More Posts by Kimber
Old Feb 26, 2013, 05:28 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I turned mine into a V-Tail after awhile.. flies like it's on rails before and after the change.. a real nice trainer.
44 secs in you'll see a descent fly-by.
Maiden Flight of the Veagle (1 min 50 sec)
Jittery camera phone but not somnething you see everyday at the field.
Thermalin is offline Find More Posts by Thermalin
Old Feb 27, 2013, 03:59 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Thanks for sharing.
K
Got a good start on the new firewall, still need the holes to
get to the landing gear mount and a cut out for the arm to
clear.
This mounts about 3/4" in front of the original fire wall and slides
over the original rails
Old Feb 27, 2013, 04:02 PM
gene6029 is online now
Find More Posts by gene6029
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
You do very neat & clean work.....Gene
gene6029 is online now Find More Posts by gene6029
Old Feb 27, 2013, 04:14 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Thank you.
I did this on my scroll saw. I made a pattern from card
stock first. It is two 1/8' lite plies with glass cloth between
them, glued with TB III.
We make the rudders for the air boats this way, two 1/32"
laminated. Makes a very stiff part.
You need a very flat surface and a lot of weight.
Old Feb 28, 2013, 05:01 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I'm watching with interest...I've been building for over 60 years,and a new build is always interesting.
You airboat reminds me of a time I had a throttle stick wide open on a .40 sized one. I (wisely) said I'll just run it up on the beach and shut it down..Only thing was there was very little 'beach' and lots of wet grass.,with picnickers seeking safety !
They won't let me bring air boats to family picnics anymore.
epoxyearl is offline Find More Posts by epoxyearl
Old Feb 28, 2013, 07:21 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
We love air boats.
Old Feb 28, 2013, 10:57 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
The clamps on the front are just ballast. Going to fit the hatch next
and then glue in the added firewall. Do some sanding and start
on the tail parts. The hatch is more than big enough for the battery.
There is room to slide it from the firewall to behind the main gear.
How about a 16" prop????
Old Mar 01, 2013, 04:31 AM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Looking like a fuselage.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Mar 01, 2013, 04:45 AM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
Nice looking wheels.
loNslo is offline Find More Posts by loNslo
Old Mar 01, 2013, 04:02 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Thanks Guys...
Battery tray and new firewall installed. I added some spruce rails
to the lip for the hatch, Since it will be off and on a lot. The balsa
wasn't that hard so just to be safe.
Old Mar 01, 2013, 05:45 PM
epoxyearl's Avatar
Joined Oct 2011
If I can be forgiven for butting in, the nose wheel wire should be rotated a 1/2 turn....(the spring should be behind the nylon mount),to wind 'tighter' on compression,rather than opening up..
If it isn't in it's final position yet,why, just forget I said anything.!...lol
Filing a 'flat' on the wire, for the steering arm lock screw, will lock the steering arm against slippage.
I'm teaching on one of those at present....Yours looks great so far.
Old Mar 01, 2013, 06:56 PM
Wacky1 is offline
Find More Posts by Wacky1
Wasn't my fault, I had it and
Wacky1's Avatar
United States, WV, Ripley
Joined Jan 2012
This looks very similar to the old Eaglet 50 I am currently trying to get started. Very nice work so far.
Wacky1 is offline Find More Posts by Wacky1
Old Mar 01, 2013, 07:35 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
It is just there to hold the arm so I could do the cut out
in the motor mount plate. And yes I will do a flat spot.
and not you are not butting in. And thank you for the
comments. And I use Loctite on every thing.
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Thank you.
Yippee! Got my first "real" quad coming!! TurboRacer Multirotor Talk 18 Feb 19, 2013 08:20 AM
Build Log #46 Model building clinic >CG Eagle 2< my first kit PoniesatemyBagel Balsa Builders 15 Oct 23, 2012 03:49 PM
Discussion My first real build, MQ-9 Reaper ll Bullish ll Electric Plane Talk 4 Jul 07, 2011 07:07 PM
Discussion First real heli building question jfl14609 Beginner Training Area (Heli-Electric) 7 Dec 08, 2009 06:19 PM
First real pico flight - first real pico crash - PARTS INFO PLEASE! rojoyinc Electric Heli Talk 2 Feb 23, 2002 10:46 AM
