Old Feb 20, 2013, 12:37 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Build Log
First real build. Goldberg Eagle 2
OK, I have built a rubber band powered balsa plane. With
some help cutting out the parts. Brad won't let me use the
band saw. I use the scroll saw.
I have helped on several balsa builds, mainly sanding.
I have done several foamies. Well, three..
I have ordered a Goldberg Eagle 2. I am going to try and
do it by my self, with a bit of supervision.
I am doing it electric, ordered the motor, ESC from Headsup.
I will be building it three channel with the ailerons
fixed but able to fit a servo later it I want. I know it
will have a lot of dihedral but still should fly with
ailerons. Should be very forgiving. I am a three
channel only flier now.
The kit should be here today and I can get started on
some of the pieces pretty soon. Brad needs to do
the wing on the Sportster and then the big table will
be free.
I wanted something that could handle the wind better
than the little foamies I have been flying.
http://www.headsuprc.com/servlet/the...2-Sport/Detail
http://www.headsuprc.com/servlet/the...-60-Amp/Detail
We have several 4s 5000mah batteries.
I am going to use a seperate rec. battery.
17g Powerup metal gear servos. I also ordered some 3" lite wheels.
It should be around five pounds.
Kimber is offline Find More Posts by Kimber
Old Feb 20, 2013, 03:04 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
OK, it is here and I have looked it over for missing parts and broken
things, it is fine.
I realize I will need some help with the motor and battery part, but
it already has the hatch so it shouldn't be too hard. It is a lot bigger
than I thought it would be. The big wheels are going to look great
on it. It will be red and white, Red fuselage and white wing and
tail. Some red on the wing to help see it. We have an extra roll
of red left over from the P-51. We buy white in the 25' rolls.
Will prop it to about 500w. Start with an 11X6.
I am ready to get started...........
Old Feb 20, 2013, 06:55 PM
gene6029 is offline
Find More Posts by gene6029
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Post some pics as you move foreward with your build......Gene
gene6029 is offline Find More Posts by gene6029
Old Feb 20, 2013, 08:45 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
I will went I get to the interesting part. Everyone has seen
this type build.
Have some parts out and sanding the edges now. Need a
bigger table.
Old Feb 20, 2013, 09:50 PM
Leroy G is offline
Find More Posts by Leroy G
Leroy G.
Leroy G's Avatar
Coeur d' alene, Id.
Joined Jan 2010
You have been around balsa planes for some time so you should have no problem with the Eagle 11, it is one of the best trainers ever produced and has a reputation to prove it. Go 4 channel in the build you won't be sorry, you can still fly it with 3 and move up to 4 when your ready.
Welcome to the world of,"I built my first plane".
Leroy
Leroy G is offline Find More Posts by Leroy G
Old Feb 20, 2013, 10:19 PM
jbrooks01 is offline
Find More Posts by jbrooks01
New Bethlehem, Pa
Joined Nov 2006
Looking forward to your build thread. It is interesting to see an airplane come together step by step. Yes, post plenty of pictures. John
jbrooks01 is offline Find More Posts by jbrooks01
Old Feb 21, 2013, 08:04 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Leroy
Leroy hit the nail on the head.
This is an excelent kit, with great instructions.
I suggest, that when you join the wing halves, you go with the least dihedral option. The model will still be gentle enough for training, but will able to perform mild aerobatics, once the student has learned to fly.
I suggest that you just go for the 4 channel option in the beginning. With less dihedral, and the addition of ailerons, your model will fly much better, and the student should learn much faster.
Good luck on your build !
TomCrump is offline Find More Posts by TomCrump
Old Feb 21, 2013, 09:23 AM
twalther is offline
Find More Posts by twalther
United States, MN, Waseca
Joined Jan 2011
Please build it four channel, you can fly it a long time without being bored. Here is one that I was given, really did not want to build a trainer so this is what I did.
twalther is offline Find More Posts by twalther
Old Feb 21, 2013, 10:09 AM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
We have a four channel trainer, I bought this one because
it has the three channel option. I like three channel planes.
I don't get a lot of time to fly, I want it simple. I have flown
the Tower 40 a little, and the Sensei, I just like three
channel. I love my Flylite, but most days are just a little
too windy for it.
BTW, I got a EP Cub some time ago, didn't check it out too
good, it was a four channel so I put it away. Brad is going to
do it later.
Old Feb 21, 2013, 03:01 PM
sirzeppu is offline
Find More Posts by sirzeppu
sirzeppu's Avatar
United States, TX, Kilgore
Joined Aug 2011
Nothing wrong with 3 channels. I still get a HUGE grin on my face from my 20 year old Kadet Senior.
sirzeppu is offline Find More Posts by sirzeppu
Old Feb 23, 2013, 01:51 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Got the motor, ESC, servos, wheels today. Parts for the fuselage are
laying on the bench ready to start gluing.
Old Feb 24, 2013, 11:15 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Fitting things together and working out the mount for the motor.
Adding a firewall in front of the original with the proper angles
for the motor. More sanding and filing on the fuselage than I
thought there would be.
Old Feb 24, 2013, 11:24 PM
New Bethlehem, Pa
Joined Nov 2006
Yes, looking good. There is nothing better than watching a plane coming together. John
Old Feb 25, 2013, 04:32 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
The new firewall, now to make another one, and glue them together.
Old Feb 26, 2013, 11:51 AM
BillM is offline
Find More Posts by BillM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
kimber
It is a great plane to start with. Goes together well. Does not require a great deal of sanding. And it is agreat flyer to boot.
I ought to know. I've built over 300 of them--both versions.
BM
BillM is offline Find More Posts by BillM
Yippee! Got my first "real" quad coming!! TurboRacer Multirotor Talk 18 Feb 19, 2013 08:20 AM
Build Log #46 Model building clinic >CG Eagle 2< my first kit PoniesatemyBagel Balsa Builders 15 Oct 23, 2012 03:49 PM
Discussion My first real build, MQ-9 Reaper ll Bullish ll Electric Plane Talk 4 Jul 07, 2011 07:07 PM
Discussion First real heli building question jfl14609 Beginner Training Area (Heli-Electric) 7 Dec 08, 2009 06:19 PM
First real pico flight - first real pico crash - PARTS INFO PLEASE! rojoyinc Electric Heli Talk 2 Feb 23, 2002 10:46 AM
