Old Feb 20, 2013, 11:48 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Starmax F-35 Thunderbird 608mm Wingspan w/ Thrust Vectoring
I just got and put together this nice little jet. The owner's manual is almost useless. Nice thing is that it's self-evident how it goes together and it's an almost ready to fly.
Here's my problem:
The servo wires are numbered but don't believe them! When I plugged into my receiver, it didn't work at all. Well all of the servos worked and the motor worked but not what they were labeled for at all.
How are the servos supposed to be setup ideally?
After I sort out which wire does what, I can see the normal setup of aileron, elevator(& thrust vectoring up/down), rudder (steering and thrust vector left/right), and throttle.
But what is best way to program it with my Futaba 7C (7 channels)?
Elevons? Mixes? I've never had thrust vectoring before so I'm newbie at this.
Help!
Russ
RGS2010 is offline Find More Posts by RGS2010
Old Feb 22, 2013, 09:38 AM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
I got a reply from Futaba Support for programming 7C for thrust vectoring:
Thank you for your recent e-mail.
Here is one type:
Ch 1- Aileron
2- Elevator
3- Throttle
4- Rudder
5- Gear
6- up/down thrust vector
7- left/right thrust vector
Go to p-mix 1 and make it active, set the master to CH 2, slave is CH 6, switch does not matter and position is "--" and set the rate to what you want.
Go to p-mix 2 and make it active, set the master to CH 4, slave is CH 7, switch does not matter and position is "--" and set the rate to what you want.
If you want to turn the either of those mixes on and of from a switch. Just assign it to the switch you want under that p-mix.
Than go to parameter and set channels 5 and 7 to "-".
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 1728 Sep 10, 2016 08:25 AM
New Product Starmax 4s 64mm F-35 Thrust Vector model JGuilty13 Foamy EDFs 79 Apr 10, 2015 08:10 PM
Sold F-35 JSF Vectored Thrust EDF rcdude01 Aircraft - Electric - Jets (FS/W) 5 Feb 10, 2013 11:58 AM
Alert Hobby Lobby Crash Sale - Starmax F-35 Thrust Vectoring 64mm Jet ARF IFlyRCs Hot Online Deals 0 Jan 30, 2013 03:45 PM
Sold TX LPU: F-16 Thunderbird w/ Thrust Vectoring, BNF $100 Roswalt Aircraft - Electric - Jets (FS/W) 4 Dec 27, 2011 09:48 PM
