Old Feb 20, 2013, 07:23 AM
truespin is offline
Find More Posts by truespin
United Kingdom, London
Joined Jun 2009
Question
Phoenix with Devo 7e
Do I need any cables/adaptors (other than the dongle that comes with Phoenix) to hook my Devo 7e (Walkera tx) up to Phoenix sim?
I've seen contradictory information regarding this so am unsure whether I need an adaptor such as: http://www.ebay.co.uk/itm/Walkera-Ad...item337c6731d5
Can anyone with Phoenix and a Devo 7e help?
truespin is offline Find More Posts by truespin
Old Feb 20, 2013, 07:27 AM
Puzom is offline
Find More Posts by Puzom
Puzom's Avatar
Joined Oct 2007
Just mail support, they know what you need support@phoenix-sim.com
Puzom is offline Find More Posts by Puzom
Old Feb 20, 2013, 10:29 AM
truespin is offline
Joined Jun 2009
Good call
For anyone else wondering how to get the Devo 7e to work with Phoenix, this was their support's answer:
We have not tested this transmitter but customers confirm the following works correctly:
1) Ensure TX is turned off.
2) Insert the 3.5mm mono to mono cable supplied with the TX into the DSC port.
3) Power on the TX. After a couple of seconds, the display should say:
"PC 0%" rather than the usual "TH 0%".
4) Without powering down the TX, swap the Walkera cable for the Phoenix dongle cable.
Old Aug 10, 2013, 11:07 AM
bryan30 is offline
Find More Posts by bryan30
Joined Feb 2012
Good call
You just saved me from going insane!!!
I had been searching and reading for two days pulling my hair out on how to get Phoenix to recognize my Devo 7 and doing what you recommended is the ONLY method that worked.
So many were posting that the devo 7 works with phoenix, but I could not figure out how to make it work!
Thank you so much for posting this!!!
bryan30 is offline Find More Posts by bryan30
Old Aug 03, 2014, 01:27 PM
D_an_W is offline
Find More Posts by D_an_W
Joined Feb 2014
Sorry to dig up an old thread but...
If the Devo 7E is running Deviation would it be just a case of choosing a suitable model file as well as following the above instructions?
D_an_W is offline Find More Posts by D_an_W
Old Sep 02, 2014, 05:42 AM
helimental is offline
Find More Posts by helimental
Joined Sep 2014
DEVO 7 & Phoenix 5
Truespin you have just saved me from going completely mental. Thank you so, so much.
Why didn't the people who sold me Phoenix tell me about this quirk ?
helimental is offline Find More Posts by helimental
Old Sep 16, 2014, 02:51 PM
LDan101 is offline
Find More Posts by LDan101
>DON'T PANIC<
Joined Aug 2014
Hi folks,
When I do step 1 thru 3 my brand new Devo 7E does not display "PC 0%" rather than the usual "TH 0%". What does change on the normal transmitter screen display is the TX signal strength bars disappear and an image of what looks like a computer monitor hooked to a TX radio appears in its place. Can I safely assume this is the same thing? I'm wanting to get Phoenix 5 to use with this TX.
Also, is it confirmed that the Phoenix "stereo" plug will work ok plugged into the 7E's mono port, or do you need a stereo to mono adapter.
Dan
PS - Does the 7E have to be running Deviation, or will the stock firmware work with Phoenix?
LDan101 is offline Find More Posts by LDan101
Old Sep 16, 2014, 02:54 PM
LDan101 is offline
>DON'T PANIC<
Joined Aug 2014
Deleted
Old Sep 25, 2014, 08:02 AM
LDan101 is offline
>DON'T PANIC<
Joined Aug 2014
I got Phoenix 5 and by just following the included instructions (ignoring the part about transmitters not supported: All Walkera except 2xxx) my still unDeviated Devo 7E works with just the included Phoenix interface cable.
Discussion Beginner configuration for Devo 7e with Walkera Super CP h2joe Electric Heli Talk 5 Apr 14, 2014 09:40 AM
Question Hoten-X with DEVO 7E losing connection Johnny NoPants Multirotor Electronics 3 Feb 08, 2013 07:04 PM
Discussion 2013 Stocks of Walkera Super CP 6CH 3D RC Heli With DEVO 7E TX Preselling at $70-Off! OMG Micro Helis 17 Jan 12, 2013 05:22 AM
Found Devo 7 or Devo 7e JHawk19 Aircraft - General - Radio Equipment (FS/W) 0 Jan 07, 2013 11:49 AM
Discussion Ladybird with Devo 7 or 7E ?? Butch777 Mini Multirotors 10 Dec 19, 2012 02:26 PM
