Old Feb 20, 2013, 03:33 AM
Dutchraptor is online now
Find More Posts by Dutchraptor
Dutchraptor's Avatar
The Netherlands, ZH, Hoogvliet
Joined Jul 2008
PCF8574P/AP I2C portexpanders
Hi guys,
Following the control unit based on the Arduino, I have also created a little expantion pcb. I want to use it for some nummeric leds, but it can also be used for extra button inputs or extra output pins. The top version is an older version which I used in my ships. Address is defined with the top left pins which can be pulled to 0 or 5V (000 tot 111).
The larger one is just 000. I want to use this one as a default for a channel indicator for my Arduino Control and leave it s simple as possibly for everyone to use (also people with no experience in soldering and programming).
I'm now programming a simple arduino sketch to let you guys test the thingy. Will follow the next couple of days. Any questions or comments, don't hasitate.
I have some issues with the unit in combination with NRF24L01 units, I try to get around that problem. Like another forum said, following the datasheet it should be possible. Keep you posted on that.
grtz
Danny
Dutchraptor is online now Find More Posts by Dutchraptor
Old Feb 20, 2013, 08:13 AM
Joined Jul 2008
Sorry slight error in the pcb, will be corrected soon.
Edit: Corrected version
Old Feb 20, 2013, 11:52 AM
Joined Jul 2008
The Code
And as promised a testprogram to test the duo version of the PCF port expander. Just tested it on an breadboard. You can change addresses by pulling pin 1-3 to 0 or 5V creating 8 different addresses. The PCF8574P and PCF8574AP both have a different startnumbers (100 and 111) so total of 16 PCF's is possible with each 8 i/o ports that can be used for input and output. The test program is for inputs. In the program you can also find a line for writing to the PCF.
grtz.
Danny
Code:
#include <Wire.h>
#define expander1 B0111000  // Address with three address pins grounded.
#define expander2 B0100000  // Note that the R/W bit is not part of this address.
                            // B0111000 = ap
                            // B0100000 = p
int PinValue1; int PinNumber1;
int PinValue2; int PinNumber2;
void setup() {
  Wire.begin();
  Serial.begin(9600);
  expander1Write(B00000000);
  expander2Write(B00000000);
void loop() {
//expander1Write(B11111111); // all pins HIGH
//expander1Write(B00000000); // all pins LOW
//expander2Write(B11111111); // all pins HIGH
//expander2Write(B00000000); // all pins LOW
// read expander1 pin (input)
  PinValue1 = (expander1Read());
  PinValue2 = (expander2Read());
// First PCF8574 on address 0
////////////////////////////////// PIN 0 ///////////////////////////////
   if (PinValue1 == 0) {
    PinNumber1 = 0;
////////////////////////////////// PIN 8 ///////////////////////////////
   if (PinValue1 >= 128) {
    PinNumber1 = 8;
    PinValue1 = (PinValue1 - 128); }
////////////////////////////////// PIN 7 ///////////////////////////////
   if (PinValue1 >= 64) {
    PinNumber1 = 7;
    PinValue1 = (PinValue1 - 64); }
////////////////////////////////// PIN 6 ///////////////////////////////
   if (PinValue1 >= 32) {
    PinNumber1 = 6;
    PinValue1 = (PinValue1 - 32); }
////////////////////////////////// PIN 5 ///////////////////////////////
   if (PinValue1 >= 16) {
    PinNumber1 = 5;
    PinValue1 = (PinValue1 - 16); }
////////////////////////////////// PIN 4 ///////////////////////////////
   if (PinValue1 >= 8) {
    PinNumber1 = 4;
    PinValue1 = (PinValue1 - 8); }
////////////////////////////////// PIN 3 ///////////////////////////////
   if (PinValue1 >= 4) {
    PinNumber1 = 3;
    PinValue1 = (PinValue1 - 4); }
////////////////////////////////// PIN 2 ///////////////////////////////
   if (PinValue1 >= 2) {
    PinNumber1 = 2;
    PinValue1 = (PinValue1 - 2); }
////////////////////////////////// PIN 1 ///////////////////////////////
   if (PinValue1 >= 1) {
    PinNumber1 = 1;
    PinValue1 = (PinValue1 - 1); }
// Second PCF8574 on address 0
   if (PinValue2 == 0) {
    PinNumber2 = 0;
   if (PinValue2 >= 128) {
    PinNumber2 = 8;
    PinValue2 = (PinValue2 - 128); }
   if (PinValue2 >= 64) {
    PinNumber2 = 7;
    PinValue2 = (PinValue2 - 64); }
   if (PinValue2 >= 32) {
    PinNumber2 = 6;
    PinValue2 = (PinValue2 - 32); }
   if (PinValue2 >= 16) {
    PinNumber2 = 5;
    PinValue2 = (PinValue2 - 16); }
   if (PinValue2 >= 8) {
    PinNumber2 = 4;
    PinValue2 = (PinValue2 - 8); }
   if (PinValue2 >= 4) {
    PinNumber2 = 3;
    PinValue2 = (PinValue2 - 4); }
   if (PinValue2 >= 2) {
    PinNumber2 = 2;
    PinValue2 = (PinValue2 - 2); }
   if (PinValue2 >= 1) {
    PinNumber2 = 1;
    PinValue2 = (PinValue2 - 1); }
////////////////////////////////// DEBUG ///////////////////////////////
  Serial.print("Pinnumber PCF8574AP is: ");
  Serial.print(PinNumber1);
  Serial.print("  /  Pinnumber PCF8574P is: ");
  Serial.println(PinNumber2);
  delay(100);
void expander1Write(byte _data ) {
  Wire.beginTransmission(expander1);
  Wire.send(_data);
  Wire.endTransmission();
byte expander1Read() {
  byte _data;
  Wire.requestFrom(expander1, 1);
  if(Wire.available()) {
    _data = Wire.receive();
  return _data;
void expander2Write(byte _data ) {
  Wire.beginTransmission(expander2);
  Wire.send(_data);
byte expander2Read() {
  byte _data;
  Wire.requestFrom(expander2, 1);
  return _data;
Old Feb 20, 2013, 12:01 PM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Neat. I am using two MCP23017 chips to expnad the ports on the Pi. It's the board Massey posted. Using a pair gets you 32 pins
DATA SHEET for the PCF8574 I/O port expander
Pete
blutoh is offline Find More Posts by blutoh
Old Feb 20, 2013, 10:13 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Danny,
Are these PCBs at full size? Or do they have to be resized before using?
Pete
Old Feb 21, 2013, 01:40 AM
Joined Jul 2008
The PCB's are 1:1 exported from my design program. I just checked, photobucket resized them. I've exported them to PDF. I attached it to this post. Hope it works.
Danny
Old Feb 21, 2013, 09:55 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Thanks, Danny,
I can rescale as well, if necessary, using the dimensions at the top of the diagram i think.
Pete
Old Feb 21, 2013, 11:43 AM
Skystream is offline
Find More Posts by Skystream
Joined Dec 2012
Pete
I'm a big fan of the MCP23017 chips. I use them on my Arduino-based MonsterShield halloween prop controller (see http://www.hauntsoft.com) for both input and output.
Skystream is offline Find More Posts by Skystream
Old Feb 21, 2013, 12:54 PM
tweety777 is offline
Find More Posts by tweety777
tweety777's Avatar
Vlaardingen, The Netherlands
Joined Nov 2008
I'm certainly going to need these things, maybe I can make them myself, might well be cheaper.
Greetings Josse
tweety777 is offline Find More Posts by tweety777
Old Feb 21, 2013, 01:59 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Josse,
Here is the data sheet. But Danny has a;rready done the hard work for a PCB using the PCF8574, why re-invent the wheel?
Pete
Old Feb 22, 2013, 05:37 AM
tweety777's Avatar
Joined Nov 2008
Hi Pete,
I meant building them myself using Danny's design.
Greetings Josse
Help! MikroKopter BL Cntrl vs I2c with simon k Nikhilrobologix Multirotor Electronics 3 Jan 22, 2014 05:28 AM
For Sale converter I2C-PWM ecokopter.pl Aircraft - Electric - Multirotor (FS/W) 2 Mar 28, 2013 02:28 PM
Sold Mikrokoper/ MK clone + I2c Converter kanchana Aircraft - Electric - Multirotor (FS/W) 0 Jan 24, 2013 11:47 PM
For Sale 6 18 amp I2C ESCs jihlein Aircraft - Electric - Multirotor (FS/W) 0 Jan 22, 2013 12:59 PM
