Old Feb 19, 2013, 11:03 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
Rockwell X-30
I'm planning on building a Rockwell X-30 plane this spring/summer. I haven't decided on the size yet, probably 4-5' long.
I'm going to get some drawings and cad plans together, hopefully I can make it happen
http://en.m.wikipedia.org/wiki/Rockwell_X-30
Endlesslag is offline Find More Posts by Endlesslag
Old Feb 20, 2013, 06:57 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
mock up
just do you own small mock up first
space 1 is offline Find More Posts by space 1
Old Feb 20, 2013, 12:22 PM
Endlesslag's Avatar
Joined Jan 2011
Yeah, will definitely make a small foamy first to make sure it flies
Old Feb 20, 2013, 08:00 PM
Endlesslag's Avatar
Joined Jan 2011
So the way I see it, a 1/48 scale foam one would be a good starting point, at 3.3ft long and 1.54ft wide, and the final version as a 1/32 scale at 5ft long and 2.3ft wingspan.
Those are definitely some odd proportions, and weight distribution will be critical. Batteries will definitely go waaaayyy up in the nose.
This is an approximate CG
Old Feb 21, 2013, 06:24 AM
space 1 is offline
USA
Joined Apr 2007
doin't forget one in pic you posted has rocket eng & lots gyro's. some HS had one in foam with EDF
Build Log Rockwell X-30 Endlesslag Balsa Builders 4 Feb 20, 2013 12:22 PM
For Sale Bridi Rockwell Shrike Commander 79" $325 kingwoodbarney Aircraft - Electric - Airplanes (FS/W) 5 Jan 15, 2013 12:24 AM
Sold $30 Shipped! -- 4-in-1 Speed Control Quad HOBBYWING Skywalker Quattro 20A x 4 Cobra68 Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2013 11:07 PM
Discussion Rockwell X-31 saber bat or Northrop X-29 torque roll Scratchbuilt EDFs 16 Dec 08, 2011 04:49 PM
For Sale 30 pieces Depron Foam 2mm x 30" x 24" ($65 shipped) Justin Stuart Aircraft - General - Miscellaneous (FS/W) 1 Oct 20, 2011 09:08 PM
