Old Feb 19, 2013, 06:33 PM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Question
Monokote/Ultracote on carbon fiber
I apologize if this has been covered, and it probably has before, but I've searched using forum tools and google with the site: filter and I can't find a definitive answer. Will Monokote or Ultracote bond to carbon fiber? I have a Guillows kit 502, the Butcher Bird, that I'd like to build into an ultra-micro using AS3X 2s brushless brick. It's a tail heavy bird due to its design and I am hoping to save weight by using carbon fiber stringers in the back of the fuse and thinning the formers, probably in the wings as well, instead of the wood. If I decide to cover with mono or ultra, will the glue activate and bond to the pultruded carbon rods well?
Again, sorry if this has been covered (no pun intended) before.... I did my best at searching out the answer.
~Ben
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 20, 2013, 11:10 PM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Nobody, huh?
Old Feb 20, 2013, 11:47 PM
wizard of odd is offline
Find More Posts by wizard of odd
wizard of odd's Avatar
Australia, VIC, Sale
Joined Apr 2011
I doubt you will actually save much weight by using carbon fibre stringers. You will gain a considerable amount of structural strength though. Maybe measure both before you start, see if it's worth the hassle? As to the formers- consider replacing them with lighter Balsa.
Using covering film should not present any problems- but take care not to warp the structure- especially the wings- when shrinking it down. I'd stay away from Monokote for that reason and use the Parklite version of Ultracoat in stead.
As noted, this bird has a short beak, so get the brick and battery as far forward as possible. Use some of the carbon fibre for the rudder/elevator pushrods.
wizard of odd is offline Find More Posts by wizard of odd
Old Feb 21, 2013, 09:00 AM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Thanks for the tips! I plan on mounting an E-Flite BL180 up front, hopefully with a hatch on top of the cowling I can fit a 180 / 240 2s cell in just behind that, and the brick immediately behind that. I'm also considering replacing the tail feathers with 2 or 3 mm depron, and may even make every other former behind the cockpit from depron.
Old Feb 21, 2013, 09:12 AM
Joined Apr 2011
Now there's nice idea, just take care when using the covering iron over the Depron formers. Anyway, there's a thread "sticky" on Guillows conversions in the scale section, which will probably offer some great tips.
http://www.rcgroups.com/forums/showthread.php?t=827861
Old Feb 21, 2013, 09:21 AM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Awesome.... great link, appreciate that!
~Ben
Old Dec 14, 2014, 11:38 PM
Sabin is online now
Find More Posts by Sabin
Every pilot has his crash
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
Bhoov... have I got news for you. I hit up google to search for the very thing you asked, to see if anyone has thought of it. Before that, I was reading up on composites and that BMW came up with covering composites with thermoplastics.
So my mind started working and I came up with the idea to try covering some cf with monokote. So, I gave it a shot.
I now have both my horizontal and vertical surfaces of my 450 heli covered with monokote and it seems to be holding up well.
Here's how I did it. I first cleaned the absolute snot out of the pieces and then I blocksanded both with 120 grit sandpaper to give the adhesive more bite. Then I rinsed the pieces off and cleaned them with isopropyl to get rid of any oils. That's when I laid down the monokote, and kept the heat on until it was completely bonded.
Turned out quite well.
Sabin is online now Find More Posts by Sabin
Old Dec 15, 2014, 01:55 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
You'll never know if you're going in the right direction or not with such modifications. The ONLY way to tell is to buy and use a sensitive digital scale. Compare the weight of the carbon rods to balsa stringers. Also watch that you're comparing apples to apples. A thin carbon rod is going to be far stronger in tension than the balsa you replace. But is that thin rod that weighs the same as the balsa also as STIFF as the balsa? Are you making a structure from a potentially stronger material that ends up shrinking inwards under the tension of the covering to give you a model with a really horrible "starved dog" look? I'd suggest that by the time you get a carbon pultruded rod down to the same weight as a suitable balsa stringer that the rods might well be more flexible and be drawn in by the shrinkage forces more than the balsa.
And let's not forget that in some kits Guillows has a reputation for supplying wood that likely isn't capable of floating. Tossing their sawn sheet of strip wood and slicing your own strip from quality sheet stock can save a bundle of weight and provide more strength at the same time.
You'll also be very amazed at how light and strong a minimal balsa structure can be if done right. And sadly Guillows does not do it right. Their balsa structures are intended more for display models than for flying models.
Go onto the scale plans area of http://www.outerzone.co.uk/ and carefully study the free flight scale model plans for ideas on how balsa can be used more appropriately for lighter weight AND more strength all at the same time. Once you appreciate what the better ways are for designing these structures you'll likely never buy another Guillows kit ever again.
BMatthews is offline Find More Posts by BMatthews
Sold UltraCote, Monokote and 21st Century film Mike Fortune Aircraft - General - Miscellaneous (FS/W) 13 Aug 20, 2013 01:10 PM
Found MonoKote or UltraCote JollyPopper200 Aircraft - General - Miscellaneous (FS/W) 0 Jan 26, 2013 12:25 PM
Discussion how to spread a carbon fiber tow into a carbon fiber band ROSS OS Composites Fabrication 11 Jan 10, 2013 05:28 PM
Wanted Small patch of carbon fiber pattern Monokote/Ultracote ajreynolds Aircraft - General - Miscellaneous (FS/W) 0 Aug 21, 2008 11:12 PM
