Old Feb 19, 2013, 04:37 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Tubing - Metric
I do a lot of wood building and would like to use 3 or 4 mm cf rods in the tails of a project. However I can't seem to find any aluminum tubing with the corresponding inside diameter... Suggestions???
schrederman is offline Find More Posts by schrederman
Old Feb 19, 2013, 06:45 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
You can make some composite ones. Do a search in this forum for joiner tubes.
If they are short you can make them this way.
Composite Sleeve Made on a Mandrel (0 min 30 sec)
wyowindworks is offline Find More Posts by wyowindworks
Old Feb 19, 2013, 06:56 PM
T.D. is online now
Find More Posts by T.D.
T.D.'s Avatar
Vancouver, Canada
How much do you need?
Pretty sure I have 3 & 4 mm ID alum and brass tube kicking around, if not there is a metric stocked hobby shop a few blocks away so I could grab some and send them to you.
Tony
T.D. is online now Find More Posts by T.D.
Old Feb 19, 2013, 10:37 PM
Joined Nov 2002
I had considered making my own but it seems that for a 3 or 4 mm rod it would be looser than I want. They need to be reasonably slop free.
TD, I just need a foor or so of preferably 4 mm i.d. tube. Before I go to the trouble of getting you to send it, let me see what I can sourse up... Thanks, all...
JW
Old Feb 21, 2013, 08:39 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
JW
I recently made some 2.5 mm diameter tubes using some of Soller Composites very nice biaxial sleeving. I spiral wound the mandrel with drop sheet plastic cut into strips approx 25 mm wide. The plastic pulls out after removing it from the mandrel. 4 mm diameter would be easy.
I'm a real fan of glass and carbon biaxial sleeving (sock) now!
The same could be done with spiral wound strips of glass, as well as the wrap method Adam describes above.
The plastic release sheet provides a good working clearance with out slop, but still easy to fit and remove the rod.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Feb 21, 2013, 11:00 PM
Just fly it!
Cody, WY
Joined Nov 2007
The ones that I made in the video have a perfect fit. I wax the rod and then dip it in PVA and hang it to dry. You want to use a wax like Part-all Paste #2 so the PVA doesn't bead up. No plastic is used between the mandrel and the layup.
Old Feb 22, 2013, 12:55 AM
Joined Aug 2008
I'm impressed Adam!
I have never tried it with the wax and PVA and no plastic. I'll give it a go next time.
Old Feb 22, 2013, 05:29 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
I tried with a 3mm alu mandrel. Stuck like a b*sturd. Eventually got it off, but needed pliers so I damaged the tube.
Do you polish the mandral to a certain standard? I assumed the PVA would make up for minor problems?
Odysis is offline Find More Posts by Odysis
Old Feb 22, 2013, 09:29 AM
Just fly it!
Cody, WY
Joined Nov 2007
Originally Posted by Jim.Thompson View Post
I'm impressed Adam!
I should say that I've never tried it without plastic for tubes longer than 4 inches.
Old Feb 22, 2013, 07:49 PM
Joined Nov 2002
Thanks, Adam... I have both the Part-All Wax and some PVA... I'll be giving that a try!
Jack
Discussion Metric Steam Throttle Valve and 5/32" Tubing hookpilot Steam Boats 2 Jan 13, 2013 09:39 PM
Metric tubing 4mm and.... CWallace Electric Plane Talk 2 Jan 17, 2003 02:23 PM
Looking for Source for Metric Carbon rod/tube suppliers AeroSports Micro Helis 8 Jan 07, 2003 11:19 PM
?????????? Metric Tubing ?????????? MicroRotors Scratchbuilt Indoor and Micro Models 2 Mar 06, 2002 12:43 PM
?????????? Metric Tubing ?????????? MicroRotors Electric Plane Talk 2 Mar 06, 2002 12:43 AM
