Old Feb 19, 2013, 05:34 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Hot Wire Power - And more questions
What are you guys using for wire-cutter power supplies?
schrederman is offline Find More Posts by schrederman
Old Feb 19, 2013, 10:34 PM
Chris Sutton is offline
Find More Posts by Chris Sutton
Spy's sappin' my thermal!
Chris Sutton's Avatar
Seattle, WA
Joined May 2009
I have two that I use.
One is a Duratrax ICE battery charger. It has a motor break-in mode dating back to the days when you needed to break in brushed motors before using them. It maxes out at 8 volts, by .1 volt increments, and also has a current readout. Not quite enough voltage for bigger bows, though.
The other that I have is a router speed control (http://www.harborfreight.com/router-...rol-43060.html or similar) and a 24V, 6A transformer. It has two drawbacks: I can't turn the voltage down low enough to run my smaller bows, and it's easy to accidently flip it from 'variable' to 'full power' which makes quick work of .016" wire. A lower-voltage transformer would solve both of those, but I got the 24V one dirt cheap.
Were I shopping for a new charger, I'd probably get on of the IChargers from ProgressiveRC (http://www.progressiverc.com/chargers/battery-chargers) and have that double as my foam cutting power supply. They have a foam cutting mode that supplies up to 25V and 10A, which would cover my needs and probably quite a bit more.
Chris Sutton is offline Find More Posts by Chris Sutton
Old Feb 20, 2013, 01:22 AM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
That and an automotive battery charger with a "start" setting.
A10FLYR is offline Find More Posts by A10FLYR
Old Feb 20, 2013, 07:30 AM
ron gijzen is offline
Find More Posts by ron gijzen
ron gijzen's Avatar
Liempde, Netherlands
Joined Jul 2007
I simply use the 12V car battery that I also use for my whinch.
For a 0.3mm NiCr wire you get the correct current when placing the clamps on the wire about 2 feet (50-70cm) apart.
Simple & safe
ron gijzen is offline Find More Posts by ron gijzen
Old Feb 20, 2013, 09:49 AM
MarkRebuck is offline
Find More Posts by MarkRebuck
Joined Oct 2006
For cuts up to two feet, I use an old computer power supply to get my 12V. For cuts shorter than 20", I use an LED dimmer switch http://www.amazon.com/LEDwholesalers...dp/B003L4KKF2/ to drop the power. When I found a setting I liked for a given length of cut, I simply made a line on the dial. I had a multimeter on it at one time, and I think I needed 0.45 watts/inch, but that was with my specific wire/foam combo.
Don't worry too much about your power source. Make it safe, adjustable, and repeatable, and you'll be fine. There are a million different ways to dump power over a wire, and there really isn't much difference between any of them.
MarkRebuck is offline Find More Posts by MarkRebuck
Old Feb 20, 2013, 10:43 AM
David Forbes is online now
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
Cheap and available, works great.
Dave
David Forbes is online now Find More Posts by David Forbes
Old Feb 20, 2013, 11:10 AM
kcaldwel is offline
Find More Posts by kcaldwel
"Where are they?"
kcaldwel's Avatar
Joined Jan 2007
The transformer from a rechargeable drill charging station is usually 18VAC or so, which works well. If you are like me, you've had a few drills die and have left over charging stations. I just take out all the recharging electronics, and connect directly to the transformer outputs.
I have a couple of old ones that put out 12VAC from 9V drills, which is about right for my blocking bows without any adjustment.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Feb 20, 2013, 11:29 AM
Joined Dec 2005
Transformers from halogen lights are usually 12VAC, don't require modification. If you've got a junk box you probably have something that will work
Dave
Old Feb 20, 2013, 02:27 PM
davekra is offline
Find More Posts by davekra
Milwaukee G Mitchell, Wisconsin, United States
Joined Mar 2002
Some newer battery chargers have a foam cutting option. I know my iCharger does.
But I use an Astro 110D charger. Simple current adjust with digital display.
Nobody seems to listen to me on this so if you want more info you'll have to ask.
davekra is offline Find More Posts by davekra
Old Feb 20, 2013, 05:33 PM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
If you wanna get real nuts and have something plug n play:
http://www.mastechpowersupply.com/dc...3a/prod_2.html
I use it on my CNC and it controls the kerf very well. You can set a constant amperage or voltage. Overkill for a bow, but still handy in the long run.
Will
heliwill10 is offline Find More Posts by heliwill10
Old Feb 20, 2013, 11:02 PM
Joined Nov 2002
OK... Thanks for the replies... I have a 12VDC - 10A power supply that I use with my battery charger at home. I think that will work. I made a foam cutter many years ago that would cut tapers. I was cutting up tp 48" in white foam with .020 safety wire.... but only used it once. With the blue and pink foam, what's the max recommended length of panels I can cut... and stay pretty accurate. My intention is to bag my male wing plugs and make female molds from them, for a 166" span glider.
Thanks, again...
Darth Composite Noob... AKA Jack
Old Feb 21, 2013, 12:44 AM
Cory is offline
Find More Posts by Cory
I DS slower than I build!
Cory's Avatar
Idaho Falls
Joined Jul 2006
I built one of these: http://www.charlesriverrc.org/articl...amcutterps.htm It works great.
Cory is offline Find More Posts by Cory
Old Feb 21, 2013, 07:48 AM
Lawrence B is offline
Find More Posts by Lawrence B
Live and let Fly !
Lawrence B's Avatar
Mill Hill - London
Joined Aug 2009
Built a modified version of the schematic shown. main diffrerances;
higher a.c. voltage to drive enough amps to cut 'blue' foam
addition of switchable ballast resitors for long / short bow operations.
it works just fine
LB
Lawrence B is offline Find More Posts by Lawrence B
Old Feb 21, 2013, 12:22 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Thanks, again...
At 33" with a .033 wire I use 1.95amps and my voltage is around 27-31 volts. I can't cut much more than that....
Will
Old Feb 21, 2013, 02:40 PM
Cory is offline
Cory's Avatar
Idaho Falls
Joined Jul 2006
it works just fine
LB
But don't use nicrome wire.
Discussion Powering hot wire? mongdex Foamies (Scratchbuilt) 4 Jan 29, 2013 02:38 AM
Help! Hot wire and Electrocution! hasselblad7 Composites Fabrication 10 Jan 14, 2013 07:44 AM
Discussion Simple Hot Wire Cutter??? joker24458 Foamies (Scratchbuilt) 20 Jan 11, 2013 01:16 AM
Question Hot wire cutter question ed4353 Composites Fabrication 6 Jan 02, 2013 07:57 PM
