The question for me is, can there be a solution that uses two to four smaller speakers that are not necessarily as loud but can be positioned better for more equal sound projection at a variety of aircraft attitudes based on the remote position of the pilot and observers. (This may be what you are talking about in regard to these 3" speakers in fact!) For my current project, I know my 4" speaker set is the best solution for a loud system. I should have some great sound on the ground and a close fly by at low level After all, the speaker points down, so on the ground, the reflected sound will be easy to hear. On just about any fly by, the reflected sound and such will still reach us well. But in flight, I expect the speaker will be muffled or even inaudible in attitudes where the top of the model plan form is viable such as in a large loop or inverted flight from above and at a certain distance away. In most cases the model sounds will be "hear-able" but there are several times I'm sure it just won't be very clear what the noise coming from the model is except some airframe, propeller, some speakers sounds and speed controller noise. Now if I had four smaller speakers installed in my current "mid size" model in well planned locations, the advantage could be many. If I had a large enough model the 4" speakers would be great but most of my models are in the 65 - 100 inch wing span regime - 2 speakers in the lager models and one in the smaller ones. But, I could have lighter speakers and more evenly distribute the load around the airframe with 4 small and light speakers (like a setup of 2" to 3" speakers), and each speaker could be hidden / camouflaged better. Also I could have speakers that could be heard in just about any attitude. While the total sound in ideal locations may not be as loud, I'd expect the overall "ups and downs" of audible sounds may in fact be more consistent throughout a large variety of aircraft maneuvering and give the impression of realism in a variety of aircraft attitudes. This is just my thinking, and I do not claim to have nearly as much of an insight as many of you guys here as I really have only been dabbling with this sound stuff for the last season. For those reasons I'm still really interested in what sort of speakers that may be recommend us to try if we wanted to try two to four smaller speakers. The advantages of David's sound board are many on setup. I still think we have a very powerful setup menu and what we can do with these boards as far as customization and versatility are incredible and I'd love to have the chance to use a larger variety of speakers but I am really out of my league when it comes to speakers. |
Latest blog entry: The Gas Turbine Engine (with images)
So the 4" speakers are 90dB/1W/1m and weigh 5.7 ounces...
The 2.5" speakers are 84dB/1W/1m and weigh 7.3 ounces. How much of a difference is 84db vs 90db in reality? I suppose one would have to hear it in a model to really know. The other question is how much do most people really push their speakers to the limit rating anyway... In other words if running a 4" speaker on a 4s setup is not getting it close to the maximum output, then maybe it's a mute point. However, I am concerned about the weight of the 2.5" speakers. There have to be 2.5" class speakers that are lighter, right? Quality may be a question but I'm just free thinking here. A question I ponder would be if a lighter, smaller set of 2.5" class speakers mounted in a greater variety of locations and directionally and strategically mounted - could that in many ways make up for and be superior in a variety of conditions to an alternative arrangement featuring fewer speakers having the advantage of specific loudness but only in one or two directions? |
http://www.rcgroups.com/forums/showp...3&postcount=23 |
Canada, ON, Ottawa
Joined Jan 2006
Yes there are smaller, lighter, speakers e.g. the Visaton BF45 which Thomas Benedini sells. It is 2", can handle 4Watts, weighs only 32 grams, or 1.2oz BUT has a sensitivity of only 79dB/1W/1m. This is a huge difference from the 90dB of the R10S speakers. Now by all means try an array of these speakers - we can order them in from our distributors as a special order for you if you like. Perhaps make a long test box about the same size as your fuselage out of plywood and distribute the speakers around it and just try it out for loudness. If anyone is wondering why I constantly refer to Visaton speakers - yes there are many speaker manufacturers out there but : 1) We have established a good business relationship with Visaton's Canadian distributor and have a credit account with them. 2) We have been in this business for about 7 years now and continually search for better speakers - defining "better" as smaller, lighter, more sensitive, can handle more output power and/or cost less. The results of these searches always come down in favour of the Visaton series as being able to provide the best all-round compromise between these and other conflicting requirements. 3) We even enlisted the help of the sales engineers at our loudspeaker distributor since they carry many different brands and they couldn't come up with another brand that suits our needs better either. 4) Thomas Benedini in Germany also uses Visaton speakers and a few years ago I discussed speaker choices with him and we both came to the same conclusion that, in general, the Visaton range was the best for the job, given all those conflicting requirements. Regards, David |
Nice website David,
Very good idea here with this thread. Wouldn't it be nice if speaker manufacturers stamped out speaker frames in aluminum instead of steel? Would be good in outdoor marine applications for corrosion and all types of models that go outdoors. Some weight savings also. The magnets could still be riveted in place. **Neons** Bob |
Canada, ON, Ottawa
Joined Jan 2006
I have been wanting to add some sound 'boxes' to my speakers for a while. (basically since I installed them)
I have done some minor research on the methods people use and discounted most as practical due to the location of my speakers and available access point. (a door in the side of the plane ~ 2" x 4") I have recently decided to cut into the fuse and change the way they are mounted. This provides the opportunity to box them and enhance my sound. What I would like to do is the 'pvc pipe method'. Assuming people reading this know what I am talking about, has anyone already done the math on the best thickness pipe and how long it should be for each speaker using this system? My setup is the standard shockwave pcb running on 6s w/2 4" Visatons as provided by MSI. |
Canada, ON, Ottawa
Joined Jan 2006
Sound Enclosures
In response to Eddie P on post #34, the plastic cylinder (part of a beef jerky maker from Walmart...though I don't make beef jerky) is used to add additional volume to the sound box surrounding the engine.
Your Corsair installation looks awesome....I hope we can hear and see it fly in a future video! The goal for the Sopwith was to use a heavy speaker to replace the 16 oz lead ballast that came with plane, along with providing a maximum RMS speaker value for the SFX6 soundcard. It's using a 3S battery along with one 4 ohm speaker...which is acceptable per David. I would love to try Monacor SPH speakers in a project...but the price has held me back. I apologize for the bad video link posted previously....I hope that this one works. http://www.rcgroups.com/forums/showthread.php?t=1836745 As the thread is currently talking about sound boxes, attached are a few photos from a Hangar 9 Fokker setup. For me, as a newbie, I just figured to make any enclosures as large as the available space would allow. Many thanks to all those that have posted similar projects and past experiences with speakers on other threads and sites (Wattflyer, RC Universe, etc.) |
Canada, ON, Ottawa
Joined Jan 2006
Hi, all. Since we are currently talking about small speakers, I thought I'd put up a few things that determine speaker performance.
1) Loudspeaker efficiency - i.e. (power out / power in) is only about 1%. That means if you put in 40Watts of electrical input power you only get 0.4Watts of sound power output. The remaining 39.6Watts gets dissipated as heat!! 2) This heat has to be dissipated somehow. The primary heatsink of a speaker is its magnet. Therefore in order to handle high power you have to have a large heavy magnet. This is why small speakers can't take much power. 3) The amount of "Power" in a sound wave depends not only on its pressure (SPL) but also on the rate of change of that pressure i.e. its frequency. So for a given speaker cone displacement, the lower the frequency, the quieter the sound. This is made up for in woofers my moving a larger quantity of air. 4) This is why woofers have a very large cone and tweeters have a very small cone to get the same amount of sound "power" out. So not only do small speakers have a low power handling capacity, but they also have a very poor low frequency response. For some planes e.g. jets with a high proportion of H.F. sound that is OK, but not for a large radial piston engine which has a large amount of L.F. energy. |
Model Sounds aircraft
David,
I recall reading in one of your newsletters or somewhere previously on your site that you were working on an aircraft to help showcase your product(s).....that you could take to shows, fly-ins, etc. Was it a P-51? If so, is that complete, or a work in progress? It would be great to see it....or even see a build thread on it...possibly in this thread? |
Canada, ON, Ottawa
Joined Jan 2006
| Thread Tools | |
| Sold Model Sound Inc. Shockwave Sound System NIB $200 | tmulder | Aircraft - Electric - Miscellaneous (FS/W) | 1 | Apr 13, 2013 02:14 PM |
| Discussion The official sudafed rant thread | billyd60 | Life, The Universe, and Politics | 48 | Jan 08, 2013 11:20 PM |
| Discussion Model Sounds Inc. New SFX7.0 sound module | DavidHarrison | Product Announcements | 0 | Jun 23, 2012 05:33 PM |
| Contest OFFICIAL RCGroups GoPro contest: Voting and Random Givaway Thread | Kmart | Video Piloting (FPV/RPV) | 177 | Nov 02, 2010 01:54 AM |
| Discussion Official RCGroups Coverage Provide By Xtreme Power Systems | JimDrew | Electric Flight Expo | 20 | Mar 17, 2009 04:38 PM |
