Old Feb 19, 2013, 10:16 AM
marctt01 is offline
Find More Posts by marctt01
Joined Feb 2013
Help!
Help!
Hi all
I need a bit of help with my tt01.
I know its one of the most basic chassis and very little can be done to it, but the little can make a huge improvement to the way the car drives and handles and be a great competitor.
I currently have:
Alu prop shaft and cups
CVA oil dampers
TT01E A and D parts
Speed gears 55 and 58
Pinion 23 and 22
Full ball bearings
9T ezrun brushless system
I wanted to know A) what would be the best gear ratio to run with my brushless system as I would like to race around a track ( and again I know its not a race chassis but just because) and B) how can I lower the ride height of the chassis
Any help will be great guys
Sent from my BlackBerry 9780 using Tapatalk
marctt01 is offline Find More Posts by marctt01
Old Feb 19, 2013, 02:40 PM
wparsons is online now
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Less pre-load spacers on the springs (or softer springs if you're already running without pre-load spacers) will lower it. As for ratio, not sure. I would base it on motor temp and how it runs.
wparsons is online now Find More Posts by wparsons
Old Feb 19, 2013, 03:05 PM
marctt01 is offline
Joined Feb 2013
Thanks WParsons
I will try that with the suspension but I also read that by adding additional o-rings on the damper shaft it will lower the chassis
Old Feb 19, 2013, 04:01 PM
cenracer1 is offline
Find More Posts by cenracer1
Hackettstown, New Jersey
Joined Feb 2008
How low are you trying to make it. Unless you stiffen the shock springs the car will bottom out with it being really low and that will really hurt the handling. I went thru this with my TT01's and my HPI's.. Too low is just as bad if not worse than too high. You can also try better tires.. I personally love foams even outdoors but others have had great success with rubber tires with traction sauce and or heat..
cenracer1 is offline Find More Posts by cenracer1
Old Feb 20, 2013, 10:08 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Originally Posted by marctt01 View Post
Thanks WParsons
You can do that, but that requires rebuilding the shocks any time you want to adjust ride height, so you'll want to measure twice and build once
If all you want is for the car to look lower, just lower the body on the body mounts.
Idea Care To Help? Looking At Ways To Promote Model Building and Helping Others Murocflyer Balsa Builders 35 Oct 16, 2014 02:57 PM
Help! Help me help my wife! Rasterize Life, The Universe, and Politics 66 Mar 19, 2013 10:26 PM
Discussion Help help help!!!!!!! rc8b Off-road Cars 1 Feb 13, 2013 07:17 PM
Discussion Help!!!! any help with TT FM-1e would be awesome JUGGIN Motorcycles 14 Jan 30, 2013 03:14 PM
