Old Feb 19, 2013, 03:26 PM
philthyy is online now
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
It doesn't sound reckless to me. It sounds like you followed the regular, consistent advice of those who have been FPV'ing for years.
philthyy is online now Find More Posts by philthyy
Old Feb 19, 2013, 04:41 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
I think your fail was not testing the autopilot enough. You have to make sure the autopilot is completely able to take the airplane back to range. This include keeping altitude or even gaining altitude while doing so.
Just doing one test of the RTH mode is not enough to go venture on testing the limits of your setup.
Elcheapo is offline Find More Posts by Elcheapo
Old Feb 19, 2013, 04:50 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Keep in mind though, that even with an autopilot that has set its home somewhere else,
a ground recording would have given him some idea where it was flying off to by itself,
and if the OSD shows you where it thinks home is, all the better.
I'll take a ground recording over an autopilot almost every time.
And to answer an earlier question, you definitely can find a plane by driving to
the area, and looking for the video signal, especially if there's no expectation
that it crashed vertically but just floated to the ground. I've used body blocking
and a couple different Rx antennas (high gain, omni, and none) to find lost FPV
planes a few times. If autopilot will have run the battery dead trying to
stay up, your window of opportunity is smaller though.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 19, 2013, 04:58 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
^^ Absolutely... i have found that recorded flights often yield the best results when recovering downed aircraft miles away.
blueprint is offline Find More Posts by blueprint
Old Feb 19, 2013, 05:02 PM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
Sorry to hear. I have been RC for about 30 years on and off, and it is too cold to fly FPV for the first time. Built a Penguin with all the bells and whistles EXCEPT: UHF. My reasoning is that I don't want to tempt myself into going much beyond LOS. I have a frsky setup w/ cp antennas and hope to have a completely solid lock always within a mile or less. The thought of losing it a couple miles out, or in terrain I can't handle, scares me. I might be able to afford it once, but certainly not twice.
Here's hoping you find your plane!
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Feb 19, 2013, 07:33 PM
harfordhawk is offline
Find More Posts by harfordhawk
harfordhawk's Avatar
United States, NC, Wilmington
Joined Oct 2010
I feel your pain
I lost my Skywalker and it was gone for 3 months in a Maryland cornfield.. GoPro(naked), all sorts of other stuff.. I got it back when some farmers picked the corn. So don't give up hope.. Many of those electronics will survive.. ( My Gopro still works!)
Sure you could've done things differently, but you didn't. We are all learning.
I wonder if you had a separate BEC powering the APM, and I wonder if it was sufficient. It sounds like a brownout to me, and I have had them. The APM will essentially reboot in flight. This is a terrible thing to happen at 2 miles away.. Almost unrecoverable in my opinion..
Also, did you have any failsafes set? The APM has some and I don't know about DL. Is it possible your DL failed?
However, If you had telemetry radios feeding data back, you have yet another piece of very useful info concerning location. If the APM were to reboot, chances are telemetry would come back and you would see real time on your laptop ( that you brought to the field), where your plane was.
I can't offer any "finding the plane" guidance, I looked for mine for 3 months.. But I made friends with all the farmers in the area and kept hoping.. I suspect it went down pretty close to where you lost signal.
harfordhawk is offline Find More Posts by harfordhawk
Old Feb 20, 2013, 03:52 AM
swartzracing is offline
Find More Posts by swartzracing
Aerial Operator
United States, CA, Sacramento
Joined Feb 2012
I'm sorry to hear about your penguin! I have a feeling though that you will find it! I was flying my quad FPV one evening and one of my props broke and the quad went haywire and flew away. I lost video and RC signal, I wasn't recording on at my ground station because I wasn't planning on going more then a 100 yards or so. When the I lost it I literally became sick to my stomach and tried to remember what the last things I saw were before the video dropped. I got into my truck and drove around with the Video RX and monitor to see if it picked up anything other then a black screen. There was an area that was about a .5 mile away that the video changed a bit, not even a picture but there was a change.
After 2 days of searching I went to the area that I didnt think the quad would be, but that was the area I had some change in video, and I literally walked up on to it. I was like a kid on Christmas, I can't tell you how excited I was.
So don't give up, Use google maps if necessary.
Now I use RTH, DVR recording OSD, and a GPS tracker on my Penguin just in case. I know it might sound overboard, but when you think the time, effort, and money you invest in a bird it is totally worth it. No matter what you do electronics arent 100% perfect, but they're steps to be taken in order to protect your investment.
I really hope you find your Penguin, and I know you wont make the same mistake again.
Cheers,
swartzracing is offline Find More Posts by swartzracing
Old Feb 20, 2013, 04:02 AM
n1lul is offline
Find More Posts by n1lul
Sourthern Maryland
Joined Dec 2002
My other money sucking hobby is high powered rocktery. Needless to say we have come up a variety of methods to recover after high flights.
I have used both 70cm trackers and GPS. My favorite is the Big Red Bee GPS that sends a APRS data stream on the 70 cm band (programable frequencies). It is nice to able to just walk right to your rocket that landed a couple of miles from the launch point. The battery lasts a long time. I never fly without it.
http://www.bigredbee.com/BeeLineGPS.htm
n1lul is offline Find More Posts by n1lul
Old Feb 20, 2013, 04:49 AM
999vertigo is offline
Find More Posts by 999vertigo
Closed Account
Joined Aug 2011
deleted
999vertigo is offline Find More Posts by 999vertigo
Old Feb 20, 2013, 06:51 AM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
Originally Posted by billyd60 View Post
Which osd did you have? All RTH autopilots I know of require extensive setups and careful calibration to work with a given aircraft. Sorry I know the horse it out of the barn already but it is what it is.
Alot of us have lost planes, and after that we either quit or get more diligent. I recommend a beacon such as this for future long range flights:
http://www.com-spec.com/rcplane/index.html
Also extensively test RTH LOS before attempting to try it long range.
+1 I have same tracking device..
Guy in our club has Rx and also someone else in city has Rx..
Put ad in local paper..
ror1 is offline Find More Posts by ror1
Old Feb 20, 2013, 08:47 AM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
a true RTH system is the RUBY from www.uthere.com :-)
rclab1 is offline Find More Posts by rclab1
Old Feb 20, 2013, 09:50 AM
Jaynen is offline
Find More Posts by Jaynen
United States, CA, Oceanside
Joined Jan 2013
Which still won't work right unless you wait for it to properly initialize the gps and set home right?
Jaynen is offline Find More Posts by Jaynen
Old Feb 20, 2013, 09:57 AM
peter.braswell is offline
Find More Posts by peter.braswell
peter.braswell's Avatar
United States, VA, Chesterfield
Joined Apr 2008
First, thanks all for contributing and giving careful thought to my dilemma. I really appreciate the feedback and discussion. As of today, still no Penguin. I'm still optimistic though, it's only been a couple of days.
With regard to Ruby, I own one also and it's currently in my ZII. Great little auto pilot and I can't say anything bad about it. It did take a little work to get dialed in (don't they all?). The downside is that it is a closed, proprietary system and (at least at this point) the user has absolutely no control over the configuration of the unit. The upside though is that Jim Hall is absolutely wonderful to work with and spares not effort in making customers happy.
The Ruby has a calibration / initialization routine that the pilot executes prior to flying. At the end of the calibration routine (less than 30 seconds) the pilot gets a clear indication whether things are configured and ready to go or not. Jim does this by either nodding the elevator up and down (think nodding your head 'yes') or by wagging the rudder (think 'no'). I thought this was a clever and clear way of denoting the status of the system.
Of course the APM does not have this feature.
-Peter
peter.braswell is offline Find More Posts by peter.braswell
Old Feb 20, 2013, 10:13 AM
Pen is offline
Pen
Find More Posts by Pen
Pen
FPWhat?
Pen's Avatar
United States, AL, Huntsville
Joined Sep 2008
I lost a plane over 5 miles out. I was recording the flight so had the last coordinates. I searched a few hours on foot in a hay field and could not find it. My friend took his plane and flew the area very thoroughly. I went home to review the video and found it about 1 minute into the first video. Went back and walked right to it. It was pretty close to the last coordinates.
I felt terrible so know how you are feeling. The recording was definately a life saver. Those super long flights have lost their appeal to me now. I have more fun proximity style flying within a mile now.
I'm also wondering what the RTH ratio is for causing a lost plane vs saving a plane. I bet it's not too good.
Pen is offline Find More Posts by Pen
Old Feb 20, 2013, 10:28 AM
Joined Apr 2008
This question has come up several times in this discussion, so I figured it would be a good poll question. Take the survey here:
http://www.rcgroups.com/forums/showthread.php?t=1836049
-Peter
Discussion What plane next? leeno123 Parkflyers 5 Feb 21, 2013 05:12 AM
Discussion I've got 35+ planes, what's my next one rcalldaylong Electric Plane Talk 35 Feb 18, 2013 07:59 PM
Discussion Lost my HZ Super Cub, so what plane next? DeepBlueGray Beginner Training Area (Aircraft-Electric) 38 Aug 02, 2012 05:42 PM
Discussion lost direction. what next?? grayzeee Electric Sailplanes 23 Oct 14, 2008 09:59 PM
Devastor lost what next FullaFoam Foamies (Kits) 3 May 30, 2004 01:21 AM
