Old Feb 21, 2013, 11:43 AM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
I use one of these on one plane, selectable output voltage.
http://www.troybuiltmodels.com/items/WRCIBEFV2.1.html
I also have one of these for the 6.6v LiFe battery, regulated to 6v.
http://www.valleyviewrc.com/estore/e...-switches.html
Regulated for single ignition at bottom of the page, selectable output voltage, but more money.
https://www.smart-fly.com/Products/I...n/ignition.htm
600Bob is offline Find More Posts by 600Bob
Old Feb 24, 2013, 02:41 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
The DLE 20cc has a very short throttle throw, and I had a lot of trouble getting the servo throw right. Guys at the club said to remove the idle screw, and set this with the servo range. That worked. But the throttle throw was so small that I had trouble adjusting the servo, and the servo (40g) was so powerful that it bent the pushrod all out of shape. I don't like the DLE throttle setup.
Also, the choke has such a hard movement, that I couldn't get any 40g servo to work it. I ended up putting a manual pushrod inside the body....
Although I have seen throttle servos installed right behind the firewall, people told me that this close to the ignition system would cause electric interference, and this would badly affect the throttle control. So I moved my throttle servo way back behind the gas tank.
wuest3141 is offline Find More Posts by wuest3141
Old Feb 24, 2013, 02:47 PM
Tucson
Joined Nov 2009
By the way, the RCGF throttle setup works very smoothly, and for that reason alone, I will probably like the RCGF 20cc gas engine better than the DLE. Even though it requires a lot longer break in period, because it is machined from harder stock.
I think that the RCGF choke will still have to be a manual pushrod.
Old Feb 24, 2013, 07:00 PM
ace4rc is offline
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I would like to add my opinions. On the throttle and choke arms being too short here is a good replacement, http://www.troybuiltmodels.com/items/TBMCARBARMSL.html, I make my own. As for the choke being to hard for a servo, one could remove the position ball. And as for anything being to close to the engine, bah humbug, all of my gear is usually withing six inches of the engine. That would include the battery, reciever, throttle and choke servo, ign kill, smoke pump, etc.etc.etc.The biggest RF cause is metal to metal, a steel clevis on the steel throttle arm for example, elsewise I have never seen or had any interference.
ace4rc is offline Find More Posts by ace4rc
Old Feb 27, 2013, 11:25 AM
gagallagher044 is offline
Find More Posts by gagallagher044
Maine
Joined Jul 2009
I fly a GP giant big stick with a 400cc on it, and a GP revolver 70 with a DLE 20 on it. I am going to be using one 2300 A123 pack for my rx and my ign. one battery, no hassle. I had been using nimh, but that is old technology.
Here is a link to my throttle setup and choke setup on my revolver I too had probs with it, so here is what I came up with. seems to work nicley.
http://www.rcgroups.com/forums/showt...1836362&page=2
gagallagher044 is offline Find More Posts by gagallagher044
Question Throttle cuts out when Servos are applied LostintheSauce Power Systems 16 Feb 15, 2013 04:34 PM
Question servo arm position when installing flaps. to maximize travel TheSelf Electric Plane Talk 41 Feb 07, 2013 11:40 AM
Discussion Throttle servos frying - cause unknown grosbeak Fuel Plane Talk 48 Jan 26, 2013 11:23 AM
Sold HPI Baja 5b throttle servo , DS1313 Hi Performance Digital Throttle Servo ronzer Cars - Trucks and Parts (FS/W) 0 Jan 16, 2013 09:32 PM
Sold Acacia F3F With Wing Bags and Servos Already Installed...Excellent rhampton Aircraft - Sailplanes (FS/W) 3 Jan 06, 2013 06:59 PM
