Old Feb 19, 2013, 06:05 AM
jeka616 is offline
Find More Posts by jeka616
Joined Feb 2013
Throttle servo installation
Good day all
Moved to gasoline engine. Got DLE 20cc, on EDGE 540T. Did my first flight couple days ago. Considerin that I'm a heli pilot, and was flying only trainer TT40 plane, it was riski transition. But hey, managed well..
one thing observed, is throttle response. I got flexible pushrod to engine. without tube, as carb has spring to close the throttle. However, does not perform good.
Also, I installed the servo about 30cm away from engine. As I used to read that on gas planes, need to install servo far away. How true is it? What about the helis then? Gas helis has all electronics right next to the engine.
I'm planning to move servo forward, and have METAL pushrod. Any concerns?
jeka616 is offline Find More Posts by jeka616
Old Feb 19, 2013, 06:49 AM
ace4rc is online now
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Most of my planes the servo is within 6" of the throttle. As for the linkage, pushrods are good as long ao you use a plastic link, not metal to metal. On my carbs I use the ball links as in the pic, either 2-56 or 4-40 works well. With the 2.4 radios and equipment of today I don't worry about where I place any of my electronics. Like you stated all electronics are well within the 6" perimeter on a heli.
ace4rc is online now Find More Posts by ace4rc
Old Feb 19, 2013, 07:02 AM
jeka616 is offline
Joined Feb 2013
Interesting fact...I thought the metal pushrod acts like a magnetic transponder, so high voltage can jump on wire and transfer to THR servo, which at the end can cause interference with radio.
I've posted here recently moving to 2.4 system. I still have old faithful Futaba 9cap, 72mhz pcm. Worked good for me in the past. Nowdays people are worried about 72's, and all are pushed to have 2.4. IMHO, I think this is just marketing. And only downside of 72 is 2 people flying on same channel, resulting in shootdown. I you check flyzone, for participants, it is not a problem.
So you also don't recommend to move closer than 6"?
Old Feb 19, 2013, 09:26 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
Metal on metal is thought to create "whte noise," a form of interference. Most throttle arms now days are plastic or non-metallic in nature. I don't think distance has anything to do with it except for maybe weight and balance purposes where you want to move the weight of the servo aft or near the center of gravity. Do not worry about high voltage jumping on anything. Your spark ignition should be sheilded and grouded and that is the source of high voltage. It is said that using 2.4 Gig systems negate the effects of ingnition noise, don't know about that.
Chip01 is offline Find More Posts by Chip01
Old Feb 20, 2013, 09:48 AM
jeka616 is offline
Joined Feb 2013
You are right, I checked the wire isolation, it is connected to negative. This proves my theory about the helicopters.
Other question, is about the spring on carburetor butterfly. I got DLE 20cc, which has a spring which keeps the butterfly closed. Some people suggest removing the spring, as the servo constantly has to fight the force. I put standart Futaba S3004 servo for that job, and it seems working ok, no buzzing. What is peoples opinion on the spring and the type of the servo to be used ?
Old Feb 20, 2013, 10:19 AM
FloridaFlyBob is offline
Find More Posts by FloridaFlyBob
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
I unhooked the spring from the arm. I've been told to use metal gear servos in gassers because of the vibration. I'm sure it's strong enough, it's a matter of will it hold up.
FloridaFlyBob is offline Find More Posts by FloridaFlyBob
Old Feb 20, 2013, 10:38 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
I remove the spring and idle screw from botth my 20cc and 50cc, and use standerd futaba servo, as I fig there really is no strain on the servo!
I am relitivaly new ta this, but they both seem to work fine! and I am running 2.4 on my 50cc plane and 72mhz on my 20cc plane!
whiskykid is offline Find More Posts by whiskykid
Old Feb 20, 2013, 11:48 AM
jeka616 is offline
Joined Feb 2013
Removed idle screw? Can you describe more. Did you cap it with blind end screw? Or just left open to atmosphere?
Are there any electronic gurus here? I've built myself linear regulator, BEC. based on 3x LM7806.
they get hot without heatsink. So may add one. Question: is there anyone using BEC here? Which commercial BECs are they? Do they get hot? I guess most of them are linear. So wonder how hot they become after flight (if not are outside the plane, so get cooled)
Old Feb 20, 2013, 11:49 AM
jeka616 is offline
Joined Feb 2013
here it is
Old Feb 20, 2013, 12:19 PM
jjkupinski is online now
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
IDLE SCREW. What the gentleman was referring to was the idle speed screw, not the idle mixture screw.
jjkupinski is online now Find More Posts by jjkupinski
Old Feb 20, 2013, 12:23 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
[QUOTE=jeka616;24194815]Removed idle screw? Can you describe more. Did you cap it with blind end screw? Or just left open to atmosphere?
not the "low speed mixture screw" "the idle screw" the screw on the outside of the carb, that sets the low speed idle! with a servo you set the idle with trim! that way you can shut the engine down with the trim on the radio!
Old Feb 20, 2013, 12:39 PM
jeka616 is offline
Joined Feb 2013
Ok got you now. mixed the idle screw with the idle mixture screw.
I tried to shut off the engine with butterfly fully closed, but it kept spinning at very low RPM, just like with choke closed. so ended up installing kill switch.
Old Feb 20, 2013, 12:40 PM
jeka616 is offline
Joined Feb 2013
any thoughts on BEC?
Old Feb 20, 2013, 12:57 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
hopefully someone else can help ya out with the BEC, as I just use a dedicated 4.8 ni-cad for my ign. that completely seperates the ign. from the radio! and I use a regular switch too turn ign. on and off!
so I can kill my engine with trim, or manualy with switch!
Old Feb 21, 2013, 08:38 AM
Joined Nov 2011
Everything i've read says to use some sort of kill switch from the TX either an opto switch or a servo on the choke. I'm using 2 batteries in my hellcat with a dle20, a nimh 4.6 on the ignition and a life on the RX with a choke servo. My dle20 stops as soon as I close the choke. On my waco with a OS GT33 I'm using the power setup from troybuiltmodels with a regulator and a ibef to the ignition for power and also the killswitch on aux3 on the TX. The regulator has 2 seperate inputs and outputs and I have 2 2800mah lion batteries going to 2 channels on the RX. Here's the link for TBM
http://www.troybuiltmodels.com/items/TBMPOWERSYS3.html
Question Throttle cuts out when Servos are applied LostintheSauce Power Systems 16 Feb 15, 2013 04:34 PM
Question servo arm position when installing flaps. to maximize travel TheSelf Electric Plane Talk 41 Feb 07, 2013 11:40 AM
Discussion Throttle servos frying - cause unknown grosbeak Fuel Plane Talk 48 Jan 26, 2013 11:23 AM
Sold HPI Baja 5b throttle servo , DS1313 Hi Performance Digital Throttle Servo ronzer Cars - Trucks and Parts (FS/W) 0 Jan 16, 2013 09:32 PM
Sold Acacia F3F With Wing Bags and Servos Already Installed...Excellent rhampton Aircraft - Sailplanes (FS/W) 3 Jan 06, 2013 06:59 PM
