Old Feb 19, 2013, 12:10 AM
Barbera_Banker is offline
Find More Posts by Barbera_Banker
Joined Nov 2012
IOM sail winch
Im looking for a mid range sail winch (drum) which wont break my student bank account, so something other than an RMG but with good reliability and performance.
Im currently building my first one metre, a SKA from Brad Gibson, im new to rc sail and havnt even seen a IOM for real yet. That said I need a winch that is fast enough for a newbie when competing with the view that I can upgrade if I get more serious.
Interest in exploring converting a generic heavy duty servo if it wasnt too complicated but it seems it is.
Barbera_Banker is offline Find More Posts by Barbera_Banker
Old Feb 19, 2013, 01:59 AM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
There are some very strong lever arm type servos out there that you might want to consider http://www.cmldistribution.co.uk/cml...tId=0000006203 Your sheeting would be much simpler than with a drum set up and the specifications make it look to have ample torque to handle the conditions, as well as being faster than any drum winch.
martin richards is offline Find More Posts by martin richards
Old Feb 19, 2013, 04:37 AM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
I would always recommend an RMG winch but as you say your funds cannot go that far so I think this is your next best option.
http://www.mxcomponents.com/en/winch...300-winch.html
ToniGe23 is offline Find More Posts by ToniGe23
Old Feb 19, 2013, 04:55 AM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Vigor
http://www.hobbyking.com/hobbyking/s...dProduct=18744
8387mike is offline Find More Posts by 8387mike
Old Feb 19, 2013, 05:30 AM
gp. is offline
gp.
Find More Posts by gp.
gp.
gp
gp.'s Avatar
South Aust.
Joined Aug 2006
I have a Hitec HS785HB in my IOM which is hitting the water for the first time Saturday,if the weather holds out,other members are using or have used this before in their boats.
Have a great day
gp. is offline Find More Posts by gp.
Old Feb 19, 2013, 06:45 AM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
Have a great day
Hey gp, where about's in Sth Aust you sail?
Old Feb 19, 2013, 09:14 AM
ToniGe23 is offline
ToniGe23's Avatar
Joined Jun 2005
Originally Posted by 8387mike View Post
gosh Mike, that's another brand of Eurgle no way would I recommend them.
Old Feb 19, 2013, 12:17 PM
hiljoball is offline
Find More Posts by hiljoball
hiljoball's Avatar
Canada, BC, Strathcona
Joined Jul 2011
As an RMG is out of your budget and you want speed and reliability, then the Hitec 815 arm winch servo is a great way to go. The 815 gives 140 degrees of movement out of the box. It is heavier than most servos (about the same as an RMG) but is strong and robust. It can be bought for $35 to $45. If your budget will go double, then a good digital servo like the HS7955 set to 180 degrees will work well and is much lighter than the 815.
The HS785 drum servo will work, but is too slow for competition use.
John
hiljoball is offline Find More Posts by hiljoball
Old Feb 19, 2013, 12:27 PM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
John
Pardon me, I'm not a full blown sailing geek but I do have an older Kyosho boat and I've been a 1:1 sailor for 40+ years.
I just purchased a HS 785 for use in an RC blimp. How fast is fast enough for competition. My HS goes three turn stop to stop just about as fast as I can move the stick on the transmitter!
Honestly, I'm asking what kind of speed are you looking for?
Majortomski is offline Find More Posts by Majortomski
Old Feb 19, 2013, 12:38 PM
hiljoball's Avatar
Joined Jul 2011
An RMG drum and an arm winch can go full in to full out in about 1 second.
With a fast winch, sail response is instantaneous. With a slow winch, I am always chasing the right setting - overrunning and pulling back.
A fast winch can always be moved slowly (by the stick), but a slow winch is always slow.
Try the 785 as you have one. You can always upgrade to an RMG later -I have a Star 45 and two mounting board, one for the 785 and one for an RMG - it is an easy switch as the internal lines just transfer to the other drum.
Switching between a drum and an arm setup is harder as the internal setup and winch placement may have to change.
John
Old Feb 19, 2013, 01:18 PM
stevo_m is offline
Find More Posts by stevo_m
Joined May 2005
I had a 785 in my iom which I inherited when I bought the bought, I thought nothing of it until the wind blew a little and the main took ages to pull in at the lee ward mark, the other boats raced past me each time as they could haul in a lot quicker.
I change to an RMG and the difference is amazing and I don't lose places anymore at the leeward mark. There is also no way I could flick the boom over on a down wind leg as you would wait for ages for the winch to pull in, with the RMG it flicks so quickly and again gives me an edge.
So yes the 785 is very slow when you are competing get some air in the sails and you'll notice the difference.
Steve
stevo_m is offline Find More Posts by stevo_m
Old Feb 19, 2013, 01:52 PM
Joined Nov 2012
Sail servo
Thanks for all the feedback everyone, it seems there is no real alternative to the RMG. If the HS715 is too slow for competition point blank then there is no point in using it.
For the money would I be better going for a powerful arm winch?
If so how much torque do i need? I understand a drum winch can have less torque as the sheet attachment point on the drum is closer is that correct?
Barbera,
Old Feb 19, 2013, 11:28 PM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
Its a bit hit and miss with them, I've put about 5 into second hand boats and only ever had one stuff up.
They did mention at the start od the thread that they wanted a cheap winch.
Old Feb 20, 2013, 07:37 AM
bigpat is offline
Find More Posts by bigpat
Love RC Yachts!!!
Australia, VIC, Melbourne
Joined Aug 2012
If no RMG, then I would say the Eurgle drum winch, but make sure its the high torque rather than higher speed version. I know a friend who almost won a 10R national title with one, and it blew hard through the series.
Therefore, I think an Eurgle should cope with an IOM.... Maybe run a smaller sheeting radius ( boom pick up point closer to the pivot point) would help increase speed . Just make sure that you have a spare, and use a voltage regulator if using battery packs greater than 6 volts...
Arm winches suffer when you are being overpressed. Quite often they don't have the torque to gybe sails. Graham Bantock used a large wheel on the servo to help it, but even he has gone back to RMG's...The good arm servos are half the price of an RMG, so if blow 2 up, you've lost out...
bigpat is offline Find More Posts by bigpat
Old Feb 20, 2013, 07:46 AM
gp. is offline
gp.
gp.
gp
gp.'s Avatar
South Aust.
Joined Aug 2006
Paris Creek
http://www.sehills.saradioyachting.org.au/index.html
Have a great day
Discussion Sail Winch Motor s_e_h10 GWS (Grand Wing Servo) 1 Feb 13, 2013 09:38 PM
Discussion IOM Sail winch- whats the best compromise? fats_nz Sailboats 10 Aug 19, 2010 08:54 PM
Discussion BMW Oracle Crew sailing IOMs Ed Morales Sailboats 4 Feb 23, 2010 07:42 PM
Discussion IOM sail number lamafever Sailboats 7 Jun 23, 2009 12:41 AM
Robbe Windstar (IOM) with a sail arm servo? rchadd Sailboats 3 Jul 21, 2005 08:11 PM
