Old Feb 18, 2013, 07:58 PM
stevea3342 is offline
Find More Posts by stevea3342
stevea3342's Avatar
United States, CT, Bridgeport
Joined May 2012
Question
How to charge NiMH AA batteries with 'regular' balance charger?
Anyone know how to charge NiMH AA batteries on a 'standard 4 button' balance charger? The batteries are rated at 2000mah. I have put them in a 4xAA holder and soldered on banana clips, changed the battery type on my charger to NiMH.
It seems that there is nowhere to enter the number of cells, or even the voltage. There is a discharge program and a cycle program, but the charge program appears to be 'manual', and the options looks like this:
NiMH CHARGE Man
CURRENT 0.4A
I have a Venom and a Thunder charger, but the options are identical. Is it possible to charge AA NiMH batteries with these chargers? One at a time? 4 or more at a time in series? Thanks for any help.
stevea3342 is offline Find More Posts by stevea3342
Old Feb 18, 2013, 10:27 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
You only set max charge current with nimh. That's all you need. Press + and - at the same time to switch to auto which will be peak detect charging.
grimbeaver is offline Find More Posts by grimbeaver
Old Feb 18, 2013, 11:03 PM
btown2 is offline
Find More Posts by btown2
United States, IN, Bloomington
Joined Sep 2012
If you are going to fast charge then you need to have thermometer to monitor the batteries. My B6AC+ has a thermometer and I use the following settings on my 6v 2700 mah flight pack.
Current = 1.6 amps
delta v = 5 mV
Temp cutoff = 40C
thats after the pack has been used before. For a first time charge use a 1/10th C charge rate for 16 hours. After that feel free to fast charge or slow charge as you see fit.
btown2 is offline Find More Posts by btown2
Old Feb 19, 2013, 01:31 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Exactly ....
And don't worry that amps charge rate will often NOT be what you set ... what you set is the MAX amps allowed if pack is near fully discharged ... part discharged means charger will not reach that max rate ..
I use my B6 often for NiMH charging ... even for topping up Tx / Rx packs when away for long sessions ....
Nigel
solentlife is offline Find More Posts by solentlife
Old Feb 19, 2013, 07:56 AM
stevea3342's Avatar
Joined May 2012
I tried pressing the + and - at the same time, but it appears that this doesn't work on either of my chargers, even if I tried holding them down.
Current = 1.6 amps
delta v = 5 mV
Temp cutoff = 40C
I have a temperature probe, but I have not found anywhere to set delta v. I think I'm still back where I started - with only the ability to set amps for NiMH. But I'm still not sure if that is sufficient? Or if this is all I need, I'm not sure what to set the mah for.
These are my chargers:
Old Feb 19, 2013, 08:04 AM
btown2 is offline
Joined Sep 2012
On my charger I have to back out of the NIMH program and go to the settings menu to set things like delta V and temperature. On the NIMH program I can only set amperage.
Old Mar 20, 2013, 08:48 PM
musechaserpilot is offline
Find More Posts by musechaserpilot
Joined Jan 2013
Current = 1.6 amps
delta v = 5 mV
Temp cutoff = 40C
This is a REALLY stupid question, but hey, they're my specialty...
I have an AC6 w/ a temp probe, too. I get how to use it as far as the settings and connections go, but, well... do you just set the probe on top of the battery? Tape it on? Any particular spot on the battery?
Flame away... I can take it...
Barry
musechaserpilot is offline Find More Posts by musechaserpilot
Old Mar 21, 2013, 01:12 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
I typically use either tape or a rubber band to hold the temperature sensor firmly against the side of one of the cells. I usually set temp cutoff at ~105F as I would prefer to terminate a little early rather than allow my NiMH cells to be subject to potential overheating.
It's important to note that NiMH packs must be properly balanced prior to attempting to charge via high rate peak detection. Initial charge must be performed at a very low rate for an extended period of time to avoid possible cell damage. I recommend 100mA or less for AA cells for initial charge and periodic maintenance equalization charge.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Mar 21, 2013, 08:01 AM
The Tug is online now
Find More Posts by The Tug
Barbados
Joined Jan 2011
Under "user set program" is where you will find the temp and Delta V settings.
The Tug is online now Find More Posts by The Tug
Old Mar 21, 2013, 08:52 AM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, FL, Naples
Joined Apr 2009
When in the Nimh program you have to change the "MAN" to "AUTO" setting (hold down the + and - ) when the current (amps) setting is blinking.
tacx is offline Find More Posts by tacx
Old Mar 21, 2013, 09:39 AM
United States, MN
Joined Feb 2011
Originally Posted by tacx View Post
[COLOR="Magenta"]When in the Nimh program you have to change the "MAN" to "AUTO" setting (hold down the + and - ) when the current (amps) setting is blinking.
I don't recall that but I don't charge nimh with my charger too often. Not every 4 button charger is exactly the same though either.
Help! NiMH AA CHARGING ? KenS999 Batteries and Chargers 16 Jun 30, 2014 09:56 AM
Discussion Questions about charging 7.2v nimh with my blance charger..& am i doing correct.. wiytboi Batteries and Chargers 4 Dec 10, 2013 01:51 AM
Question charging AA batteries with Imax B6? tiggertoo1962 Batteries and Chargers 10 Feb 07, 2013 03:25 PM
Discussion New Bright RC car Li-Ion battery 4 cell, how to charge with AC6??? shahram72 Batteries and Chargers 7 Jan 08, 2013 09:53 AM
Question Triton Charger and Regular AA/AAA nimh batteries jmc67 Batteries and Chargers 17 Dec 19, 2005 12:06 PM
