Sure you can, my experimental quad jet even looped and rolled without control surfaces.
But better to have control surfaces too. Better control and maintains control in dead stick situation. Thread.
Latest blog entry: Quick Stick
There is a trick you might be able to use to avoid complicated programming with your quad. With a little appropriate tilt to the fans you can make it yaw stable and have yaw control. The little Alien Jump Jet used this technique. All the props spin the same direction |
Here are a couple of other examples of quads with tilted fans. The tilt helps improve the yaw rate and give more yaw authority. Looks cool too.
Morton, IL
Joined Jan 2005
Awesome input guys, I really appreciate it.
Regarding my intent to use a ducted fan or this, my hope is eventually to significantly scale-up the project into a large-scale working prototype, and need to final design to be efficient and compact, with a minor regard also to aesthetics. In larger scale, my understanding is, ducted fans can be smaller than traditional rotors because they are more efficient, they're quieter, safer (to bystanders or those entering and exiting the craft), etc. Maybe EDFs are too far removed from normal rotors and I need to build something of a hybrid? ![]() The Bell X-22A is something similar to what I'm trying to achieve, though on a smaller scale, with a non-traditional airframe and smaller fans. http://videos.howstuffworks.com/disc...-22a-video.htm In the sketches I'm working on (I'll post some eventually) my design is a central craft with the passenger compartment in the front, power source and ancillaries in the rear, with 4 fans in an X configuration which are level in hover and tilt into a staggered arrangement (rear fans tilt up from the leading edge, front fans tilt down from the rear edge) in an attempt to provide better airflow to each fan. This design should operate as a quad in hover mode (or by nacelle tilting if inertial effect doesn't work with this design) and apparently may still work in that fashion so long as the tilt doesn't pass 45* (fast hover), only needing to vary the function of the fans for flight control when in fast forward flight. (Thanks Ran D for the description, this was one of my questions). If speed and range can be attained in "fast hover", "fast forward" flight would not be necessary, significantly simplifying the project. This would have to be similar to other small private aircraft. |
Ducted props will be much better than edf's.
You'll be able to find counter rotating props pretty easily so you can just use an ordinary quad controller and no weird fan tilts to control yaw. The prop system is much lighter and more efficient for the same amount of static thrust when compared to an edf. If you are going for a scale looks, the larger ducted props might work better for your X-22 in this way also. Not going to full tilt for forward flight is another big simplification and a good starting point. Once you get it flying well, you can always attempt more/full tilt later. |
| Thread Tools | |
| Discussion FF, "Flying Without the Aid of RC or CL" | E-Challenged | Free Flight | 20 | Feb 13, 2013 07:53 AM |
| Discussion Tricopter Rudder Motor tilt vs control surface? | dcame002 | Multirotor Talk | 0 | Jan 11, 2013 02:08 PM |
| Discussion Taileron vs Traditional Control Surface Configuration | Brutikus | Electric Ducted Fan Jet Talk | 11 | Dec 29, 2010 12:54 AM |
| Cool WOW!!!! Iphone controlled quad with vid link to iphone, tilt controlled!! | helifrek | Multirotor Talk | 8 | Jan 18, 2010 09:23 AM |
| Discussion Mass balancing control surfaces, FF stabs etc | flyonline | Slope | 3 | Apr 29, 2009 12:18 AM |
