Old Feb 18, 2013, 03:14 PM
Ken Lilja is offline
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
Smoke smell
I purchased a very nice vintage transmitter. The only problem is that it smells strongly of cigarette smoke. I can remove all the guts and clean the case. But the electronics, and especially the wiring may have most of the odor. Does anyone know of an electronics safe cleaner that might kill the smell? My 2 ideas so far would be to hose it down with a quality contact cleaner. Or hose it down with ACF50 - Corrosion X. I know that this is safe, just slimy and smells like
Play Dough. A spray flux remover might be too aggressive. In all cases I would have to keep it out of the pots. I know that there are spray enzyme odor killers but I would worry about corrosion.
Any thoughts would be appreciated.
Ken Lilja
Ken Lilja is offline Find More Posts by Ken Lilja
Old Feb 19, 2013, 06:39 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
Maybe dust it down with baking powder, let it sit for a while, and then blow it out with compressed air?
Just a thought.....
dmccormick001 is offline Find More Posts by dmccormick001
Old Feb 19, 2013, 08:33 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Isopropyl alcohol is safe to use and will clean the electronics and rosin nicely.
The smell could be IN the wire insulation, though. It can absorb the smell, so you might not get rid of it entirely.
Baking soda is not a good idea. It will attract moisture and, as a salt, will be a very CORROSIVE product.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Feb 19, 2013, 03:29 PM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
And by 'Vintage' what do you mean ?
Cant see how anyone could give good advice without knowing when the 'transmitter' was manufactured.
srnet is online now Find More Posts by srnet
Old Feb 20, 2013, 04:24 AM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
A good while ago, I bought a stinkin' watt meter. It always smelt pretty bad until after testing a large setup, the current shunt resistors heated up enough to burn off what ever was on them. I guess the tar and other crap is deposited on the different parts thus causing the smell.
I reckon isopropyl alcohol will get you a long way in removing the residues causing the smell.
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Feb 20, 2013, 05:33 AM
Ken Lilja's Avatar
Joined Nov 2003
True. It is an ACE MicroPro 8000. Slightly off white textured vinyl. I will remove everything from the case and fix any corrosion, scrub, and paint the case. I also have a Pro Line that is getting the same treatments in addition to M*2K encoder and XPS 2.4
Iso sounds like the way to go.
Thanks all,
Ken
Old Feb 20, 2013, 10:41 PM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
Just enjoy the rich aroma. Why would you want to waste that?
jakestew is offline Find More Posts by jakestew
Old Feb 21, 2013, 03:57 PM
Ken Lilja's Avatar
Joined Nov 2003
Well, if it was Chicago deep dish pizza.......
Ken
Help! Hitec X4 ACplus smells like smoke, acrid burning Remy130 Hitec/Multiplex USA 4 Jan 08, 2014 06:32 PM
Discussion The smell of smoke Loafman99 High Performance 37 Nov 18, 2009 12:11 PM
Help! Smoke smell fish2keel Electric Heli Talk 23 May 04, 2009 06:37 PM
Discussion Trainer cable = smoke smell Brian_ Radios 5 Jan 30, 2009 08:38 PM
Discussion Fire fire i smell smoke comming from ecs lol wrangler Beginner Training Area (Aircraft-Electric) 1 Dec 21, 2006 02:21 PM
