Old Feb 18, 2013, 11:41 AM
Joined Apr 2006
Gentle Lady Hinge - which to use - nylon hinge or film covering hinge
Am building a standard Gentle Lady, not powered, ad the plans for the rudder and elevator hinging call for either using film covering as a hinge or a "conventional hinge if preferred". How to choose?
rwpeek is offline Find More Posts by rwpeek
Old Feb 18, 2013, 11:59 AM
glider pilot in training
webdragon's Avatar
United States, AR, Searcy
Joined Aug 2006
A film hinge is better in my opinion.
webdragon is offline Find More Posts by webdragon
Old Feb 18, 2013, 12:03 PM
Joined Apr 2006
hinge
OK then webdragon Ill use the film covering hinge then. Helps a lot because I am out of the country and don't have easy access to nylon hinges. Thanks!
Old Feb 18, 2013, 01:51 PM
webdragon's Avatar
Joined Aug 2006
If your worried about it not being strong enough you can use clear packing tape as well.
this is the method i use and so far i've never had one let go.
http://www.rcgroups.com/forums/showt...1331760&page=4
Old Feb 18, 2013, 01:52 PM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Book binding tape or "blenderm" tape also work very well.
tkallev is offline Find More Posts by tkallev
Old Feb 19, 2013, 12:47 AM
slopemeno's Avatar
United States, CA, Mill Valley
Joined Jan 2003
Tape is quick, easy, and durable. I use 3M #190, which Ace Hardware sells. Comes in clear, white, and the primary colors.
slopemeno is offline Find More Posts by slopemeno
Latest blog entry: F-20 update
Old Feb 19, 2013, 02:47 PM
In the Dunes
Chesterton, IN
Joined Dec 2003
My original GL is still flying 20 years later. Original film hinges still going strong.
Papermache
papermache is offline Find More Posts by papermache
Old Feb 20, 2013, 09:52 PM
Thermal Naked!
Hossfly72's Avatar
United States, AL, Mobile
Joined Dec 2007
Quick tip... If you don't want to use film hinges (personal preference?) look in the nearest FedEx drop box or station and grab a FedEx pack, not a letter, but the pack. It's made of Tyvek and is very durable and thin.
Hossfly72 is offline Find More Posts by Hossfly72
Old Feb 25, 2013, 03:05 PM
Joined May 2010
Built mine in the early 80's. After a rest period of 24 years electrified it 2 years ago. The monokote rudder hinge failed with minor damage, luckily. Had flown well over the years up till then. Replaced it and the elevator hinge with Dubro pin hinges. I liked the monokote hinges better, but did't want to encounter any more repairs. I think the Monokote works well, but needs to be examined often for possible wear or deterioration. I like some of the above ideas as well.
Hope this helps,
Jack
Jack McC is offline Find More Posts by Jack McC
Old Feb 25, 2013, 03:34 PM
R.M. Gellart's Avatar
Joined Nov 2005
+1 for 3M #190, but use the clear, it just seems to have better attributes for hinging. I have used this on unlimited ships with great results.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Mar 01, 2013, 07:53 AM
United States, MI, Hastings Charter Township
Joined Apr 2005
If you are concerned about the covering film peeling, you can use a laced hinge method which is very secure.
maxdriver is offline Find More Posts by maxdriver
For Sale Gentle Lady (ARF version) helifrek Aircraft - Sailplanes (FS/W) 7 Jan 16, 2013 08:09 PM
Discussion Soph Lady wing work on a Gentle Lady fuse?? overmyhead Sailplane Talk 10 Jan 12, 2013 02:31 PM
For Sale Carl Goldberg Gentle Lady kit with 2 servos 70.00 shipped MIKEYOUR Aircraft - Sailplanes (FS/W) 1 Jan 04, 2013 10:07 AM
Question gentle lady covering film... rjarois Sailplane Talk 20 Sep 18, 2010 06:01 AM
Sig Riser or Gentle Lady? Which one would you build, to complete the fleet. Jimmy James Thermal 32 Apr 05, 2006 07:49 AM
