Yeah, Baby! That's what I'm talking about! And with Airhole's glow wires, this thing is gonna rock at night. When doing fly-by's or landings, he can just flip switch #3 and illuminate the snow. Like one of those UFO's when the bright lights get switched on and poor Agents Mulder & Scully (or in this case Wind_of_Change and Airhole) are blinded and amazed. Imagine that thing in the fog, which we've had an abundance of here lately!
Now I gotta do it! It's like keeping up with the Joneses!
Wind_of_Change
Can we take a look at the "Guts" of your Projeti? I am looking at doing this with LED`s from Curtek I did it with a MSW that had a 10 Turn 010 Worked quite well. I think it will be bright enough for me.....Hopefully. I do like the looks of yours though.....Very cool indeed. MAl |
kushal_22,
Sorry, I just stripped off the wires to put them on my newly completed Unicorn. But I can describe it to you. I cut off the 9 volt attachment on my EL Wire inverter, and then soldered the wires to my deans connector leads (the one that is attached to my speed controller.) I ran the two blue glowires out the same holes that the wing servos come into the fuselage through. I ran them out and wrapped them up around the vertical stabilizers, then down to the nose of the plane I ran a lead wire out one of the servo holes as well, down the underside of my plane out to the tip, where the glowire started. Then I wound it around that wing tip, along the front of the plane, out to the other tip, which I wrapped with E.L. wire. Inside the fuselage, I was using a Kokam 1500 3S1P Lipo battery and the Jeti 18 speed controller. That sat at the nose. Behind that I put the E.L. Wire Inverter. Then behind the firewall was the receiver and ESC. If anything's not clear, or you have other specific questions, let me know. Todd |
Firewall?? I M Basically going to do the same thing with mine and the Curteks.....A llittle different for the LE Strip but this is because the wire is thinner. I am just going to go striaght up inside the fuse to where the nose cone stops then out along the LE. ANYWAYS THANKS for the Pics. BTW did you ever get it to WOT at night??
Mal |
| Thread Tools | |
| Discussion Night flight with a slow stick... | TommyB | Parkflyers | 6 | Sep 29, 2006 01:03 PM |
| Discussion 1st Night flight with video | MisterNiceGuy | Aerial Photography | 4 | Mar 04, 2006 12:10 PM |
| Airbus A330 night flight with lights | WillFrance | Fuel Jet Talk | 8 | Sep 02, 2005 03:41 AM |
| Second Night flight with Glow wire | kushal_22 | Foamies (Kits) | 5 | May 03, 2004 08:37 PM |
| Night Flight With Tiger Moth | Burtsc | Parkflyers | 6 | Dec 31, 2002 08:38 AM |
