Jan 17, 2004, 09:26 AM
Utah
Joined Dec 2003
Looks nice Helicool! Looking forward to a flight report!
Dsam,
I took the case off of my inverter. There were three small circuit boards inside connected to each other with small wires. I'm laying mine out in a row and cutting them into the foam just inside the battery bay, opposite the RX. I'm facing the board with the power switch into the battery bay and placing it at the far rear and recessed into the foam a bit so the switch is easily accessible, but not "switchable" if the battery shifts around. It'd suck to pull a tight maneuver and suddenly have your lights turn off!
The case doesn't save you much weight, I just didnt' want to bore out more foam than necessary, so the wing is as strong as possible.
Todd
