United States
Joined Feb 2001
That ESC only has two voltage settings. http://www.castlecreations.com/products/talon.html
If you have good quality efficient servos the internal BEC should be ok for a 500-size FBL helicopter. Make sure everything is free and no binding. . |
United States
Joined Feb 2001
I have several Scorpion motors (large and small) and have never been able to tell a difference between 8 and 12. Has CC actually run any lab tests that show 8 is better than 12? . |
Chicago 'burbs
Joined May 2006
![]() I too have used Scorpion motors a lot, and find like all motors, they perform slightly better at higher PWM. Unfortunately the ESC's, as I am sure you are already aware, run hotter at higher pwm settings. So the net result is that it doesn't matter a lot if you go 8 or 12kHz. I have run Scorpions even as high as 24kHz with my old Phoenix ESC's in the past with no impacts. Couldn't do that with my ICE 50, the ICE couldn't even make the motor start at 24kHz. I assumed that with logging its controller was just too busy, but running at 12kHz was fine. |
United States
Joined Feb 2001
LOL - that’s probably it. If their ESC’s will only do 8 KHz then they are going to recommend that for every motor they make even if it’s not optimal - LOL. Since CC had all the fancy test equipment it would be really interested to see what is optimal for Scorpion motors. It’s probably different for the various series of motors that they make.
| Thread Tools | |
| Sold New in box Castle Talon 90 | Ifly101 | Aircraft - Electric - Power Systems (FS/W) | 2 | Feb 13, 2013 04:07 PM |
| Trade Trade New In The Box Losi Mini Sprint for pretty much anything...Planes,Helis, 4x4SC. | vacahtu | Want To Trade | 3 | Jan 11, 2013 12:26 PM |
| Free lot of new Trex 250 size heli parts new in packages | MIKEYOUR | Free Items | 3 | Jan 05, 2013 04:06 AM |
