Old Feb 17, 2013, 06:02 PM
flyforfood_not's Avatar
Northern VA
Joined Jul 2009
How to make windows?
I have a C-310 with two .61 nitro fuel engines on it.
I'm trying to build new windows in it (including the winshield).
What is the best advice for them? What's the best/easiest material out there to use?
Also, the plane will be recovered with monokote, so i also wanted to make sure i could somehow wrap the covering around the edges of the window frames into the cabin of the plane (so that the wind doesn't strip the covering off on the outside).I'm just not too sure how to go about it all..
Any suggestions or even pics (or links to materials) would be appreciated.
Thanks, Lukas
flyforfood_not is offline Find More Posts by flyforfood_not
Old Feb 17, 2013, 07:58 PM
AA5BY's Avatar
East Texas
Joined Aug 2007
Making side windows is easier than one might first think. First, obtain some .015 PETK, your local hobby shop should carry it or be able to order it. If not, it is available in 8.5 x 11 inch sheets on line.
Next, using plywood the same thickness of the longeron or window framing, make an identical cut out, it will be the female mold. Follow up by making a male plug from the same thickness plywood, 1/16" smaller than the opening. These molds will work for both sides of the plane if the window openings are identical, just by reversing sides.
Place a piece of wax paper on a cookie sheet and lay the male mold over it. On this, place a piece of PETK cut a half inch larger around the window opening. Now carefully position the female mold over the male mold. On this, lay a piece of plywood that overlaps the window opening. Finally, on top of it all goes a healthy weight placed about center of the window.
Place in an oven on low heat and wait until the weight has driven the female mold down over the male plug. It generally took me from 15-20 minutes. Turn off heat and let it partially cool but not so much that the window will be hard to remove. Trim around leaving 1/4 inch of back lap to glue. The pane will be installed of course after the covering where the film covering will be as you desired, wrapped inside.
Put the molds in a 5x7 manila envelope and mark what plane they are for and save in case another window is needed.
No vac forming is needed and the PETK piece only needs to be slightly larger than the window (not necessary to use a whole sheet as with vac forming).
I do have a link showing the process but it is embedded in a plane build and is a very lengthy load on dial up.
http://pages.suddenlink.net/arlyn/tcrebuild.html
AA5BY is offline Find More Posts by AA5BY
Old Feb 18, 2013, 12:49 PM
Northern VA
Joined Jul 2009
Awesome!
Thank you.
Do you think this will also work with thicker sheets?
I wanted to use stronger thickness since it's a pretty fast airplane.
Old Feb 18, 2013, 02:36 PM
AA5BY's Avatar
East Texas
Joined Aug 2007
Originally Posted by flyforfood_not View Post
Awesome!
Thank you.
Don't know... I've not tried it with the .060 PETK.
Discussion How To Make Molds - Composite Gliders SOOFLY Composites Fabrication 9 Jan 20, 2013 03:31 PM
Question How to make airliner's cockpit and windows _Sergey_ The Builders Workshop 4 Feb 02, 2011 06:00 PM
