Old Mar 08, 2013, 04:37 PM
Da Big_G is offline
Find More Posts by Da Big_G
"Get off the runway!"
Da Big_G's Avatar
United States, TX, Hutto
Joined May 2012
Originally Posted by ParkJeff View Post
Nice looking bird. Perhaps a good replacement for my Helios 63e. Do you think these Hitec servos will fit? http://www.hobbyking.com/hobbyking/s...idProduct=9813
They will be a tight fit...but look close. Maybe a little trimming.
Da Big_G is offline Find More Posts by Da Big_G
Old Mar 08, 2013, 06:35 PM
ParkJeff is online now
Find More Posts by ParkJeff
Birds do it, bees do it
ParkJeff's Avatar
Australia, WA, Perth
Joined Feb 2003
Thanks. Looking forward to your build.
ParkJeff is online now Find More Posts by ParkJeff
Old Mar 09, 2013, 01:28 PM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
About done. Just waiting for the servos to arrive..
Update: Just finished the build, less servos. Plugged in the weight of the servos and the plane weighs (less LiPo) 2299.15 grams, about what HK said it would (2300 grams). I am impressed! With a Turnigy 6S/3000ma. pack, the AUW is 6.22 lbs. Perfect. The motor I am using (Turnigy SK3-5045-500Kv) is out of my HK Katana, which, btw, came out at least 1.5 lbs. over advertized weight. As soon as the servos arrive, I'll give an initial flight report.
Old Mar 10, 2013, 12:52 AM
ParkJeff's Avatar
Joined Feb 2003
Did the screw holes on the backmount cross of the 5045 fit the blind nut positions on the firewall or did you have to modify that?
Old Mar 10, 2013, 09:57 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
They were a little off, so I slotted them about 1/16 inch and used lock nuts instead of blind nuts. If this motor works out, I'll convert to blind nuts.
Old Mar 10, 2013, 10:26 AM
ParkJeff's Avatar
Joined Feb 2003
Thanks. Not sure whether to go with the 5045 or the 5055. Hope the 5045 works out as it's a fair bit lighter.
Old Mar 10, 2013, 10:55 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
It will be close. I like the 5045, but the 500kv might be just a tad low. Prop calc. shows it to be good for 89-91 mph in this combo, but I think it's too optimistic. Tested the static thrust tonight with a 13/10 prop...7lbs,12oz. I'll check rpm's and amp draw tomorrow.
Amps are 48.8 @ 4.02-4.03 volts/cell (resting). Watts were 1,083.36. 173w/lb. So far, so good. Seems to have a warp in the left horizontal stabilizer..a little wash-in. May try heat to un-warp it.
Old Mar 16, 2013, 10:42 PM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Airoso
Should maiden tomorrow
Old Mar 17, 2013, 08:12 PM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Maiden flight
Well, the Airoso has maidened. Never have I flown a plane that flew so neutral after a build. Negligible roll or pitch coupling. C/G was close. Looks like no mixing will be necessary! The power plant is perfect, (Sportsman maneuvers are no sweat) with the motor temps. after 4+ min. flights 95* on a 85+ degree day! The 3000 ma. pack was warm, going down to 18%. I will upgrade to 4000 ma. packs, giving me a safe 5 to 5-1/2 min. full throttle flights. The landing gear is a weak point, however. Any bump at all and the gear will bend. I will seek out a carbon fiber substitute. One of my club fellow flyers took a video of the maiden. If it's available, I'll add it here.
Old Mar 18, 2013, 05:58 AM
ParkJeff's Avatar
Joined Feb 2003
Well done! I hope the bigger pack will not make it nose heavy but other than that, it sounds good. Great job.
Old Mar 18, 2013, 08:03 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Balance won't be an issue. How are you coming along with yours?
Old Mar 18, 2013, 09:03 AM
ParkJeff's Avatar
Joined Feb 2003
I am still sitting on the fence as something else has caught my eye. It's hard when there are several attractive choices and only limited time to build.
Old Mar 18, 2013, 11:56 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
I know what you mean. For me, I'm happy with my choice. It feels so comfortable in the air.
Old Mar 19, 2013, 09:13 AM
RC_Fred is offline
Find More Posts by RC_Fred
Joined Mar 2013
Great job! Looking forward to see the video.
What about these TGY-390V HV Metal gear Servos you used, are they any good?
RC_Fred is offline Find More Posts by RC_Fred
Old Mar 19, 2013, 09:54 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Those servos are great. Fast, strong and center very well and tight. They were a little small for the factory cut-outs, I had to add balsa filler to achieve a solid mount. I have since installed some new Hitech HS225's. They are not digital, but they are just as fast.
Help! Hobby King Shipping Damage Fiasco... Demon 6 HobbyKing 21 Jan 16, 2013 07:54 PM
Help! Can anyone Help Me out? Hobby King Fiasco Demon 6 HobbyKing 55 Jan 12, 2013 07:19 PM
Discussion Hobby King P31 HobbyKing 7 Jan 04, 2013 06:32 PM
Sold Hobby King Multi-battery charging adapter for UMX-type batteries K_B Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 03, 2013 07:02 AM
