Old Feb 17, 2013, 06:44 PM
Da Big_G is offline
Find More Posts by Da Big_G
"Get off the runway!"
Da Big_G's Avatar
United States, TX, Hutto
Joined May 2012
Hobby King Airoso
Has anyone built/flown one of these? I'll be the guinea pig. I have one on order. They seem popular, HK has sold 10 this week. I know...it's Hobby King. Forgive me, for I am on a budget...lol.
http://www.hobbyking.com/hobbyking/s...dProduct=26558
Da Big_G is offline Find More Posts by Da Big_G
Old Feb 18, 2013, 03:15 AM
santuz is offline
Find More Posts by santuz
italy
Joined Sep 2007
waiting for your feedback when you will get it
santuz is offline Find More Posts by santuz
Old Feb 18, 2013, 09:51 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Will do...It'll be a while, as it's on a slow boat from China (literally).
Old Feb 18, 2013, 09:29 PM
Mattfoo83 is offline
Find More Posts by Mattfoo83
I like turtles
Mattfoo83's Avatar
United States, FL, Leesburg
Joined Dec 2012
Very cool!
Mattfoo83 is offline Find More Posts by Mattfoo83
Old Feb 22, 2013, 08:46 AM
scottflight is offline
Find More Posts by scottflight
scottflight's Avatar
Arvada, CO
Joined Aug 2004
I picked one up. Some damage from the trip here but I'll fix it up and see how it goes. I'll post some of my results...when I get a chance to work on it.
scottflight is offline Find More Posts by scottflight
Old Feb 22, 2013, 09:05 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Mine has shipped.
Old Feb 22, 2013, 05:54 PM
bill clark is offline
Find More Posts by bill clark
Half way there
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
looks kinda heavy but that may be good
bill clark is offline Find More Posts by bill clark
Old Feb 22, 2013, 06:02 PM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Keep us posted on the build weight. I'll do the same.
Old Feb 26, 2013, 11:55 AM
viflyer is offline
Find More Posts by viflyer
St. Croix, US Virgin Islands
Joined Oct 2003
Suggested set-ups?? 5S?? Looks like a low ground clearance with stock gear?
viflyer is offline Find More Posts by viflyer
Old Feb 26, 2013, 01:26 PM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
I'm going with 6S, mostly because I already have 2 packs. With a 500kv motor, should be fast enough. Probably a 16/12 prop.I have this motor in another plane, I will try it first: http://www.hobbyking.com/hobbyking/s...dProduct=18171
Old Mar 01, 2013, 02:00 PM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
It has arrived, undamaged. I'll pull it out of the packaging and weight it tonight. The fuselage is huge. Let the building commence!
Old Mar 01, 2013, 03:04 PM
viflyer is offline
Joined Oct 2003
Cool mon!!! Undamged too!!! Can't wait to see those parts pics/weights!
Old Mar 02, 2013, 12:09 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Airoso update
Upon closer examination, I have some observations:
Some minor shipping/handling damage, limited to a broken fuselage former reinforcement and a cracked/loose cowl mounting tab. Not too bad considering the distance from China and the USPS crew.
Check all glue joints. Add thick or thin CA glue as needed. Typical of Chinese ARF's.
Covering job was very good, with a minimum of trapped dust under the covering. A few loose edges. Very bright and creative covering. Should be very visible in the sky.
Servo cut-outs are 30mm x 15mm. Standard servos are too big. You will need strong mini servos.
Massive fuselage and thick root section on the wing. Should help in down-line speed control and make landings easier/slower.
Aggressive wing taper. Should have a fast roll rate. Airfoiled stabilizers a big plus. Tail flying surfaces seem very strong.
Good quality hardware kit. They seem to get better every few build cycles. Sounds like the designers are listening to us.
Things I do not like are limited to the landing gear and the joiner for the elevator halves. I will work around that. I don't like this type of engineering. The landing gear box is not strong.The box construction will not survive many botched landings. This is also typical of many ARF's. Carbon fiber should be used here, and on the landing gear themselves. The aluminum legs are heavy, and will probably bend on the first hard landing.
I predict this plane will build up about 1 lb. heavier than advertised. I don't think this will hurt the flying characteristics too badly.
So, all in all it looks like a good deal. We will see in a few weeks after I maiden her.
Gary
Old Mar 05, 2013, 11:27 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Added notes on build
Added notes on the build will be posted here:
Carbon wing tube too long, by maybe 3/16 inches., preventing tight fit of wing to fuselage. Just trim one end until the wing is snug.
Both blind nuts for wing bolts were "buggered up". Cleaned up the threads with a M4 tap.
The DVD/manual is a joke, but if you have built a few ARF's, you will be fine.
Remember that the servo holes/openings are NOT a standard size. Smaller than Futaba 3004, but bigger than most mini's. A lot of the cheaper mini's will not have enough torque, so choose your servos wisely. The Futaba servos to fit the openings were $65 each, so I opted for HK servos. Mixed reviews on the quality of these...I'll let you know after I try them out. http://www.hobbyking.com/hobbyking/s...dProduct=23468
Old Mar 08, 2013, 05:19 PM
ParkJeff is offline
Find More Posts by ParkJeff
Birds do it, bees do it
ParkJeff's Avatar
Australia, WA, Perth
Joined Feb 2003
Nice looking bird. Perhaps a good replacement for my Helios 63e. Do you think these Hitec servos will fit? http://www.hobbyking.com/hobbyking/s...idProduct=9813
ParkJeff is offline Find More Posts by ParkJeff
Help! Hobby King Shipping Damage Fiasco... Demon 6 HobbyKing 21 Jan 16, 2013 08:54 PM
Help! Can anyone Help Me out? Hobby King Fiasco Demon 6 HobbyKing 55 Jan 12, 2013 08:19 PM
Discussion Hobby King P31 HobbyKing 7 Jan 04, 2013 07:32 PM
Sold Hobby King Multi-battery charging adapter for UMX-type batteries K_B Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 03, 2013 08:02 AM
