Old Feb 17, 2013, 04:35 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Data
3-Blade or 2-Blade Props? 10 propellers tested
We often see questions about 3-blade props.
Answers concerning airplanes props are easily found unlike multicopters ones.
Wanting to improve my knowledge, I have tested 10 props, four 3-blade and six 2-blade.
DT700 motor and 3S battery, often seen on multis, have been used for this test.
Two levels, mid throttle (1.5ms) usually used for hover and full throttle (2ms) for max thrust.
Airflow being without any interference, thrust and efficiency values are optimal.
Here is what I've got:
Mortimer is offline Find More Posts by Mortimer
Old Feb 17, 2013, 05:43 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Thank you for your hard work and effect here. Your results confirmed my Intuition when taking into consideration the Pitch and diameter of a given prop in the same class, there is little measurable differences. Example, the Master Airscrew 10x7 and the APC 10x4.7, if the pitch was the same, there would be little differences.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Feb 17, 2013, 07:07 PM
otlski is offline
Find More Posts by otlski
checkout my Blog
otlski's Avatar
Joined Feb 2008
Great work Gary; it expands on Old Man Mike's work from years ago. His data and yours points to two blades being more efficient in general than three blades.
Dan
otlski is offline Find More Posts by otlski
Old Feb 17, 2013, 07:52 PM
nfhill is offline
Find More Posts by nfhill
Just Keeping UP
United States, ID, Moyie Springs
Joined May 2004
It's been known for a long time that 2 blades are more efficient than 3 blades and 1 blade is the most efficient. Single blade props are a challenge to balance, but they have been used.
nfhill is offline Find More Posts by nfhill
Old Feb 18, 2013, 08:33 AM
otlski is offline
checkout my Blog
otlski's Avatar
Joined Feb 2008
[QUOTE=nfhill;24167202]It's been known for a long time that 2 blades are more efficient than 3 blades and 1 blade is the most efficient. Single blade props are a challenge to balance, but they have been used.[/QUOT
Agreed but there are many non believers out there.
Dan
Old Feb 18, 2013, 09:05 AM
Joined Aug 2009
There is another factor few people consider when discussing 2 and 3 bladed props and that is Disk loading.
Old Feb 18, 2013, 11:25 AM
Jem3 is offline
Find More Posts by Jem3
United States, OR, Portland
Joined Aug 2011
Thanks so much Mortimer for doing this great work and publishing
Jim
Jem3 is offline Find More Posts by Jem3
Old Mar 16, 2015, 05:12 PM
dmkmod is offline
Find More Posts by dmkmod
Joined Aug 2009
Without taking airflow speed into consideration this test doesn't prove anything. Low pitched propellers will always give more thrust at 0 speed. Only test that could be considered given circumstances is GWS 9*5 vs APC 9*4.7, and we see really close performance here, but considering difference in quality between APC and GWS I really don't know... Correct test would be to check amp draw of the prop while doing same same thrust AND airflow speed.
dmkmod is offline Find More Posts by dmkmod
Old Mar 17, 2015, 02:13 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
What airflow have you when hovering ?
These props are tested for multicopter purpose, not for planes, check forum/context where you are.
renatoa is online now Find More Posts by renatoa
Old Mar 17, 2015, 03:39 AM
pteadsgo is offline
Find More Posts by pteadsgo
Joined Mar 2015
pteadsgo is offline Find More Posts by pteadsgo
Old Mar 17, 2015, 04:47 AM
Joined Sep 2007
Bigger for 3s, so again less efficient, but more wind resistant.
I would be more interested to see a versus analyse, which is more efficient when you need more load in restricted space, which is better, increasing voltage (3s to 4s) or blades count (2 to 3) Both decrease efficiency, but curious which is better.
Old Mar 17, 2015, 07:26 AM
Joined Aug 2009
Amen and is why I like the Master Airscrews even though their efficiency is lower than the slow-fly props.
Old Mar 17, 2015, 05:13 PM
dmkmod is offline
Joined Aug 2009
Never knew quads have changed laws of physics.
Old Mar 18, 2015, 01:32 AM
Joined Sep 2007
So you think hovering/forward flying has same prop requirements ?
Old Mar 18, 2015, 04:13 AM
dmkmod is offline
Joined Aug 2009
Could you please be more specific with your question, to the one you asked I can answer only that in both cases it is required for the prop to spin Airflow, in our case, is a speed of air that is being pushed through the prop which, is not the same as airspeed that I assume you have mistaken it for.
Discussion Myth #1 - 3 bladed props give more thrust than 2 bladed ones rcmaverick Electric Plane Talk 219 Mar 09, 2013 01:19 PM
Discussion 3 blade vrs 2 blade props helizrnew2me Multirotor Talk 9 Feb 10, 2013 03:14 PM
Sold 3 electric props for sale (brand new) Parkzone, GWS 3 blade and 2 blade aquaanox Aircraft - Electric - Power Systems (FS/W) 3 Jan 31, 2013 10:36 PM
Found CF 2 blade 28-10 or 3 blade 27-10 or 12 rjstrickjr Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 18, 2012 11:41 AM
3 or 4-blade prop vs. 2-blade prop R Hudson Power Systems 11 Aug 11, 2006 09:10 AM
