Old Feb 17, 2013, 12:19 PM
Jets:) is offline
Find More Posts by Jets:)
Jets:)'s Avatar
New Zealand, Auckland
Joined Aug 2006
Help!
Carbon vs kevlar sock
Hi guys i have a question i need answered so i can place order
From CST.
I have been bagging wing spars i make using carbon sock , how ever
Im wondering if i can do it with kevlar and save some money(bonus!)
What will i loose and what will be gained from using kevlar rather than carbon?
Wings spars are for two meter ds gliders weighing 2-3kg
Spars are carbon caps with pine shear webbing, then sock over the outside for burst strenght
Jets:) is offline Find More Posts by Jets:)
Old Feb 17, 2013, 12:55 PM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
You're probably better off using glass sock if you want to save money. Haven't ever seen Kevlar used in wingspars before, I'm sure there's a good reason.
SB7 is offline Find More Posts by SB7
Old Feb 17, 2013, 01:48 PM
Upvector is offline
Find More Posts by Upvector
Upvector's Avatar
Hamilton, CANADA
Joined Sep 2009
I've not heard of using Kevlar sock on the spar, (normal TD or F3B, J gliders) but definitely Kevlar tow, or string as a spiral wrap. It has the qualities of holding the carbon spar caps onto the spars, (as its qualities are good in tension), when under bending loads. That prevents the cf spars from sliding / shearing, which quickly leads to spar failure under hi-g forces.
The kevlar sock should work well, but might be a bit of overkill if you are concerned
about weight..( but for ds'ing.. probably a good idea considering the bending loads)
Joe Manor, the DS'ing guru might have some insight into that..
$0:02 Cdn worth
Ray
Upvector is offline Find More Posts by Upvector
Old Feb 17, 2013, 11:40 PM
Jets:) is offline
Jets:)'s Avatar
Joined Aug 2006
In joes d60's hes using a hybrid sock of carbon and kevlar, he said its does the job
Well enough.
Thanks for your ideas
Old Feb 22, 2013, 03:12 PM
G Norsworthy is offline
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
You can always do the math.
http://www.rcgroups.com/forums/showp...&postcount=117
G Norsworthy is offline Find More Posts by G Norsworthy
Discussion Carbon fiber vs kevlar (aramid) vs glass? icmartin Slope 17 Oct 31, 2013 02:53 PM
Discussion Carbon/Kevlar or Carbon/Fiberglass sock AUSELECTRIC Composites Fabrication 4 Feb 09, 2011 02:43 PM
Discussion kevlar vs. Carbon-pod lay-up for 1.5 meter Dlg dougmontgomery Hand Launch 22 Aug 18, 2007 03:33 AM
Discussion Kevlar vs Carbon SOH Hand Launch 2 Aug 15, 2007 08:14 AM
