Old Feb 17, 2013, 09:47 AM
Want2B3D is offline
Find More Posts by Want2B3D
Want2B3D's Avatar
Joined Nov 2012
Build Log
77" Edge goldberg
Bought this plane yesterday this is my first gasser to build, second ARF to build . I am going to do a build log, hoping that you guys will have lots of input to help me along the way. It looks like the motor box has been covered with epoxy alcohol mix already. Might go over it again to be safe. I re-glued all interior I could reach. Now some pointers on beefing up landing gear would be nice Name: ImageUploadedByTapatalk1361115739.821834.jpg
Description: Name: ImageUploadedByTapatalk1361115763.138309.jpg
Description:
Also the instructions start by putting the control horns on ailerons first, then installing the aileron. The last plane I did I put the aileron on first then the control horn. Does it really matter? I haven't received servos yet, so actual construction will have to wait. Just getting some suggestions will help me a lot thanks guys.
Want2B3D is offline Find More Posts by Want2B3D
Old Feb 17, 2013, 10:23 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
You can probally put a couple pieces of trianglar stock on the block and alittle more epoxy.
I'm looking forward to more postings of your build
kerwin50 is offline Find More Posts by kerwin50
Old Feb 18, 2013, 08:42 PM
Want2B3D is offline
Want2B3D's Avatar
Joined Nov 2012
Ordered the servos should come in by Thursday. Got wheels and wheel pants on ailerons and pushrods in place did my best on beefing up landing gear Name: ImageUploadedByTapatalk1361241699.222648.jpg
Description: add 2 blocks front and back with epoxy all around. Didn't have any triangular stock but this should work
Old Feb 18, 2013, 08:50 PM
Want2B3D is offline
Want2B3D's Avatar
Joined Nov 2012
Now for motor box I contemplated putting blocks in corners with epoxy and bolts but might go with aluminum angle pieces instead for strength Name: ImageUploadedByTapatalk1361242084.975398.jpg
Description:
Here are couple of pics so far Name: ImageUploadedByTapatalk1361242061.268211.jpg
Description: Name: ImageUploadedByTapatalk1361242155.855038.jpg
Description: Name: ImageUploadedByTapatalk1361242206.986474.jpg
Description: can you tell I am getting excited
Old Feb 18, 2013, 09:57 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
looking really good
what servos did you go with
Old Feb 18, 2013, 11:15 PM
Want2B3D is offline
Want2B3D's Avatar
Joined Nov 2012
Gonna try out some hextroniks hx12k 208ozin @6V
Description:
Starting to look like a plane here
Old Feb 19, 2013, 09:09 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
[QUOTE=Want2B3D;24178829]Now for motor box I contemplated putting blocks in corners with epoxy and bolts but might go with aluminum angle pieces instead for strength [ATTACH]5549057
so do you have some angle brackets too put on the firewall!
I definitaly would add some reinforcements on that firewall!
whiskykid is offline Find More Posts by whiskykid
Old Feb 19, 2013, 10:00 AM
Want2B3D is offline
Want2B3D's Avatar
Joined Nov 2012
Not yet hopefully today. Going with a pterodactyl 36 cc motor. What size gas tank do you recommend. 16oz or 32oz
Old Feb 19, 2013, 10:11 AM
Want2B3D is offline
Want2B3D's Avatar
Joined Nov 2012
I can tell from the 81" that 16oz should be plenty
Old Feb 19, 2013, 05:30 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Good luck with that motor.
Old Feb 20, 2013, 05:26 PM
Want2B3D is offline
Want2B3D's Avatar
Joined Nov 2012
Okay so might have a change in the motor. Maybe DLE35RA
Old Feb 21, 2013, 09:06 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
O man that motor will toss that plane around like a rag doll.
Good choice
Keep us posted
Old Feb 21, 2013, 08:21 PM
Want2B3D is offline
Want2B3D's Avatar
Joined Nov 2012
What do you guys know about mintor engines my local hobby shop sells these and they sure do look pretty? I am looking at the 38cc rear carb
Old Feb 21, 2013, 08:33 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
They have had alot of problems with them
http://www.flyinggiants.com/forums/s...69198&page=130
Old Feb 21, 2013, 09:49 PM
Want2B3D is offline
Want2B3D's Avatar
Joined Nov 2012
Okay that solves it then tomorrow I am ordering the DLE 35
Sold New Never Flown Goldberg Edge 540 77" tdaf22 Aircraft - Fuel - Airplanes (FS/W) 9 Dec 02, 2011 09:56 PM
For Sale goldberg edge 540 77" BNF ERGO60SX Aircraft - Fuel - Airplanes (FS/W) 0 Dec 09, 2010 09:30 AM
Wanted goldberg edge 540 (77") stuff Devil_Inside Aircraft - Fuel - Airplanes (FS/W) 3 Mar 09, 2010 09:33 PM
Discussion Carl goldberg edge 540 77" servos diego84 Giant Scale Airplanes 0 May 26, 2008 10:40 PM
Discussion **NEW** Carl Goldberg Edge 540 ARF 77” Jim T. Graham Product Announcements 1 May 17, 2006 11:30 AM
