This thread is privately moderated by hutchis, who may elect to delete unwanted replies.
Old Feb 17, 2013, 08:47 AM
hutchis is offline
Find More Posts by hutchis
Trader Rating: 3
Hutch
Joined Jan 2009
Trader Rating: 3
Sold
Misc Glow Props and OS 46 AX Engine Parts -$25 Shipped to lower 48
Guys, here’s some glow gear I no longer need. I have 9 used and in good condition props (2 – APC 11-4, 2-APC 11-5, 2 APC 11-6, 1 TF 11-8, 1 TF 10-7, and one master Air Screw (not sure of pitch, doesn’t say).
Here’s the story on the OS 46 AX parts. The disassembled engine was in perfect condition until I completely hosed it up using the “crock pot” method to clean it. I missed the memo about proper procedures and completely dunked the motor overnight which apparently ruined it. The carb is seized onto the crankcase and I cannot even budge the screw to get it off.
So, the assembled engine is one I find here on RC Groups. The previous owner had an incident and the only known damage at the time was missing heat fins from the cylinder head. So, I bought the engine thinking I could salvage parts from my original motor, but when I received the engine, I also found that in addition to the cylinder head issue, the crank shaft was bent too (adjustment made to paypal by seller).
Anyway, beyond tuning and flying these things, I’ve never spent any time mixing and matching the internal parts, but I attempted anyway. I put my old crankshaft into unit with the new cylinder head, and even though it will start, I cannot keep it running and lost interest in my ability to rebuilt 2 stroke motors.
So, at the very least I have some good os 46 ax parts, but if you’re better than me with isolating problems and rebuilding these things, you may end up with a reliable glow motor. The crank shaft seen in the photo is the bent one, and I will ship as it with prop nut/washer. The needle stay bracket is also cracked on the disassembled motor.
Also included are two used mufflers (1- E370 and 1-873).
Please note, I will accept paypal only and will ship USPS in a flat rate box Tuesday due to the Monday Holiday.
Cheers..Hutch
hutchis is offline Find More Posts by hutchis
Old Feb 17, 2013, 09:25 AM
racerob is offline
Find More Posts by racerob
Trader Rating: 24
United States, TN, Smyrna
Joined Nov 2012
Trader Rating: 24
Os 46
PM sent. Thanks, Robert.
racerob is offline Find More Posts by racerob
OS Ax 46 versus OS Fx 46 Engines pjm21b Engines 16 Jun 18, 2014 02:02 AM
Sold os 46 ax parts all 4 shipped 25.00 bendix1 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 07, 2013 04:54 PM
Sold OS 46 AX Like new Grandstand Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 18, 2013 12:05 PM
Sold Pitts muffler -os 46 ax Grandstand Aircraft - Fuel - Engines and Accessories (FS/W) 6 Jan 18, 2013 11:51 AM
Sold OS 46 AX engine parts pa34250 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 08, 2012 08:36 AM
