This thread is privately moderated by wingloada, who may elect to delete unwanted replies.
Old Feb 16, 2013, 04:48 PM
wingloada is offline
Find More Posts by wingloada
wingloada's Avatar
United States, MD, Lutherville-Timonium
Joined Apr 2012
Vivace - 100" Elliptical wing glider/e-glider prototype
Vivace - 100" Elliptical wing glider/eglider prototype design:
Influenced by Dr. Mark Drela's Allegro Lite design with high aspect ratio elliptical flying surfaces. Vivace (lively) is a musical modifier of Allegro (as in Allegro Vivace - fast and lively).
Updated 3-30-13
Modified April 7, 2013 -- larger wing control surfaces, corrected shear web dimensions, and redrew wing ribs.
Modified May 5, 2013 -- edited the wooden fuselage design for longer nose moment.
Modified May 12, 2013 -- Moved indicated CG
Modified May 18, 2013 -- Straightened center section spar so that no angled joint is needed at the center of the CF spar caps.
Modified May 31 -- finer line weight in pdf.
Modified 1-18-14 -- Corrected mis-drawn spar cap cutouts in ribs W1-W7.
Modified 2-10-14 -- Corrected slightly mis-drawn rib length dimensions
pdf: http://wkleinsasser.net/download/Vivace_100_pdf.zip
Drawing files and part cut sheets:
http://wkleinsasser.net/download/Vivace_100.zip
126" larger wing option
Modified 6-23-13 -- Added enlarged tail section proportional to wing increase from original 100" design.
Modified 7-5-13 -- Corrections to the drawings.
Modified 7-15-13 -- Simplified stab construction, added lost foam fuselage for electric version.
Modified 7-16-13 -- Clarified parts for built up stab and fin-rudder.
Modified 7-28-13 -- Minor corrections as prototype build progresses.
Modified 7-28-13 -- Specifications added and outer panel aileron spar dimensions added.
Modified 8-10-13 -- FIxed some mistakes in the electric lost foam fuselage drawing.
Modified 8-14-13 -- Added a lost foam pod with wing pylon fuselage drawing.
Modified 1-8-14 -- Scaled and separated pdfs to print at full scale on 144" X 36" paper
pdf: http://wkleinsasser.net/download/Vivace_126_pdf.zip
100" larger area clipped-wing option
pdf: http://wkleinsasser.net/download/Viv...ipped_wing.pdf
If you have an Allegro Lite and just want to try out the Vivace wing with it,
here is a modification I have drawn that should mount directly on an Allegro
Lite fuselage (the bolt-beam mounting holes should align). I'm not certain that
the Allegro Lite fuselage has room for the wiring from the four-servo wing,
though.
pdf:
http://wkleinsasser.net/download/Viv...e_fuselage.pdf
Drawing file with parts cut sheets:
http://wkleinsasser.net/download/Viv...e_fuselage.zip
As always all suggestions for improvements are welcome.
W
Photos below
wingloada is offline Find More Posts by wingloada
Old Feb 16, 2013, 04:58 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Nice job
Thanks for sharing, I am sure it was a lot of work.
Do you have a name in mind? It deserves something better than 100" Elliptical wing Glider
pmackenzie is offline Find More Posts by pmackenzie
Old Feb 16, 2013, 06:17 PM
wingloada's Avatar
Joined Apr 2012
Thanks, pmackensie. Yeah, you're probably right. I'll have to give it some thought.
W
Old Mar 05, 2013, 06:10 PM
wingloada's Avatar
Joined Apr 2012
Vivace (lively) is an Italian modifier of Allegro (fast).
W
Old Apr 07, 2013, 03:10 AM
leons is offline
Find More Posts by leons
украина , чернигов
Joined Feb 2011
super glider , video?
leons is offline Find More Posts by leons
Old Apr 07, 2013, 06:51 PM
wingloada's Avatar
Joined Apr 2012
No flights yet, leons :-). I'll try to take someone with me for video. The weather is definitely getting better here.
I really liked the way your video showed the agility of the Allegro modification that you made. I was inspired by your design to re-draw the Vivace with larger flaps and ailerons. I think the prototype will be OK, but the larger areas will allow for less angular deflection for the same control, I think. The flaps and ailerons are now about 25% of the chord, which is closer to Mark Drela's Supra proportions. We'll see if I have the stamina to build another wing.
W
Old Apr 10, 2013, 02:16 PM
leons is offline
украина , чернигов
Joined Feb 2011
also wanted to make the ellipse but you Wingloada ahead of me
really like how the end of the aileron
with the new year I will do Vivace
Old Aug 09, 2013, 07:05 PM
CoolCanuck is offline
Find More Posts by CoolCanuck
CoolCanuck's Avatar
Canada, BC, Kelowna
Joined Jun 2006
Any progress reports on this one?
CoolCanuck is offline Find More Posts by CoolCanuck
Sold Rare - Klingberg Wing 6' 6" wing NIB Future Flight. Glider / Sailplane sst2000 Aircraft - Sailplanes (FS/W) 3 Feb 17, 2013 01:23 PM
Sold 2 meter 2 ch glider $100.00 woodyflight Aircraft - Sailplanes (FS/W) 0 Jan 09, 2013 05:37 AM
Why do elliptical wings get a bad rap? Joel K. Scholz Modeling Science 14 May 09, 2003 05:10 PM
Quick'n'dirty way to find area of elliptical wing? tim hooper Electric Plane Talk 5 Apr 10, 2003 05:28 PM
Elliptical wings aft_cg Foamies (Kits) 5 Nov 03, 2002 12:31 AM
