Old Feb 16, 2013, 01:41 PM
DonB
SC
Joined Feb 2009
Separate power source for Rx and Servos
I have read several times of having separate power sources for Rx and Servos. The only way I can see of doing so is combining all the B+ power leads to the servoes to a separate battery? There must be an easier way, does someone make a device where this is possible, like a breakout box etc?
Thanx
Don
mentor34 is offline Find More Posts by mentor34
Old Feb 16, 2013, 02:26 PM
Florida
Joined Aug 2004
I do not know what you mean by B+ power leads. I assume you are flying a model powered by and ESC (electronic speed control) that now has a built in power reduction for your receiver and servos. If so, and you want to power the servos and receiver by a separate battery, all you have to do is break the red lead connection between the ESC and receiver by either just cutting it in two or by removing that pin (the center connector) from the housing by carefully lifting the locking tab holding it into the housing and pulling the lead out of the housing. Then just connect any 4 or 5 cell Nixx battery to any unused port on the receiver (or connect it to a port already in use through a Y harness). Put a switch in line with the added battery for convenience in using it and charging it.
Rodney is offline Find More Posts by Rodney
Old Feb 17, 2013, 03:54 AM
DonB
SC
Joined Feb 2009
B+ is the positive side of the battery. Thanx for you help.
Don
Old Feb 17, 2013, 01:44 PM
Letchworth, Great Britain (UK)
Joined Jul 2004
I use separate power source for electric retracts. I do this by splicing another negative lead to the original negative; then signal and one negative lead go to the receiver, and positive and the other negative lead go to the alternate power source.
A simple board could be made with 1/10"-spacing copper strip board with header pins soldered in, if you want to connect multiple servos to the alternate supply.
abenn is offline Find More Posts by abenn
Old Feb 17, 2013, 07:01 PM
United States, OH, Holland
Joined Jan 2006
EMS sells a device manufactured by JOMAR products called a "glitch buster" that allows you to optically couple the servos to the receiver and power the receiver from one battery and the servos from another.
Check the web site for EMS.
ace1flyer is offline Find More Posts by ace1flyer
Old Mar 10, 2013, 05:12 PM
Canada, ON
Joined Aug 2012
abenn...........I have installed EFlite electric retracts in a P51 Mustang and want to power the retracts with a separate retract battery. I already use a separate Rx battery.
South Ontario had the same heat and drought as the U.S. Midwest last summer and you only have to see one electric go in full bore from 200 feet because its BEC overheated to realize there is a problem that must be fixed. Separate batteries all around.
I want to make sure I understand your retract wiring for a separate retract battery. Pull the red pin on the plug coming from the retracts and going into the Gear channel in the Rx. Splice a black wire onto the black negative wire in the Gear plug. Plug the original black/signal into the Rx gear channel. Attach the original red wire and the new black spliced wire to the separate retract battery.
Do I have that correct?
Bill
erie_flyer is offline Find More Posts by erie_flyer
Old Mar 10, 2013, 10:27 PM
Joensuu, Finland
Joined Mar 2002
Originally Posted by erie_flyer View Post
...I want to make sure I understand your retract wiring for a separate retract battery. Pull the red pin on the plug coming from the retracts and going into the Gear channel in the Rx. Splice a black wire onto the black negative wire in the Gear plug. Plug the original black/signal into the Rx gear channel. Attach the original red wire and the new black spliced wire to the separate retract battery.
Bill
This is correct.
jkettu is offline Find More Posts by jkettu
Old Mar 11, 2013, 03:17 AM
Joined Jul 2004
You have it correct Bill.
If you don't want to mess around with the leads on your retracts you can make up a simple Y-harness with the red lead missing on one leg and the white lead missing on the other. Unfortunately you can't simply cut the wires on a regular Y-harness because the plugs will be the wrong gender -- you need a regular servo plug on the leg that's going to the receiver, a socket to take the plug on the leg that's going to the battery or alternate power source, and a regular servo socket on the leg that the retract plugs into.
Old Mar 11, 2013, 10:15 AM
Canada, ON
Joined Aug 2012
I have in my hand a JR factory-built Y harness with one male plug and two female sockets so it would appear to be the proper design for a separate retract battery.
Bill
Old Mar 11, 2013, 12:33 PM
Joined Jul 2004
Only if the bottom of the Y has a socket on it, and the two branches are one socket and one male plug.
A "standard" Y-harness has two sockets on its branches to accept two servos, and one male plug at the bottom to go into the receiver. We want it to work the other way round in our case, and to have a female socket at the bottom to plug the retract into, male plug on one branch for white & black wires to the receiver, and a female socket on the other branch to accept the normal plug from the alternate power supply.
If yours does have the right plugs and sockets, then just pull out the red wire from the receiver plug.
Old Mar 11, 2013, 01:47 PM
Canada, ON
Joined Aug 2012
Yep, done deal. Pulled the red wire on the male Y-harness Rx plug and insulated it with some heatshrink so it doesn`t short out against something. Put an Rx switch on the female battery plug.
Electric retracts cycling nicely.
I use a 5 cell 6.0 volt NiMH on the electric retracts, 4.8 volts won`t cycle them reliably. Use a 4.8 volt NiMH on the Rx with the red wire pulled and insulated on the male Rx plug coming from the ESC.
Bill
Help! Power Source for 10S LiPo not working... gln6f Batteries and Chargers 16 Mar 01, 2013 03:12 PM
Discussion LiFEPO4 power for Rx and servos? grosbeak Fuel Plane Talk 5 Jan 20, 2013 08:52 PM
Question Going Separates: Q re Power for RX cosgrove Micro Helis 2 Sep 30, 2010 06:34 PM
New Product New RX Power Source for our jets Ron101 Electric Ducted Fan Jet Talk 52 Feb 23, 2010 12:45 PM
Discussion best power source for the ar2000 rx? jaymillwall Beginner Training Area (Fuel) 5 Jun 30, 2009 02:37 PM
