Old Feb 16, 2013, 11:57 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
wing area X % scale =?
Maybe I didn't put i down quite right, but what I would like to know is this?
If you are going to increase the overall size of a plane by say 150%, and you have a given wing area (sq in) , how do you figure the new area out? A x 150%, just doesn't seem right.
TIA
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 16, 2013, 12:12 PM
ShoeDLG is online now
Find More Posts by ShoeDLG
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
If you increase all dimensions by 150%, then you will increase the wing area by: 1.5x1.5 = 2.25, or 225%.
ShoeDLG is online now Find More Posts by ShoeDLG
Old Feb 16, 2013, 12:37 PM
Joined Dec 2008
I was thinking it had something to do with being "squared" , just not sure on what and how. Now I have learned my one new thing for the day!!
Old Feb 16, 2013, 02:40 PM
Rodney is online now
Find More Posts by Rodney
Florida
Joined Aug 2004
Your thinking was correct. The increase would be 1.5 squared or 2.3 times the original area. If you wanted to have the new size to have 150% as much area as the original you would increase the linear dimensions by the square root of 1.5 or 1.2247 times.
Rodney is online now Find More Posts by Rodney
Old Apr 15, 2013, 10:59 AM
Joined Dec 2008
OK, here's one more question. I'm trying to find sq.in (wing area) of a model which is 8.79% scale. Full size plane is 202 sq.ft. So do I take 8.79 x 8.79= 77.26/202=2.61 x144=375.84 sq.in.?
Old Apr 15, 2013, 01:16 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
You need to convert the % to a decimal. So 8.79% is actually .0879.
So it's the size change squared times the full size area in sq feet times the conversion from sq ft to sq inches. Or;
.0879^2 x 202 sq feet x 144 sqin/sqft = 225 sq inches
BMatthews is online now Find More Posts by BMatthews
Old May 23, 2013, 06:36 PM
Joined Dec 2008
Thanks for the help guys, but I'm doing something wrong here.
Where I think I'm going wrong is in figuring the scale. The full size plane has a WS of 40ft or 480" and 400sq/ft. . Model has WS of 53" -----sqft?
I took 53/480=9.056
So, using BMatthews formula .0905^2 x 400 sq/ft x 144 sqin/sqft = 471.7sqin
Now if I take 44.5" WS/480 =10.78
then .1078^2 x 400sqft x 144sqin/s1ft =669.3sqin? -shorter wing with more sqin? WRONG.
It has to be something simple I'm missing, HELP Please.
Old May 24, 2013, 02:02 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
You're calculating the scale factor NOT the percentage change. Effectively your division is upside down which is why the calculations go astray.
Scale factor is Original size / Model size. 480 / 53 = 9.056
Percentage change is Model size/Original size (x 100)
53 / 480 = .1104 (or 11.04 %)
44.5 / 480 = .0927 (or 9.27%)
The percentage change also equals 100 / scale factor. I.e. if scale factor is 4 that's 100/4 or 25%, if scale factor is 8 that's 100/8 or 12.5%. For 53" span you got a scale factor of 9.056, which is a percentage change of 100/9.056 or 11.04
Steve
slipstick is online now Find More Posts by slipstick
Old May 24, 2013, 02:10 AM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
EDITED - I was being a numbnuts...
MCarlton is offline Find More Posts by MCarlton
Old May 24, 2013, 05:18 AM
Joined Dec 2008
slipstick, Thanks much, I knew something was astry, just could not pin point it.
To some it may seem a "Stupid"question, but I can't be the only one who doesn't/didn't know! It may help others later on, in a their quest for knowledge!
Having gotten the solution,I see where I went wrong-
The dividend is the number that is being divided. The divisor is the number that the dividend will be divided by. Had to look it up, it's been a long time since I have seen the inside of a classroom!!
For Sale X-83 flyjet seattle area lectroglide Aircraft - Electric - Airplanes (FS/W) 2 Mar 11, 2013 01:29 PM
.25 Low wing trainer LPU Sacramento area gravityking Non R/C Items (FS/W) 7 Feb 12, 2013 06:36 PM
Question Scale flying in the Los Angeles area firespit Scale Sailplanes 3 Jan 25, 2013 08:43 PM
Sold X-83 flyjet seattle area lectroglide Aircraft - Electric - Airplanes (FS/W) 2 Jan 18, 2013 08:04 AM
How do you scale down the wing area? Frank B Modeling Science 2 Nov 18, 2004 06:13 AM
