Old Feb 15, 2013, 10:55 PM
gln6f is offline
Find More Posts by gln6f
Joined Feb 2013
Mini-HowTo
How can I tell the propeller direction?
Hello, I have a very newbie question. When you put a propeller on your motor, how can you tell which way is 'forward'? Forward as in facing the flight path.
gln6f is offline Find More Posts by gln6f
Old Feb 15, 2013, 11:32 PM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
If there is any text on the prop (size markings etc.), the text side should face forward.
To verify: the blades have an airfoil shape - one side is essentially straight and the other has a noticable convex curve. The curved side should face forward.
jkettu is offline Find More Posts by jkettu
Old Feb 15, 2013, 11:33 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Generally, the numbers and lettering will be on the front face of the prop. This applies to APC, GWS, Master Airscrew, Graupner, Xoar, GM, Zinger, Top Flite, and most other brands, but there are a few oddballs.
The most foolproof way is to determine which side of the prop is the convex side. The blades' convex faces always, ALWAYS face forward. Somebody here has a nice little image that shows the concept pretty well. It'll probably get posted soon.
Piece is online now Find More Posts by Piece
Old Feb 15, 2013, 11:34 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
Jkettu posted while I was typing... and, incidentally, posted almost exactly the same thing.
Old Feb 16, 2013, 10:26 AM
Ginohio is offline
Find More Posts by Ginohio
Ginohio's Avatar
United States, OH
Joined Mar 2012
Here ya go.
Ginohio is offline Find More Posts by Ginohio
Old Feb 16, 2013, 04:47 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
Yup, that one
Old Feb 17, 2013, 10:38 PM
aurorae is offline
Find More Posts by aurorae
aurorae's Avatar
Joined Sep 2008
After you put the prop on correctly, if the motor runs backwards, if you have a brushless motor just swap any 2 of the 3 wires.
aurorae is offline Find More Posts by aurorae
Old Feb 18, 2013, 09:30 AM
villapilote is offline
Find More Posts by villapilote
Wilson, NC
Joined Aug 2009
What most people do not realize is that a prop mounted backward, but turning in the correct direction, will still push/pull air in the correct direction, but the quantity of air pushed/pulled will be greatly reduced. I have seen a model takeoff, with the prop unknowingly mounted backward. The plane was extremly sluggish, but it did fly.
villapilote is offline Find More Posts by villapilote
Old Feb 18, 2013, 10:28 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Simple method.
A boat going backwards cavitates. The backside of a plane propeller is concave, the word "cave" appears in both cavitate and concave.
dedStik is offline Find More Posts by dedStik
Old Feb 20, 2013, 12:29 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Originally Posted by dedStik View Post
Simple method.
I remember it by "you can always go into a cave"
bartricky is offline Find More Posts by bartricky
Old Feb 20, 2013, 01:26 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Simple method.
I hate to be a party pooper but 'cave' doesn't appear in 'cavitate'... At least not unless you jumble the letters around a bit
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Feb 21, 2013, 08:45 AM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
there you go pooping on the party again
fastfwd is offline Find More Posts by fastfwd
Old Feb 21, 2013, 09:10 AM
dedStik is offline
dedStik's Avatar
Joined Feb 2012
/me passes the tp
The root 'cav' is close enough to work as a mnemonic device.
I'm just glad I didn't misspell it and write cavities.
Old Feb 27, 2013, 04:30 PM
gln6f is offline
Joined Feb 2013
Sorry about the late post, I've been crazy busy with a new job. Good to know and thank you all.
Old Feb 28, 2013, 05:29 AM
benlinus is offline
Find More Posts by benlinus
Joined Feb 2013
Propellers are described as left- or right-handed. Left-handed propellers rotate counterclockwise and are known as "counter-rotating propellers." When the boat with a left-handed propeller backs up, it pulls to the left. When a boat with a right-handed propeller backs up, it pulls to the right.
nstructions
1
Look at the propeller mounted on the motor. When seen from above, the leading edge of a right-handed propeller is to the right of its trailing edge. The leading edge of a left-handed propeller is to the left of its trailing edge.
2
Start the motor and watch, from astern of the motor, the direction in which the propeller turns. A left-handed propeller rotates counterclockwise; a right-handed propeller rotates clockwise.
3
Put the boat in reverse, turn the motor so that it's centered and back the boat up at idle speed. If the stern pulls to starboard, the right side of the boat, it's a left-handed propeller. If it pulls to port, it's right-handed.
benlinus is offline Find More Posts by benlinus
Reply With Quote  (Disabled)
Discussion How Can You Tell If Your Sport Plane CG is Set Properly When In Flight? itsme2 Electric Plane Talk 18 Feb 16, 2013 09:58 PM
Discussion how can you actually tell if a prop shaft is bent? allisonmo2 Micro Ready-to-Fly 7 Feb 02, 2013 07:01 AM
Discussion Can anyone Tell me more about this Car? Aero Ace Electric Power Cars 8 Jan 30, 2013 11:36 AM
Help! wind, how much can i fly in, how can i tell if its to much glenn297 Beginner Training Area (Fuel) 22 Jul 31, 2009 11:28 PM
How to tell if the Propeller is on right.... George-Maxwell Beginner Training Area (Aircraft-Electric) 3 Jun 06, 2005 10:34 PM
