Old Feb 15, 2013, 10:07 PM
CoolCanuck is offline
Find More Posts by CoolCanuck
CoolCanuck's Avatar
Canada, BC, Kelowna
Joined Jun 2006
Looking for a 12.5x4 folding prop
Anyone knows who makes a 12.5x4 folding prop?
Looking to install on my 2m Simprop Excel Competition (first series fiberglass fuselage, with built-up wing), using a C3542/06 KV100 // SK3536/05 KV1400 or SK3548/03 KV1100), on 3 / 2 or 5 cells respectively.
My calcs show that this would make interesting combinations ...
I thought there was a CAM one available, but can't seem to find one.
CoolCanuck is offline Find More Posts by CoolCanuck
Old Feb 16, 2013, 01:26 AM
CoolCanuck's Avatar
Canada, BC, Kelowna
Joined Jun 2006
Thanks Rick. Aware of those.
I already have an Aeronaut 12.5x6, hence looking for the 4"pitch.
Old Feb 16, 2013, 04:14 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
The white Aeronaut 12* 7 folder has a real life pitch much closer to 5 than 7 and may be exactly what you're after. You could use a twisted aeronaut yoke to fine-tune it even further , here's a list with measured values for the black/carbon props...(in cm ....)
http://www.aero-naut.de/fileadmin/do...eichswerte.xls
WimH is offline Find More Posts by WimH
Old Feb 16, 2013, 02:10 PM
CoolCanuck's Avatar
Canada, BC, Kelowna
Joined Jun 2006
Thanks Wim. I'll have to investigate this a bit further and educate myself. Never considered offset yokes before.
Old Feb 16, 2013, 04:33 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
There is a good reason why they don't make many props like a 12.5x4---they are best suited for applying epoxy than to spinning on the nose of your plane. Anything below a .5 pitch-diameter ratio is not good for things that fly. Props like that will give lots of static thrust but once the plane is moving things go bad. Better to get a smaller diameter prop with more pitch. As a general rule you want a PD of .75 or more.
Steve Neu
Steve
sneu is offline Find More Posts by sneu
Old Feb 16, 2013, 09:14 PM
vil64 is offline
Find More Posts by vil64
vil64's Avatar
Joined Nov 2012
Hey guys, this is what I'm looking for. I've got 2m moldie and would like to use Neu 1110/1y/6.7 motor. Can somebody tell me what would be the smallest folder you can run on this with high pitch for speed.
vil64 is offline Find More Posts by vil64
Old Feb 17, 2013, 12:57 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Steve Neu
Steve
Not valid for all cases.
In multicopters the lowest PD possible is the most sought. 12x3.8 is the most obvious example that comes now, but also 17x5 are available.
Yes, this application field means lots of static thrust, and (apparently) zero speed.
But I think it is valid for gliders propulsion too. I climb better with a 13x5 than with a 12x6.5, same MVVS 960kv motor.
renatoa is online now Find More Posts by renatoa
Old Feb 17, 2013, 12:29 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
A PD prop is like a plane stuck in 1st gear--lots of pull at the start but is quickly hits the wall and stops accelerating. The one place low PD makes sense is for static operation--like the quad copters but gliders are better with higher PD props.
Steve Neu
Old Feb 17, 2013, 12:30 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
How many cells?
Old Feb 18, 2013, 03:09 AM
vil64 is offline
vil64's Avatar
Joined Nov 2012
Planning 3cell 2200mAh
Old Feb 18, 2013, 07:54 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
There are F5D pylon props that are 11x22 that would give you around 140mph prop pitch speed. http://www.neumotors.com/store/page11/index.html
If those are over the top then I would be looking at a 12.5x13 of 15x16 from SUSA http://www.soaringusa.com/Props/?page=11
Steve Neu
Old Feb 19, 2013, 03:43 AM
vil64 is offline
vil64's Avatar
Joined Nov 2012
Thanks Steve, that's the info I was looking for.
Old Mar 11, 2013, 05:31 AM
vil64 is offline
vil64's Avatar
Joined Nov 2012
Hi Steve, I have just changed my mind and plan to use Neu 1105/2.4y/4.4:1 instead of 1110/1y/6.7. Still, I will use 2200mAh 3S. Could you please let me know what could be the smallest folding prop I can use for speed. This is going to a 2m Spirit E glider/hotliner.
Old Mar 11, 2013, 09:41 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
Steve Neu
Awesome analogy.... I think this is a great way to describe it.
ScottSails is offline Find More Posts by ScottSails
Question Looking for 1mm shaft folding prop adapter rdeis Scratchbuilt Indoor and Micro Models 7 Jan 24, 2013 09:41 PM
Wanted I'm looking for a folding prop spinner mikez64 Aircraft - General - Miscellaneous (FS/W) 2 Jan 16, 2013 08:23 AM
Question Looking For A 4.5x4.5 Prop Bookstar75 Power Systems 5 Jan 17, 2010 09:20 PM
Question Looking For a 5x4 speed prop Bookstar75 Power Systems 6 Mar 13, 2009 11:15 PM
replacement prop for potensky folding 9.5x4.7 tduro Power Systems 1 Nov 14, 2005 07:48 PM
