Old Feb 15, 2013, 10:03 PM
bill clark is online now
Find More Posts by bill clark
WingsTiresTitsGunaGiveYaT ruble
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
hypothetical on "C" rating
I have a setup that pulls about 30 amps and initially holds 10.75v on a TP 25/50c (33.7/67.5a) 1300mah pack. If I get a 1350 65/130c (58/117a) pack about how much voltage should I expect it to hold?........roughly. 11.5 volts????
bill clark is online now Find More Posts by bill clark
Old Feb 15, 2013, 11:54 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
you will pretty much have to try it , just because it says 65c don't meen its so ...
Dennis Everett is offline Find More Posts by Dennis Everett
Old Feb 16, 2013, 12:10 AM
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
I kinda figured it would be a try and see but thought someone might have some experience with it. I'm pretty confident the thunderpowers are gonna be on the top of the pile as far as realistic ratings judging by how strong their new 25c's are. ecalq says about .75v. will see tommorrow
Old Feb 16, 2013, 08:51 AM
Wintr is online now
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Let's assume 65C is more than just marketing, and means that it is determined by the current that can be drawn while keeping the cell voltages safe, say 2.9V each (that may be too low for today's batteries). So, 65C would mean 87.75 amps at a drop of about 3.8V gives a total IR, including wire and solder connections, of about .043 ohms. That means, at 30 amps, there would be a drop of about 1.3V, so the predicted voltage would be about 11.2V, under ideal conditions. Take your measurements, and you will see how real that 65C number is in practice.
Wintr is online now Find More Posts by Wintr
Old Feb 16, 2013, 09:01 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Huh?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Feb 16, 2013, 09:49 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
"Holds a voltage", not exactly, it is continuously decreasing from the time the plane takes off to the time it lands.
Check out these discharge graphs, all at a 30A draw, packs ranging from 25-65C (If I read that correctly). http://www.rcgroups.com/forums/showp...15&postcount=1
Looks like the difference is about 0.2V(3s pack) between the highest and lowest pack voltage at any time during discharge.
hoppy is offline Find More Posts by hoppy
Old Feb 16, 2013, 11:10 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Just use the Discharge/IR calculator to see what you really have and what you need. Takes all the guesswork out of LiPo selection. http://www.jj604.com/LiPoTool/
RC Man is online now Find More Posts by RC Man
Old Feb 16, 2013, 11:48 AM
Wintr is online now
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Originally Posted by goldsworthy View Post
Huh?
That was a thought experiment, assuming all the resistance of the battery system is accounted for in the C rating, which it is not. I made that assumption just to simplify the math, so I could illustrate just how small an effect that more than doubling the C rating would have on voltage drop. In this simplified world, his voltage drop was about 1.75V, and the estimated drop is 1.3V. In reality, the IR of the battery system is very dependent on quality of connections, the wires, and connector used, so the estimated drop should be much closer to his original reading, if all those factors were taken into account. Even that calculation would be ignoring the effects of the chemistry of the battery, as current is drawn from it.
Old Feb 16, 2013, 03:32 PM
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
I'm cycling the new 65c battery on the charger now (dont know if its needed but thats what i've always done) so I should have some data this evening. I usually dont use these high c batts but I need to put this little pig of an airplane on a serious diet so I'm reducing the capacity by a bunch which means my amp draw is getting close to the c rating with the 25c.
I have been flying electrics for about 6yrs and never had the ability to check IR. My chargers are doing fine so a stand alone unit would be nice. is there anything out there? something cheaper than a new charger with the feature.
thanks for the information above
Old Feb 16, 2013, 06:06 PM
Wayne Giles is online now
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Bill,
I build these as hobby. Not particularly cheap but accurate, very quick reading and capable of much higher resolution than most chargers.
PM me if you are interested.
http://www.rcgroups.com/forums/showp...&postcount=249
Wayne
Wayne Giles is online now Find More Posts by Wayne Giles
Question C ratings ????? jonspot25 Batteries and Chargers 3 Feb 05, 2013 09:59 PM
Discussion Relationship between C rating and amps you can charge at? cloud_9 Batteries and Chargers 33 Feb 04, 2013 09:29 PM
Discussion Need Advise on what C rating for this system set up! chopper52 Electric Ducted Fan Jet Talk 1 Jan 12, 2013 01:09 PM
Wanted 4s 2350-2700 mAh with high C rating and Deans clip TheMagician007 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 08, 2013 11:24 PM
Question Charging rates based on "C" rating jeb6684 Batteries and Chargers 6 Aug 22, 2012 09:31 AM
