Old Feb 15, 2013, 04:22 PM
RogueAce is offline
Find More Posts by RogueAce
Air Assassin
RogueAce's Avatar
United States, FL, Pompano Beach
Joined Oct 2012
Build Log
55mm Sabre
OK ...I decided to use the 55mm unit left from 1st Ronin in a Sabre. Always loved this plane. No good plans anywhere, so this is a real scratch build. SloperJoe did a box-build like it and it waas SWEET! Taking his lead and just using some pics for guidance. It will be 25"WS , 25" long. 55mm w/ 3000kv and a 11.1V 2200mah going through a 45A esc w/seperate Bec. Guesstimate weight is 1-1/2 to 2 lbs . Ails and regular elvs. Carbon spar in wing and balsa leading edges all round.
RogueAce is offline Find More Posts by RogueAce
Old Feb 15, 2013, 04:42 PM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
I think you need higher kv motor 3700 to 4000kva need keep it light 16oz Id run switching bec ESC LESS WT.
space 1 is offline Find More Posts by space 1
Old Feb 15, 2013, 07:29 PM
TANGOSIERRAROM is offline
Find More Posts by TANGOSIERRAROM
James L
TANGOSIERRAROM's Avatar
Beck Row Mildenhall
Joined Mar 2009
on a on gws 55mm I now run 5000 kv motors on 3s 600 grams thrust installed not too shabby
TANGOSIERRAROM is offline Find More Posts by TANGOSIERRAROM
Old Feb 15, 2013, 08:17 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
My bad on the Kv size guys..it's a 4300Kv. Oh and as before I'm using $Tree foam. Thanx for the catch guys.
Old Feb 15, 2013, 08:36 PM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
I was just thinking of doing a 50mm size "Box Frame" Mig-17 or F-86, only I was thinking of using a 7800KV motor coupled with a SkyAngels fan unit.
have the motor and fan now on a 25amp ESC, and running 1000-1300mah 2s 40C pack.....REALY good thrust, 10,000 rpm or so more than the stock motor with one less cell to carry and about the same amp draw as stock, and it is VERY LOUD on a static run
this is my new experiment, and so far it looks promising.
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Feb 16, 2013, 10:27 AM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Hey SloperJoe..how far back ,or forward did you place unit? I was looking at having the leading edge of unit at the rear edge of wing. I saw where you had fun trying to get CG set as plane was tailheavy.
Old Feb 16, 2013, 01:46 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
When I design my models I put the fan at the front of the fan at the trailing edge of the wing and never had problems with CG. I think you will be happy with this location.
Eric B.
AirX is offline Find More Posts by AirX
Old Feb 16, 2013, 02:14 PM
sloperjoe's Avatar
Joined Mar 2012
I put it right behind the root trailing edge, the plane didnt have a CG problem....I did ,for some reason I thought I had to have a nickle glued to the tail end for balance...after several tosses and battery adjustments I realized I really didnt need it, once I popped the nickle off the tail it flew great
Joe
Old Feb 16, 2013, 03:16 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
The Aeo OR Gws 55mm with the Adh300 motor @4300 kv .. Will work 'fine'.
When / if you need mo' go, use a 4S battery.
Bare is offline Find More Posts by Bare
Old Feb 16, 2013, 03:25 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Thanx as always for the input guys.
Old Feb 16, 2013, 03:49 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Progress on Sabre: All leading edges and hinge areas got balsa. Carbon spar installed and first coat filled. Took some pics of rough idea. Gonna go w/servo for each ail and elv.
Old Feb 16, 2013, 03:55 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Here are some more pics of progress. Hey Cooler ,here's where the Subterrain is so usefull.
Old Feb 16, 2013, 04:45 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Just put my order in for the Subterrain. My LHS did have it, but not some of the other items I wanted. Even at that, I will have it before I"m ready for it!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 17, 2013, 05:50 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Sanding ..the necessary evil! All control surfaces sanded to airfoil. Wingtips got final cut , shape and sanded. Yes washout too ! Adjusted tail section a smidge, slid it back a bit on fuse. Sanded and shaped interior ducting for intake and exhaust.
Old Feb 19, 2013, 01:25 PM
RogueAce is offline
Air Assassin
RogueAce's Avatar
Joined Oct 2012
Today's progress and headaches: Ails and Elevs hinged & sculpted the heck out of the canopy! Now where to fit all this stuff?!?!!?? (Not ESC that will be used.) I'm thinking of hollowing out the botttom of the canopy to hold batt. The ESC will be behind fan gettng the exhaust flow. The wiring haness won't be long , but will be tricky to confine.
Sold Like New Canon Rebel T3i Digital SLR with IS 18-55mm Lens cbcalhoun Non R/C Items (FS/W) 6 Feb 18, 2013 05:11 AM
Sold EDF lot 55MM hi2nr Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2013 01:38 PM
For Sale BRAND NEW Canon EF-S 18-55mm F/3.5~5.6 IS II,18-55mm IS2 Lens scoobiemario Non R/C Items (FS/W) 3 Oct 29, 2011 10:06 AM
