Old Feb 15, 2013, 04:22 PM
dma251 is offline
Find More Posts by dma251
Joined Feb 2006
Can someone explain how higher Mah batteries make a car faster?
I am pretty well versed in electricity, so it intrigues me how increasing battery mah affects anything other then run time. Increasing voltage would increase output (until failure), but the motor draws whatever current it draws. How does the batteries milliamp capacity affect performance?
dma251 is offline Find More Posts by dma251
Old Feb 15, 2013, 04:28 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
It reduces the voltage drop under load. The C rating is actually defined as the maximum current you can pull without suffering a significant voltage drop. It is an actual number, but it's expressed as a factor of the capacity, so when the capacity goes up, so does the C rating, not the factor, the actual number.
So, a 30C 1000mah has a C rating of 30 amps, but the 30C 2000mah has a C rating of 60 amps. So your 30 amp car will cause a significant voltage drop on the small battery, but not on the big one. Same c factor, different c rating.
jasmine2501 is offline Find More Posts by jasmine2501
Old Feb 15, 2013, 06:28 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ What he said. Voltage drop under load at close to the packs happy limit will be pretty bad, so having more amperage available will greatly reduce the voltage drop.
wparsons is offline Find More Posts by wparsons
Old Feb 15, 2013, 09:04 PM
Rocket Programmer
Joined Jul 2007
There is a point of diminishing return...
Say you have a 30-amp truck and you're running a 5000mAh 35C battery, like I run in my 1/10th truck. That battery won't experience a significant voltage drop until you pull around 175 amps, so my truck isn't even stressing that battery at all. If I put a 10,000 mAh battery, all that will happen is I will add weight, and the truck will go slower. So, it's only true if your truck is currently being limited by the battery you're running. If that is not the case, then yes, a bigger battery will slow you down. That's why racing is so much fun... so many trade offs to shave those seconds
Old Feb 18, 2013, 05:43 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
RC batteries are generally rated by Ah (mAh) and "C". "C" is a horrible rating since it's really just a relative discarge rate and what is more important is Ah*C which computes the amp rating of the pack. Pulling more amps than Ah*"C" on a continious basis will cause strain on the pack, premature aging, voltage sag, and limit the total capacity you can safely extract from the pack.
If your battery Ah*C is higher than the amps that your ESC/Motor can pull then going with a bigger battery will probably not produce any differences. There would be a tiny difference in voltage drop over time which would probably have a minimal effect in overall speed.
If your battery Ah*C isn't high enough you can get more amps in two ways, go with a higher C rating or a larger Ah, both will allow you to safely pull more amps.
brontide is offline Find More Posts by brontide
Old Feb 18, 2013, 06:31 PM
Rocket Programmer
Joined Jul 2007
Brontide, that's why i made it clear that the C rating is the actual number of amps, not the factor. That's just how it's expressed, so the C rating is 40 amps or whatever, it's not the number before the C.
Old Feb 19, 2013, 02:16 AM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I understand you are trying to make it easier to grasp, but talking about a seperate C-rating and C-Factor isn't helping, I think, it just makes it more confusing. A C-rating is not in Amps, it's just a number. The C number is simply what you need to multiply the battery's capacity with to get the current this battery can deliver without it's voltage collapsing and/or the battery overheating.
You can't simplify that, the only way to determine how much current a battery can deliver is by simple math, a single calcucation. The outcome of that calculation is what matters. C-rating without taking into consideration the capacity of the battery means nothing, and capacity alone means nothing either. As brontide explained, it's a relative number, and as such, you can be tricked thinking into just looking at the C-number. But it is as it is, and once you know how it works, it's easy to compare batteries.
SoloProFan is offline Find More Posts by SoloProFan
Old Feb 19, 2013, 09:39 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
In reality, the C rating is a representation of the internal resistance of the cells. Lower resistance means higher C rating.
Discussion Does someone here makes (or can point someone who can) custom Composite Airframes? Reginak UAV - Unmanned Aerial Vehicles 7 Jan 21, 2013 06:29 AM
Discussion Can someone explain motor ratings? ripmax Scratchbuilt Multirotors 5 Jan 15, 2013 08:28 AM
Discussion Does someone here makes or can point someone who can, custom Composite Airframes? Reginak Composites Fabrication 4 Jan 15, 2013 06:00 AM
Help! How can i make, my RC car faster? rampagedude Car Talk 29 May 14, 2010 08:28 AM
Can someone explain to me Mah, cells, and voltage and what it means? JStory Electric Plane Talk 1 Jul 01, 2001 12:38 AM
