Old Feb 15, 2013, 03:51 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Look at this lipo, is it safe to use? bent and dented
I got this new lipo in the mail today and it must have got caught in a conveyor. It is slightly bent, creased in the middle and has a dent in the middle about the size of the tip of a finger. Battery voltage is normal for both cells, but I am afraid to charge it. I contacted the seller, not sure if it's worthwhile to send it back or even IF I should send it back in the mail, seeing that it's damaged. Waiting for seller's reply but I wondered what you guys thought of or if you had any experience with dented/bent batteries. I don't think the foil is pierced behind the shrinkwrap.
shahram72 is offline Find More Posts by shahram72
Old Feb 15, 2013, 04:14 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
If that is NOT a 2S2P I would not use it. If it is a 2P (hard to tell by those pics) the crease may be at the junction of the two internal packs. Perhaps another pic of the whole battery is due?
Rick
rampman is offline Find More Posts by rampman
Old Feb 15, 2013, 04:29 PM
btown2 is offline
Find More Posts by btown2
United States, IN, Bloomington
Joined Sep 2012
http://www.rcgroups.com/forums/showthread.php?t=1831412
btown2 is offline Find More Posts by btown2
Old Feb 15, 2013, 05:03 PM
Joined Sep 2011
No, that's a dent in the corner. both cells run the whole length and you can see the shadow of them slightly in the pics.
Old Feb 15, 2013, 05:18 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
I wouldn't take my chances with that big of a dent. I would discharge it to 0V and toss it.
grimbeaver is offline Find More Posts by grimbeaver
Old Feb 15, 2013, 05:40 PM
Joined Sep 2011
Originally Posted by btown2 View Post
Oh, NO! That's my friend here on RCG, Spookeay, How terrible...
She did report, however, later in the thread that the fired dept said it most likely started at the electrical panel box as that was the hot spot and the fire had burned through the floor at that spot. So this was not likely a lipo fire. Point taken, however, it's not worth the risk.
Old Feb 15, 2013, 05:44 PM
Joined Sep 2011
I get so confused with all the recommendations. You and many others say discharge to 0, some say cut and short the wires after that. But one of the things that makes a battery explode is overdischarge. So how do I discharge it safely?
Old Feb 15, 2013, 05:57 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
http://www.rcgroups.com/forums/showp...3&postcount=27
I'd leave it on the light bulb until the voltage was less than 1V/cell. If your battery charger has a discahrage function, use that. Does it?
I see you have an ECO4 which can be used to discharge the pack.
hoppy is offline Find More Posts by hoppy
Old Feb 15, 2013, 06:06 PM
Joined Sep 2011
Yes, it does have a discharge function, but my question remains. How do I safely discharge the battery when taking it below 3v per cell makes it unstable, puff, and likely to explode?
Old Feb 15, 2013, 06:19 PM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
It just simply stuns me how many people repeatedly post "is it safe to use this battery" time and time again and completely ignore all the other threads JUST LIKE IT and also conveniently ignore the "LiPo fires are REAL" thread that is stickyed at the top of this very fourm. People... listen to me very carefully... I know that the vast majority of modelers buy cheap batteries from Hobby King. The cheap batteries ARE NOT WORTH THE RISK TO YOUR HOME, FAMILY, PETS, FISH, LIFE, ETC. If you have ANY doubts about a LiPo, DISPOSE OF IT PROPERLY!! And please, for the love of sliced peanut butter, DO NOT start another thread about how to properly dispose of a LiPo!!
This was your "Please ignore the weekly battery safety rant from Mike Then".
Mike_Then is offline Find More Posts by Mike_Then
Old Feb 15, 2013, 06:35 PM
Joined Sep 2011
I appreciate your comments. I have read the other threads about battery disposal, but this was not the original purpose of my thread, and the answers in those threads are conflicting, that's why I ask again here.
I will not use this battery. Right now it's sitting on the concrete floor in my garage. I am putting it outside tonight. Hopefully the seller will send me a replacement, cause I do not feel right sending it back through the mail system. I think it's supposed to be mounted anyway in order to mail it back. But if something happened with it on the way back, I would feel guilty, and possibly criminally negligent. If they had opened it, they might have stopped it. I know if I found a battery like this at work (I work at UPS), I would turn it over to the Hazmat disposal guy as hazardous and would not let it travel any further through the system.
Is the battery fine, possibly. Voltage is fine, so it's probably ok, but it's not worth the risk. I'll just get another.
Old Feb 15, 2013, 06:44 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Lipos do just go off for no real reason. They simply go into a thermal run away long after anything was done to them.
So put them in a BIG fire proof pot & lid, or a garbage can with a loose lid. Have that container several feet away from everything else.
Best that you can do. They are dangerous & we know it.
cyclops2 is offline Find More Posts by cyclops2
Old Feb 15, 2013, 07:30 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
1 - Do nothing to the pack until you hear back from the vendor.
2 - A dented pack will degrade much more rapidly than an undented pack due to crystallization of the chemicals in the cell started by the dent.
3 - If and when you decide to discharge it, place the charger and pack outside and discharge it. It will swell up as it goes under 3V/cell but this is a different kind of swelling than that caused by overcharging which is the prelude to ignition. A discharged battery, that is one under 3V/cell, cannot explode/burn/catch fire/ignite/etc as there is no energy left in the battery.
Where did you read that overdischarging makes a battery likely to explode? Maybe on subsequent uses during a charge, but on discharging, never heard of one happening.
Old Feb 15, 2013, 07:41 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
^ This. Overdischarging leads to internal damage and puffing but since the battery has very little if any energy left, there won't be an ignition unless you puncture it and light the gases. It's when the battery is recharged after an overdischarge when the problems happen.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Feb 15, 2013, 08:04 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I think he is thinking it can explode by discharging it completely, no?
Discussion Please take a look at this setup. polykarbon Scratchbuilt Multirotors 3 Feb 13, 2013 11:31 PM
Discussion Can an iPad be used as a FPV viewer for people watching to look at. jasper7821 FPV Talk 8 Feb 06, 2013 10:06 PM
Question Is it safe to use this LiPo? BD Flyer Batteries and Chargers 5 Feb 20, 2009 06:29 PM
Discussion How does this dent look like? Project Batteries and Chargers 5 Mar 20, 2006 01:16 AM
Is this a safe use of Lipo's? Ping Batteries and Chargers 1 Aug 10, 2005 04:21 PM
