Old Feb 15, 2013, 02:48 PM
cwolfe is offline
Find More Posts by cwolfe
cwolfe's Avatar
United States, TX, Spring
Joined Aug 2011
Question
Do I need a power distribution board?
I'm trying to put together a multi-rotor package from HK. This will be my first multi-rotor build. My question is. Do I need a power distribution board if I have a KK control board already? Anything other than ESC's, Motors, Frame kit, KK board?
Thanks for any advise.
CW
cwolfe is offline Find More Posts by cwolfe
Old Feb 15, 2013, 02:59 PM
serrated is offline
Find More Posts by serrated
United States, KS, Overland Park
Joined Feb 2013
i opted for the wire harness. easier to use since you can just route the wires wherever you want, unlike a board that requires a good amount of space to mount, and on frames with little room, you'll have trouble mounting it AND the flight controller.
not saying you can use a power distro board, lots of people do, but it's just easier, in my opinion, to use a wire harness (hobby king sells them)
serrated is offline Find More Posts by serrated
Old Feb 15, 2013, 03:00 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
So, some type of distro is still needed aside from the KK board?
Old Feb 15, 2013, 03:01 PM
serrated is offline
Joined Feb 2013
you'll need props too. slowfly ones work fine since they're cheap and you'll probably crash a lot if it's your first one. tx/rx too if you don't have one already. bullet connectors and shrink tubing if you don't have esc's with them already soldered on
Old Feb 15, 2013, 03:02 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
How does this set up look? Am I headed in the right direction?
Q450 Glass Fiber Quadcopter Frame 450mm
HobbyKing Multi-Rotor Control Board V3.0
NTM Prop Drive 28-26 1350KV / 310W
F-30A - Hobby King 30A ESC 3A UBEC
Old Feb 15, 2013, 03:03 PM
serrated is offline
Joined Feb 2013
yes, because you'll have one battery giving power to all four ESC's. (receiver and flight controller gets power via the BEC in the ESC that'll be connected in the "motor 1" port on the KK board. the harness plugs into your battery, and the other end has 4 red and 4 black wires that plug into each ESC
looks good, just pick out some props and radio and you should be close to airborn. (battery/charger too) low battery alarm would be good to have too so you don't have to time your flights
Old Feb 15, 2013, 03:05 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
Great. Thanks I'll add one to my cart.
Old Feb 15, 2013, 03:06 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
Ahh yes! Props. I fly planes. I have a DX6I and plenty of Orange and Spektrum RX's around. As well as batteries.
I appreciate you taking the time to respond.
Old Feb 15, 2013, 03:13 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
I've added these to my cart. I wasn't sure If I would want to use the distro board or the harness so put both in the cart.
5.5mm Bullet to 4 x 4.0mm Multistar ESC
Hobby King Quadcopter Power Distribution
3 x 10x4.5 SF Props 2pc Standard Rotation/2 RH rotation
Old Feb 15, 2013, 03:25 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
I would go for kk2 fc
ripmax is offline Find More Posts by ripmax
Old Feb 15, 2013, 04:36 PM
symon is offline
Find More Posts by symon
Joined Apr 2007
Yes deffo the KK2 fc!..so easy to set up
symon is offline Find More Posts by symon
Old Feb 15, 2013, 07:06 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
Cool. I think I'll take the advise. I'm not sure about those motors with those props.
I'll pull the trigger on this order in a couple days. Like I need another project going on in the hanger. However, I did just finish one project. My Thomas Morse build (See blog if interested).
Thanks again.
Discussion Power distribution board for Heavy lift Octo Needed gtxkid Power Systems 7 Aug 10, 2014 11:19 AM
Discussion DJI 550 power distribution board with 6S bananawhiz Multirotor Talk 0 Feb 01, 2013 02:08 PM
Sold FPV Manuals Delrin Tricopter w/ Power Distribution board $85 shipped ff954 Aircraft - Electric - Multirotor (FS/W) 0 Jan 14, 2013 07:18 PM
Discussion Power distribution board for Heavy lift Octo Needed gtxkid Multirotor Talk 4 Mar 04, 2012 02:21 PM
Wanted Power Distribution boards needed!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 3 Jun 01, 2011 01:18 AM
