Old Feb 15, 2013, 08:03 AM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
Idea
DIY Brushless Gimbal For GoPro & Nex5
Low cost ,simple DIY project idea for "GoPro Brushless Gimbal",
Need little mod for adapting brushless motors, not finished mine yet, but developable,
I hope you like..
Part List
Description: Name: 2.jpg
Description: Name: 3.jpg
Description: Name: 4.jpg
Description:
Description: Name: 6.jpg
Description: Name: 7.jpg
Description: Name: 8.jpg
Description:
DIY Nex5 Brushless Gimbal
iFlight Gimbal Brushless Motors and BL Controller
Widelec is offline Find More Posts by Widelec
Old Feb 15, 2013, 08:20 AM
Skewp is offline
Find More Posts by Skewp
In progress...
Skewp's Avatar
Estonia, Tartu County, Tartu
Joined Jul 2012
Very nice idea, I hope to see the finished product soon.
Skewp is offline Find More Posts by Skewp
Old Feb 15, 2013, 11:00 AM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Do you have a photo of it assembled?
epyonxero is offline Find More Posts by epyonxero
Old Feb 16, 2013, 01:19 AM
Widelec is offline
Simple is the best
Joined May 2011
There is two way for roll axis motor
Use propeller adapter and nuts (need 5mm drill) or direct screw (need 9mm drill).
First way is advantage for camera balance when the 5mm channel extended to the left side.
Description: Name: DSC00361_Medium.JPG
Description:
Old Feb 16, 2013, 02:31 AM
Widelec is offline
Simple is the best
Joined May 2011
Tilt motors fits to left side when the 2mm screw hole drilled to 3mm.
two hole distance is 19mm like the motor mount screw hole distance.
well fits the tilt motors.
Description:
Old Feb 16, 2013, 02:46 AM
Widelec is offline
Simple is the best
Joined May 2011
One side of the propeller saver adapter is 5mm (caming with motors package)
this parts fit in the second aluminium parts left side (camera container parts) when the aluminium parts drilled 5mm.
I used epoxy glue before before settling firmly
Description: Name: DSC00365mmmm.jpg
Description:
Old Feb 16, 2013, 02:15 PM
Askyvision is offline
Find More Posts by Askyvision
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
How much total cost all of these?
Askyvision is offline Find More Posts by Askyvision
Old Feb 16, 2013, 11:50 PM
Widelec is offline
Simple is the best
Joined May 2011
This is DIY project and all part list in the first post.
Last stiation ;
Need alexmos board and rewind motors
My gimbal final
Old Feb 17, 2013, 12:21 AM
corsair2014 is offline
Find More Posts by corsair2014
United States, TX, Cypress
Joined Jan 2012
Any video of it in action?
corsair2014 is offline Find More Posts by corsair2014
Old Feb 18, 2013, 05:58 AM
Simon Castle is offline
Find More Posts by Simon Castle
Germany, HE, Griesheim
Joined May 2008
Controller
Nice Idea, shame about the cost of the controller.
How about starting an open src SW/HW project.
Any idea about the current load to hold position I guess its quite high.
... Simon
Simon Castle is offline Find More Posts by Simon Castle
Old Feb 18, 2013, 06:02 AM
leemann is offline
Find More Posts by leemann
Canada, ON, Toronto
Joined Feb 2012
+1 on that
leemann is offline Find More Posts by leemann
Old Feb 18, 2013, 06:05 AM
Joined May 2008
Follow the link to Alexmos
Old Feb 18, 2013, 07:44 AM
NDT_UTS_LU is offline
Find More Posts by NDT_UTS_LU
China, Jiangsu, Suzhou
Joined Jan 2013
how can you control the brushless motor like servo????
in which way control the roll axis position ???
NDT_UTS_LU is offline Find More Posts by NDT_UTS_LU
Old Feb 18, 2013, 08:05 AM
Joined May 2008
Well I dont know for sure but I guess you have to power 2 phases at a time and gradually change the amount of on to off ratio of each phase and then switch to the next phase in sequence. The idea is to balance the camera and move the gimbal around it, which seams like a good idea but may be difficult to set up in practice, requiring power to lock the motor and prevent the camera from falling. It would be like trying to balance a falling object i.e. with your finger under a long broom stick
Old Feb 18, 2013, 08:58 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ You need a gimbal controller which takes servo type input for roll/pitch and translates it into motor movement.
I'm sure you might be able to come up with other options as well, but that will for sure work.
wparsons is offline Find More Posts by wparsons
Help! DIY Brushless motor gimbal, need help sourcing parts for gimbal hexa Multirotor Talk 13 Apr 13, 2013 03:08 PM
Discussion Best 2 axis Gimbal for DJI 450/GoPro? FixedWing172 Aerial Photography 3 Jan 11, 2013 04:39 PM
Build Log DIY Pan and tilt for GoPro (or other) Pukin_Dog FPV Talk 0 Jan 06, 2013 02:40 PM
Discussion New DIY GoPro 2 axis gimbal AeroVideoUS Hoverfly Technologies 35 Apr 20, 2012 03:27 AM
Discussion DIY GoPro Gimbal webgeek Aerial Photography 1 Apr 03, 2012 12:42 AM
