Old Feb 15, 2013, 06:58 AM
Joined Jan 2012
New Formula 1 3Racing F113
New 3Racing F1 - F113
Version Kit
Price: $ 224.90
Link: http://www.rcmart.com/3racing-kitf11...g-p-36140.html
Version Combo
Price: $ 322.90
Link: http://www.rcmart.com/3racing-racing...s-p-36021.html
This is the first high end race kits bearing 3 Racing "Factory Racing Products" label!The all new F113 is the first competitive F1 chassis race kit to bare the 3 Racing "Factory Racing Products" label, the introduction of this label was conceptualized with the idea of including the best materials in our high end race kits and to distinguish our line of successful Sakura car kits from the entry/mid-level to race level.
Images:
The F113 was redesigned from scratch and shares very little parts with the successful F109, the F113 is the first to feature various innovative concepts previously unseen on mainstream F1 chassis currently available while maintaining the realistic looks of a real F1 car which in many cases is the fundamental success of the class.
The rear of the F113 employs a 1/12th pan car inspired design with the widely used single pivot ball, side springs and drag link rear suspension system with a longitudinal Symmetric Stroke Through Shaft Design rear Coil Spring Oil Filled Dampers to handle the front and rear weight transfers and another mounted transversely to handle the side to side damping.
The 2.5mm main chassis and 2mm upper chassis are CNC machined from premier grade imported woven graphite. It will accommodate both standard and low profile servos with plenty of room for electronics.
Steering on the F113 can be handled through Standard or Low Profile servos depending on the type of batteries and electronics you are using with a servo saver horn for most popular servos (23, 24, 25).
To maintain high speed stability and agility, the body, front and rear wings features a completely new design with the aim of providing the right amount of downforce while maintaining realistic looks
Features:
2.5mm Main Chassis and 2mm Upper Chassis machined using imported premium grade woven carbon graphite
Front 7075 alum bulkhead
Front Double Wishbone Suspension
Front Independent Dampers
Front Droop adjustment
Ultra flexible impact resistant rear wing and front wing mount
Pivot Ball Rear Pod design with side springs and drag link
Standard or Low Profile Servo
Rear Axle Height adjustments in 0.5mm increments
Ultra low CG 7075 Alum motor mount and bulkhead for Brushed and Brushless motors
1/12th specs 1/4" rear axle and differential with 1/8" diff balls
Processed hardened steel diff plates
Symmetric stroke through shaft design Coil Spring Oil Filled Dampers all round, 3 standard and one oversized center damper for superior shock absorption
PTFE Coated Hardened Alum Damper bodies and ball stud.
Adjustable battery pack stoppers – standard or shorty Lipo packs ready
Centralized weight distribution
Camber caster adjustable
Reactive caster adjustable optimized for carpet racing
Complete rolling chassis with tire and body set
Titanium Turnbuckles
First kit from 3 Racing to bare the "Factory Racing Products" label
Specs:
Length: 410mm
Width: 200mm
Height: 95mm
Weight: Approx 1100g
Wheelbase: 270mm
Requires:
Motor & ESC
Radio System
Servo steering
Battery and charger
Assembly Tools
- Version with Combo -
As part of the celebration of the launch of F113, the 3Racing will feature a version of the F113 with Speed ​​Passion combo, ESC and 17.5T Motor 3.0 S Reventon
vini_itu is offline Find More Posts by vini_itu
Old Feb 15, 2013, 02:19 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
The chassis looks good, but the body doesn't look anything like a modern F1 car.
wparsons is offline Find More Posts by wparsons
Old Feb 15, 2013, 08:05 PM
Kowalski !.....Options
mredzadventure's Avatar
USA, MI, Hastings
Joined Jan 2007
Nice looking chassis. The body does need a little work. It looks like like a body form the middle 1980's Like the F188 or f189 from Ferrari. I really like the front shock set up.
mredzadventure is offline Find More Posts by mredzadventure
Discussion Graupner Rhode Island Formula 1 Tunnel Chinewalker Racing Boats - Electric 2 Feb 06, 2013 08:51 AM
For Sale Pro Boat 1/12 Scale Red Nitro Formula Hydro 2.4Ghz RTR Upgraded! PRB3200 $350 stretch1100 Boats (FS/W) 0 Jan 16, 2013 03:27 PM
For Sale 3Racing LED Light System For 1/10 Scale queadlunnrau Cars - Cars and Parts (FS/W) 1 Nov 12, 2011 11:25 AM
Sold 3Racing F109 & HPI Formula Ten cartix Cars - Cars and Parts (FS/W) 1 Oct 09, 2011 11:26 AM
For Sale NEW 3Racing Blue 5 spoke, rims/tires, need 2 sell asap tyhodge07 Cars - Cars and Parts (FS/W) 1 Sep 30, 2008 02:15 PM
