Old Feb 15, 2013, 02:25 AM
Witterings is offline
Find More Posts by Witterings
Beware Of The Shills !!!
Chichester Sussex
Joined Aug 2007
Your Preferred Connectors
Just interested to see what people's preferred connectors are at the moment ???
I had a lucky ish escape recently when I put the wrong coloured heat shrink on my battery leads and connected it the wrong way and everything worked fine. A couple of days later and I'm connecting the battery and it pushed the looser part of the bottom bit of the Dean's connector up to touch the top bit shorting it and has either blown the ESC or the motor, haven't pulled t out yet to see which yet.
I was thinking of possibly changing all my connectors maybe to XT 60's and wanted to see what other people's experiences are / if they're totally foolproof as it'll be quite a job to take all the ESC's out of every plane and re-solder new connectors to everything and the batteries.
Any input apppreciated !!
Witterings is offline Find More Posts by Witterings
Old Feb 15, 2013, 03:00 AM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Gotta be about the most done to death topic on RCGroups
Run a search on connectors, select titles only in advanced options, and select all the electric forums except FSW: http://www.rcgroups.com/forums/searc...ery=connectors
scirocco is offline Find More Posts by scirocco
derpron is offline
Find More Posts by derpron
darn you, kakka carrot cake.
derpron's Avatar
Australia, WA, Perth
Joined Aug 2012
deans, i hate xt60's because i can never pull them apart.
derpron is offline Find More Posts by derpron
Old Feb 15, 2013, 04:04 AM
stemo99 is offline
Find More Posts by stemo99
stemo99's Avatar
United States, NJ, Pennsville
Joined Feb 2008
T plugs, (deans knockoffs)
stemo99 is offline Find More Posts by stemo99
Old Feb 15, 2013, 04:10 AM
Grantham Kid is online now
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
I use XT 60s but they are hard to pull apart and let go suddenly so it is possible to cause damage to your plane. A friend has drilled tiny holes in his ones and uses circlip spreading pliers to pull them apart.
Grantham Kid is online now Find More Posts by Grantham Kid
Latest blog entry: A bit about me
Old Feb 15, 2013, 07:08 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
HK T Plugs here too. If your having trouble connecting or disconnecting T connectors, flatten the springs with a pair of pliers to suit yourself. If your having trouble connecting them, file a taper on the end of the tabs. On XT 60s, I took a pair of pliers and gently squeezed the male connectors a bit to make them easier to install. If you go to far, you can pry them out with a jewelers screwdrive.
Hope this helps.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Feb 15, 2013, 09:13 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
Dean's or EC3/EC2
chucksolo69 is offline Find More Posts by chucksolo69
Old Feb 15, 2013, 10:35 AM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
+3 for the HK T connectors, I have them on everything that doesn't use JST's. Up to the 12S set up in the plane in my avatar, 16' span.
http://www.hobbyking.com/hobbyking/s...irs_20pc_.html
Evan D is offline Find More Posts by Evan D
Old Feb 15, 2013, 10:37 AM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
ec3
cmdl is online now Find More Posts by cmdl
Old Feb 15, 2013, 10:40 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Anderson Power Poles. And yes, please do a search before asking these kinds of questions... they have been answered and debated ad nauseum.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Feb 15, 2013, 01:36 PM
Logan4169 is offline
Find More Posts by Logan4169
Joined Nov 2011
Logan4169 is offline Find More Posts by Logan4169
Old Feb 15, 2013, 01:52 PM
Wingman26 is offline
Find More Posts by Wingman26
Wingman26's Avatar
Oklahoma
Joined Aug 2008
Wingman26 is offline Find More Posts by Wingman26
tsymonds is offline
Find More Posts by tsymonds
Snappy Title On Backorder....
tsymonds's Avatar
United States, TX, Killeen
Joined Jun 2011
EC or bullets.
tsymonds is offline Find More Posts by tsymonds
Old Feb 15, 2013, 02:15 PM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
JST for small stuff, Deans on anything 10-30 Amps, XT60's on everything bigger.
With XT60's, all you need to do is sand the male connector a little until it is firm but not too loose. I also pinch the male connectors on deans with needle nose pliers to reduce the force to pull apart.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Feb 15, 2013, 03:39 PM
aero550 is offline
Find More Posts by aero550
United States, OH, Tipp City
Joined Oct 2011
Anderson Power Poles. Once you've gone black (and red) you'll never go back. :-)
aero550 is offline Find More Posts by aero550
Poll I Prefer To Fly Alone; Yes or No (Your Flying Preference Poll) Murocflyer Parkflyers 198 Oct 06, 2009 06:16 AM
Poll I Prefer To Fly Alone; Yes or No (Your Flying Preference Poll) Murocflyer Parkflyers 1 Apr 25, 2009 07:57 PM
Discussion Connectors... Got a preference? NumbSkull Sport Planes 28 Jun 18, 2007 05:46 PM
Yippee! Bullet battery connector, are there preferences? Yogi High Performance 12 Jan 18, 2005 12:55 AM
Which do you prefer, E-Z connectors or z-bends ??? Cal Parkflyers 26 Oct 21, 2004 04:00 PM
