Old Feb 15, 2013, 01:34 AM
Trekman is offline
Find More Posts by Trekman
Joined Feb 2013
Suugestion for small motorglider
I am looking for a good quality lightweight small 800mm or so motorglider with removable wings
Have been flying this one after figuring out to glue the prop on, although the company that sold it to me was clueless about what to do. It actually is a really neat design, but it is poor quality. It also has a very poor glide ratio which could partly be caused by having filled the prop cone with epoxy to glue it on, but cannot buy replacement props. Anyway as I say the plane is poor quality. It does handle hard landings well where the wings will pop off
SkySurfer -Defective Nine Eagles RC Plane (1 min 39 sec)
Have searched online and could not find anything this small like this plane, which I would like for portability
Any suggestions welcome
Trekman is offline Find More Posts by Trekman
Old Feb 15, 2013, 05:49 AM
AMA69405 is offline
Find More Posts by AMA69405
Gary L
Dexter, Kansas
Joined Oct 2009
I could be wrong, but... there appears to be a screw in the front of the prop and spinner assembly. That screw most likely holds the spinner on. Remove the spinner and see what's underneath. There is probably a nut that, when tightened (after the prop assembly is installed on the motor shaft), clamps the prop to the shaft via a collett (segmented sleeve) assembly.
AMA69405 is offline Find More Posts by AMA69405
Old Feb 15, 2013, 07:04 AM
stevespana is offline
Find More Posts by stevespana
Huesca, Spain
Joined Aug 2009
If you can get hold of one, a Graupner Chip ( Aka Terry S )
A bit bigger at 1m and more expensive but a fantastic flying model. Currently available in Europe for 100 euros complete with brushless motor, prop spinner, servos.
Flies superbly on rudder/elevator but ailerons can be added to take it to another level.
stevespana is offline Find More Posts by stevespana
Old Feb 15, 2013, 09:43 AM
Trekman is offline
Joined Feb 2013
Yeah looking at the photo one would think the prop screws on, but the prop goes on a bare motor shaft with a friction fit. There is no collet or clamp in the spinner. The screw at the front of spinner is probably there so one could remove it and put a longer screw in to press the spinner off the prop shaft if needed. A great idea except the hole for the motor shaft in the plastic of the spinner is too large so the only answer I could find was to glue it onto the shaft
Old Feb 15, 2013, 11:15 AM
AMA69405 is offline
Gary L
Dexter, Kansas
Joined Oct 2009
Hmmm... friction fit. I guess we're beginning to understand why the radio and plane combo sells for 70 bucks.
Old Feb 16, 2013, 03:49 PM
Trekman is offline
Joined Feb 2013
Any suggestion for where I can find a 800-1000mm motor glider?
Question Where to find motors, props, controllers, etc for 10lb motorglider? flying jeep Electric Sailplanes 23 Feb 02, 2013 03:43 PM
Discussion Looking for a small camera system for remote viewing deathrow Radios 5 Jan 31, 2013 05:56 AM
Discussion Small Tug For Sale Umi_Ryuzuki Dock Talk 6 Jan 17, 2013 01:22 PM
Question Multi4 storage for small lipos? LittleMo FMA Direct 3 Jan 13, 2013 05:47 PM
Canard airfoil suugestions need. rcjetpilot Modeling Science 1 Oct 26, 2003 02:13 AM
