Old Feb 14, 2013, 11:41 PM
dwtriac23 is offline
Find More Posts by dwtriac23
DWTRIAC23
United States, MA, North Andover
Joined Feb 2012
SYMA S031 vs S031G
I bought a Syma S031G and think I was actually given an S031. I thought the S031 came with a 7.4v 1100 mAh Li-ion battery and the new and improved S031G came with a 9.6v 800 mAh Li-po. Can anyone verify what the differences are and if anyone has had any flight problems with either bird? I am not sure I want to go through the hassle of trying to return it for the correct model.
dwtriac23 is offline Find More Posts by dwtriac23
Old Feb 15, 2013, 12:36 AM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
There is no 9.6v lipo, they are made in 3.7v increments.
Balr14 is online now Find More Posts by Balr14
Old Feb 16, 2013, 04:24 AM
drambuidhe is offline
Find More Posts by drambuidhe
United Kingdom, Scotland, Argyll and Bute
Joined Oct 2012
Hi, the s031 had a 9.6v nicad and the s031g (later ) was changed to 7.4 lipo. I have an early s031 and a later model s031 both had 9.6v nicads which I replaced with 11.1v lipos with no ill effect.The later one has a two speed tail motor which is very necessary to get any wind performance.
If you've managed to get an so31with this then do the battery mod and fit a tail rotor from the s033g which makes it really shift.Good luck
drambuidhe is offline Find More Posts by drambuidhe
Old Feb 16, 2013, 09:36 PM
DWTRIAC23
Joined Feb 2012
Thanks for the info guys! I have seen the S031g advertised with 3 different batteries and one guy on youtube mentions the 9.6 lipo which Balr14 educated me of its non existence. My S031G came with a 7.4v 1100 mah li-ion but the box says li-poly. It also has the 2 speed tail motor and I already replaced the rotor with one from my old S033G. I am also losing some weight from the rear and adding it to the nose because it drifts backwards at hover. I am also lengthening the antenna to 54" to make it a wavelength multiple of 27 mhz. I think 1/2 the fun is experimenting with different mods. It has been very cold and windy so I have not had much flying time. I also have the new S33 and had a couple signal drops like the S033G even after replacing the pcb board thinking the first one was defective but weather has been to bad to make any more test flights. I am eager to hear if anyone is having any problems with the S33.
Discussion DH 9118 vs SYMA S031G Inevitability Coaxial Helicopters 28 Jan 02, 2013 08:04 PM
Discussion Syma s031 vs syma s032 jamiek123 Electric Heli Talk 9 Dec 10, 2011 10:25 AM
Help! SYMA S031G Gryo Problem? dsnipes Coaxial Helicopters 6 Aug 20, 2011 04:19 PM
Question Getting a Syma S031G heli shortly -- anything I need to be aware of? The_LED_Museum Coaxial Helicopters 12 May 06, 2011 09:23 AM
