Old May 01, 2013, 10:53 PM
Ricomon is offline
Find More Posts by Ricomon
Ricomon's Avatar
USA, SC, Charleston
Joined Oct 2002
I've had many missions of well over an hour. My only fear is letting the Li-po discharge too far to recharge it.
Yeah, an air bubble in that yaw thruster allows it to cavitate. Wow, it sounds awesome when I put it like that.
Rick
Ricomon is offline Find More Posts by Ricomon
Old May 02, 2013, 12:04 AM
BieneFlyer is offline
Find More Posts by BieneFlyer
BieneFlyer's Avatar
Australia
Joined Mar 2013
I hadn't thought about discharge with the LiPo. Having too much fun. thanks for reminding me.!
Where exactly do the yaw thrusters exit ? With my eyesight I need a magnifying glass to find it.
BieneFlyer is offline Find More Posts by BieneFlyer
Old May 02, 2013, 07:29 AM
Ricomon is offline
Ricomon's Avatar
USA, SC, Charleston
Joined Oct 2002
The steering thruster is hiding inside this 3mm x 1mm hole. Don't feel bad; I couldn't see it or the prop until I looked at the pictures. ...even with my 16X magnifier!
<== This smiley isn't cool, he's blind. That's why he wears the dark sunglasses!
Rick
Old May 02, 2013, 08:03 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
The receiver in the sub will automatically surface when the lipo reaches its cutoff voltage and then shuts down, it was designed for kids after all so no worries about the battery going flat.
derk is offline Find More Posts by derk
Old May 02, 2013, 09:02 PM
BieneFlyer's Avatar
Australia
Joined Mar 2013
Rick
Thanks for that Rick. Gawd, it is tiny.
Old May 02, 2013, 09:03 PM
BieneFlyer's Avatar
Australia
Joined Mar 2013
Thanks Derk,
Anyone got any idea if the battery can be replaced without too much hassle ?
Old May 03, 2013, 01:03 AM
tchalfant is offline
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
There is an earlier post of one being disassembled. Too much hassle is relative....your mileage may vary!
tchalfant is offline Find More Posts by tchalfant
Old May 04, 2013, 09:24 PM
BieneFlyer's Avatar
Australia
Joined Mar 2013
I saw that post. The pictures make it look a risky exercise. (with my eyesight).
I should have said without too much chance of breaking something
Looks like the battery sits in the front section that comes off as a seperate piece without the need to disasemble the whole sub ?
Old May 04, 2013, 10:31 PM
shaneperch is offline
Find More Posts by shaneperch
Joined Jul 2004
I hate lipo batteries mainly cause of the dangers involved and have to buy a special charger. I hope they come up with a much better battery than this.
shaneperch is offline Find More Posts by shaneperch
Old May 04, 2013, 10:38 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Every battery needs a special charger. It's only inconvenient if it's not one of the chargers you already have.
ruzam is offline Find More Posts by ruzam
Old May 04, 2013, 10:56 PM
BieneFlyer's Avatar
Australia
Joined Mar 2013
Lipo's and water don't mix. That I know.
I'd bet the seal would be damaged if it was disassembled ?
Old May 04, 2013, 11:34 PM
ruzam is offline
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Lipos and air don't mix either (don't ever try to disassemble one).
Old May 05, 2013, 07:42 AM
Joined Jul 2004
I just don't like the idea of fires and damage if you do this or you do that, too complicated and to sensitive. My feelings
Old May 05, 2013, 01:50 PM
derk is offline
derk's Avatar
Joined Dec 2003
fires can result from nearly any battery if improperly handled or mistreated. ever seen what a nimh does when they go up? its like a shotgun firing outside of a gun
sure, lipos and water dont mix, neither do nimh, or life. taking proper care of any battery will make it last longer and work better. and with this teeny tiny 20mah cell, the chance of an actual fire is non existent as it cannot produce enough heat to ignite itself.
as for replacing it, it wouldn't be too hard, just be sure to solder the little pcb on the old battery back onto the new one, otherwise you will kill the new cell. i have done numerous toy and electronic cell replacements, and thats the main thing to watch for, next to proper cell capacity.
Old May 07, 2013, 07:53 AM
BieneFlyer's Avatar
Australia
Joined Mar 2013
Just discovered she doesn't handle lint or hair very well.
The tiny prop gets fouled very easily.
The sub stopped all forward & back movement. The prop seems to have much hair and assorted lint wrapped around it.
I need to get some tiny tweezers & a magnifying glass to try and remove it.
Sold Spring Air 102 Retracts 3 Gear set w/ Struts, tank and Wheels badbill Aircraft - General - Miscellaneous (FS/W) 5 Feb 09, 2013 11:14 AM
For Sale GoPro 3 WiFi remote control with charger for sale, FREE SHIPPING ! ! ! jasper7821 FPV Equipment (FS/W) 2 Jan 07, 2013 05:08 PM
Sold Air Hog planes, parts, and different channel remotes. Curt S Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Feb 13, 2012 11:29 AM
Discussion New Air Hogs Gryphon - 3 Channel Coax edwong3 Coaxial Helicopters 15 May 26, 2011 07:23 AM
